Question about Acer AL1916W 19" LCD Monitor
My monitor just went out with no warning. It will turn on but display nothing
  • 11,361 Answers
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply, blown fuses, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed ACER monitors to get some ideas what to look for: http://s807.photobucket.com/home/budm/allalbums
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://en.wikipedia.org/wiki/Capacitor_plague
http://www.badcaps.net
Service manuals: http://elektrotanya.com/?q=showresult&megnev=ACER&megnev2=AL1916&kategoria=&kat2=all
Posted on Jun 01, 2010
BOUNCING CHARACTERS/DISPLAY
1. Verify the monitor's power cord is plugged firmly into the wall outlet and the back of the monitor.
2. Verify the monitor cable is firmly connected to the computer and the monitor.
3. Verify that you have turned the monitor power switch on.
4. If the power light on the monitor is not on, test the wall outlet (plug in a light or something you know works).
5. If the power light on the monitor is not on, try a different power cord.
6. If the power light is on and yellow or flashing, but nothing displays, or the display is incorrect, borrow a monitor from a friend. If that works, your monitor probably needs replaced.
Mar 22, 2014 | AOC 19" LED Monitor e950Swn Black
I have connected my monitor to a kvm switch but it displays nothing on screen...please help
If you are getting no video then either the KVM Switch is not transmitting video or the cable is defective. I would recommend checking with the supplier of the KVM Switch you are using.
Jan 18, 2012 | HP TFT7600 Rackmount KVM Switch
Monitor will not turn on.
Friend. Not a good news.
First check whether all the connection of monitor to the cpu is alright. If the connection is okay, then try connecting an external display and see whether display comes on or not on the external monitior. If yo get the display on the external, it means you have faulty monitor or video card. If you get nothing on the external monitor, it means your motherboard is faulty
May 25, 2010 | Sony SDM-HS75 17" LCD Monitor
Warning "not optimum settings"
Press F8 as the computer boots up and the Windows Advance Options Menu will be displayed. Then select Safe Mode to boot up the computer.
When Windows finishes booting up, then open Control Panel - select Display - Settings, then change the screen resolution to a lower setting.
Apply and shut down and reboot computer.
Dec 19, 2009 | Samsung SyncMaster 912N 19" Flat Panel LCD...
Monitor Will not come on
bad capacitors inside the monitor they need to be replaced, or if the power light is blinking then there are transistors that need replacement
Mar 22, 2009 | Dell E198FP LCD Monitor
No Display.
the problem is seem to be in your moniter vedio driver ic which is present inside the moniter it is programmable ic, it may get heated or corrupted so pls check your moniter
the service manuals are available at eservice.com
Mar 18, 2008 | ViewSonic VA2012WB Monitor
DEAD SCREEN
Disconnect completely computer and display form power cable for ten minutes, plug them back and restart ().This is called hard reset.
If you still have the problem try checking the display video cable, both in the monitor and computer socket.
If it still does not work connect PC to a different monitor, just to test that is not the pc or the video card the problem.
If it still does not work the blackout may have caused a short in your monitor or a system failure on pg then get back here and post the new problem.
regards
Mar 13, 2008 | Samsung SyncMaster 740N 17" LCD Monitor
Compaq monitor no working properly
Did monitor work's on another pc?
If YESS so u need to change ur VGA
Nov 02, 2007 | Compaq Presario 5000 PC Desktop
Acer AL1916W 19" LCD Monitor Logo
105 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
