Question about Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca
My nikon s550 wont extend
At first when i turned it on the lens would go in and out a few times then say lens error. but now it dosent even open up. what can i do to fix it without having to pay a bunch of money for it?
  • 3 Answers
What finally worked for me was a mix of the ideas listed here. I placed a vacuum hose against the lens and turned on the vacuum, then turned on the camera and tried to gently pull them apart. There was just enough suction to pull the lens through the spot it was sticking on and PRESTO! It works again! The focus was nasty at first, but another quick power cycle fixed that up. The lens hasn't locked up again despite many power cycles. I used a proper canister vacuum which happens to have a new bag in it, so plenty of suction.
Posted on Feb 25, 2011
  • Rsrsrs Rsrs
    Rsrsrs Rsrs Nov 09, 2013
    Thanks for the tip. I had given up almost after trying 3 to 4 times. However, last two efforts, kept the Canister vacuum so close and it did the trick last try.
Blurry images (after a lens error)
There is a mechanical displacement in your camera. Definitely, it is not a software problem. Actually Digi Cams are very delicate, especially small ones.... So get it serviced from a authorised service station. They will fix the problem....
Pleas rate the answer iof you find it useful.
Apr 27, 2010 | Nikon Coolpix S550 10 Megapixel Digital...
The camera shutter wont open
if the camera is turning on and the lens pops out, it is not fully expanding. this may be because the camera was dropped and now the lens guide is damaged.
Nov 07, 2009 | Nikon Coolpix S550 Digital Camera
Nikon Coolpix S550 Lens Error
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Sep 30, 2009 | Nikon Coolpix S550 Digital Camera
Nikon Coolpix S550 Lens Error.. Need fix without spending
No, even if you could find a lens for free this is not an easy camera to replace the lens on. Even a qualified tech would take up to an hour to replace. Understand that today's cameras low cost makes replacing the camera a better option than repairing a camera who's value used is less than the repair cost.
Jul 03, 2009 | Nikon Coolpix P1 Digital Camera
My nikon camera lens won't work
You must have cleaned/repaired by a professional.
Nikon is in Melville, NY or you may contact
SP-TS.com, an Authorized Service Center in Florida for an estimate.
Apr 20, 2009 | Nikon Coolpix S550 10 Megapixel Digital...
Nikon s200 when camera turned on lens error
You may have a jammed lens assy. When the camera is turned on, camera go through a few stages of processing to be ready to take picutre and if the lens does not respond mechanically, it will give you a lens error. Lens jams due to sand or impact (even unnoticable light impact). If the lens is extended out you can somehow grab the lens barrel lightly with two fingers while turning the power on and nudge it side by side. If this did not help, take it to a reliable local technician for a diagnostic(should be free). Good luck. -james
Mar 28, 2009 | Nikon COOLPIX S200 Digital Camera
Samsung L730 wont extend lens and dosent turn on right
Met the same problem. I disassembled camera and found a lot of sand in lens transmission. I couldn't move lens even by hand. It was strongly jammed. I had to disassemble lens block completely to remove all sand. Now camera fully functional.
Dec 15, 2008 | Samsung Digimax L730 Digital Camera
Wont turn on but light is blinking
Are there any error messages on the LCD display?
Will the camera lens stay out when the camera is turned on?
Can you still take a photo/flash/sound without seeing the photo?
If the camera will not turn on even with a fresh set of batteries it could have a system or lens error in the camera.
a possible lens jamb when closed and the green led on top comes on then shuts off after the lens attemps to extend but cant.
Aug 29, 2008 | Nikon Coolpix L11 Digital Camera
Nikon Coolpix L1 has "lens error" message
get it repaired from a local repairman ,..... we have replaced many lens barrels and gear sets as well as Flex strips which cause this problem ....
Aug 14, 2008 | Nikon Coolpix L1 Digital Camera
Nikon Coolpix S550 10 Megapixel Digital Camera (Graphite Black) with 5x Optical Zoom + 4GB Memory Ca Logo
136 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
