Question about KitchenAid KHMS145J Microwave Oven
I am replacing the Kitchenaid microwave door KHMS145JBT
I am replacing the door for a Kitchenaid KHMS145JBT over the stove top microwave. I have the replacement. I know the key is not from the screw end but probably has something to do with disengaging the hinges. Help?
  • 5 Answers
SOURCE: microwave
It sounds like there may be a blown fuse. The back of the mw oven will have to be removed to check. Some ovens only have a thermal fuse and not a traditional glass fuse. If that is the case you should call a technician to repair it unless you know how to use a soldering iron.
Posted on Dec 26, 2007
MicrowaveSvc
  • 9047 Answers
SOURCE: Microwave
You can download Kitchenaid/Whirlpool owner's manuals and installation instructions here.
They're very handy when uninstalling them too.
If you have a problem with your microwave, we may be able to guide you to an affordable repair.
If you're interested, please reply back with your brand and model number as well as your symptoms so we can help you.
Posted on Dec 15, 2008
MicrowaveSvc
  • 9047 Answers
SOURCE: Broken torsion spring needs to be replaced
There are indeed two springs that "cross" each other, and they must be both be replaced to ensure full strength.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) that demonstrates how it's done.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Posted on Dec 25, 2008
SOURCE: i have an over the stove kitchenaid microwave w
The issue is probably your exhaust fan on your microwave comes on automatically when it detects a certain temperature. Mine does this as well but will turn off automatically after temperature goes down.
Posted on Mar 04, 2009
SOURCE: Microwave Oven Door Spring Replacement
Remove the front panel by removing the screws located on the inside of the door (note hold door inplace, since it is heavy and will fall out after screws removed). Unscrew screws located on bottom of plastic retainer (2 each) Remove tension spring. Note 2 are included right and left. Note color of spring on end, different springs for different door types, stainless, black,beige or white. Replace all in reverse order.
Posted on Mar 26, 2009
How do I fix stove top lights?
Find the manual online by going to Google and put in the make and model of your stove. It's usually found on the inside of the door. In the manual it will tell you how to replace the lights (bulbs).
Oct 12, 2014 | Whirlpool MH6130XEB/Q Microwave Oven
Hot microwave door handle
I always recommend that you use the vent fan whenever you're cooking on the stove top to keep heat, steam, and grease out of the controls and door panels.
Jan 08, 2013 | Whirlpool Microwave Ovens
My wife slammed the door and now the microwave does not work. it popped the fuse box and also cut the power to the stove. i flipped the switch in the fuse box and the stove came back on but not the...
You can try to take the unit down and open the cage. Look at the door safety switches and see if they also popped out of place. She might have permanently damaged the door. But don't panic just try what I just explained. Turn off all power first at the breakers.
Jan 05, 2011 | KitchenAid KHMS155L Microwave Oven
Will not turn on says door
There are 3 door switches arond the door that can throw up this error but if the 2 fuses are blown also it will throw up this error. You can ohm out any of the fuses or even the door switches but until you repair them it wont work. I have even found both fuses to be blown. If you are nervous about pulling apart your stove make sure whoever does is very familiar with this line of Kitchenaid. Hopefully this helps.
Jan 30, 2010 | KitchenAid KBMC140H Convection Microwave...
Rattling coming from top grill on Kitchenaid microwave
the gril at the top (above the door) usually comes off with a couple of screws or just pulls off .. on some you have to take the cabinet apart ..... inside you might find a flat filter put in at a slant .. its often a grease and smell filter that contains activated charcoal .. when it gets clogged then it can rattle around as air tries to get around it .. you can replace it or just leave it out ..
Oct 04, 2009 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Microwave high intensity light turning bright orange
You have a shorted grille relay on your control board. I can repair this for $69.95, which includes insured return shipping.
For details and more free DIY and other help & advice, feel free to contact me.
William E. Miller, AS-EET
pupista@gmail.com
http://www.microwavecontrol.com
Microwave Oven Control Panel Repair Nationwide
"Recycling by repairing since 1982"
Mar 15, 2017 | KitchenAid KHHS179LSS Convection /...
Microwave
Dec 14, 2008 | Microwave Ovens
KitchenAid KCMS185JSS1 Door Removal
On most new MW ovens, the door will lift off the hinges once the top grille is removed. There are two screws on the top that hold the grille in place.
Mar 12, 2008 | KitchenAid KCMS145J Microwave Oven
KitchenAid KHMS145J Microwave Oven Logo
136 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Stu Ungar
Darial Jr Lasaria
Darial Jr Lasaria
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
