Question about Dryers
Electric dryer FEQ332ES WOW, the control start switch doesn't work
Hit start button dryer doesnt work
Posted on Jun 16, 2008
    Scholar:
  • 178 Answers
Evidentally, this is a common problem for these dryers. I have found parts available for you to order and replace yourself if you would like and save from a hefty repair bill. The cost of a new switch is 24.74 before shipping. Depending on your location, 9 nationwide warehouses have them in stock in multiple quantities. If you would like further information, conatct me via e-mail at [email protected]. I'll be more than glad to help.
Posted on Apr 09, 2008
SOURCE:
Stop button doesn't work on Amana NED7200TW Electric Dryer.
Check the door switch to see if it "clicks" when you push and release it. If it clicks, then the control board will need to be replaced. Here is the part you will need to order.
Nov 01, 2012 | Dryers
My Whirlpool Dryer GEW9868KQS has power, but won't start when the button is depressed. The sensing light comes on, but the dryer doesn't start. Any ideas?
It's probably either the start switch or door switch. Try bypassing the switch and see if it starts. If it does,you can either replace the switch or try taking it apart and fixing the switch yourself. (I had a switch that simply required a copper contact to be readjusted and its worked perfectly for several years)
Oct 18, 2011 | Whirlpool LER4634J Electric Dryer
Dyrer on comes on when button is press, once you let go it turns off. we have to keep the button pressed in at all times in order for it to work.any ideas???
place a jumper wire , between the 2 wires that attach to the start button, if this fixes the problem replace the switch , leaving it on all the time will burn it out since its a momentary switch , if that doesn't fix the problem, then check the door safety switches, and the control thermostats
Jul 09, 2011 | Maytag MED5600TQ Electric Dryer
The dryer wont show any sign of power. The plug works fine
Press and hold start button for 4-5 seconds.Make sure that the start button has been fully pushed down or turned far enough to activate the dryer.
After that plug something else into the same outlet. If it works, you know you have power to the dryer. If it doesn’t work, you’ll need to check for any blown fuses or tripped circuit breakers.
If the power is there, you need to check door switch, thermal fuse, thermostats, and start switch to see if one of these is faulty.
Make sure that the control settings are appropriate, and that any buttons are fully depressed.
Good Luck and have a nice day.
Jun 21, 2010 | Frigidaire Electric Dryer
Frigidaire FEQ332ES tumbles but does not heat up. Replaced the thermostat, did not solve the problem.
check ur breaker see if something is tripped dryer willl run on 120 but needs 240 to heat..
check ur element and also a thermal fuse, there might also be another thermosat that could be bad.
if gas check the ignitor, fuse, and thermostats
Feb 05, 2010 | Frigidaire FEQ332E Electric Dryer
Frigidaire FEQ332ES-It starts out ok, then trips the breaker, then no heat, continues to run but only blows cold air
sounds like your heat coil element is shorted, this coil is in the inside behind the drum..
replace coil and this will solve your problem, the coils break , you get no heat but voltage goes to heat elem that is shorted, trips breaker
Sep 16, 2009 | Frigidaire FEQ332E Electric Dryer
My Fridgidaire feq332es dryer has stopped heating in certain cycles. I read the thread about the control thermostat, I think I can change this myself do you have someone who can give me some direction on...
Have you checked your duct and vent for lint clogs? If you vent is obstructed, it will cause the unit to shut down the heat. Try removing the duct hose and examine for lint clogs. Be sure to look into where duct connects to your dryer. Then take a look at the wall vent, both inside and outside the house as well. You might try that before replacing the thermostat.
Jun 08, 2009 | Frigidaire GLEQ2152ES Electric Dryer
Clothes dryer don't run
sounds like a bad cycle timer switch
Apr 22, 2009 | General Electric Clothes Dryer Knob -...
Dryers Logo
103 people viewed this question
Top Dryers Experts
Marvin
Marvin
paul
paul
