Question about Uniden Cordless Phone
We have a Uniden DSS 2475 system installed for domestic use - one base station and 2 satellites. It has developed a constant background buzz in all 3 handsets which is very annoying. A Uniden FP204 analog handset is plugged in and doesn't suffer from the same problem. Any clues on how to rectify?
  • Uniden Master
  • 12,061 Answers
Yes Buzzes nearly always end up being in the base stations Power Supply, and earthing. You need to try another Power Adapter. I have also found that some base units, are still faulty even after replacing the power supply, and in these cases it is usually a problem, a bad diode, or smoothing capacitor, in, with the actual power supply inside, the Base Unit. They are pretty easy to fix, however i don't know how economic the repair would be? If you decide to repair, you must take it to a Uniden authorised repair center, and ask for a "Quote" before proceeding with any repair.
Posted on Jun 01, 2010
    President:
  • 3,278 Answers
Hello.
There could be an interference.
In general, keep the handset away from microwave ovens, computers, remote control toys, wireless microphones, alarm systems, intercoms, room monitors, fluorescent lights, and electrical appliances.
Move the base or satellite phones to another location or turn off the source of interference.
If still a problem, I would suggest disconnecting all handsets and connect the base station to see if all OK. If OK, add one phone at a time.
Hope this helps.
Hi i have a uniden ZO68 i want to add another hand set to this i have brought another uniden ZO68 second hand hand set and i can't set it up can you help me please
did you get the charging base with the hand set
is it a charging base or a base station base
if it is just a charging base , follow the instructions as how to get the base station to recognize the next phone
if it is a base station, probably won't work as you will have 2 base stations trying to work and that will create conflicts
talk with a telephone technician to see what can be done
Oct 30, 2016 | Uniden Lands Phones
Is the uniden 3105 additional handset compatible with the n32 base station? i was told it was by harvey norman, but it says registration failed..how do i do it?
It should register once it is charged and put into the cradle of the base station.the channels are selected automatically by the base station.the only time it doesn't is when you try using a handset for 2.4ghz system when the base is 5ghz or vice versa.
Mar 09, 2015 | Uniden Cordless Phone
How do you register a old uniden SSE27 handset to a new Uniden SSE37 base
The following is taken directly from the SSE37 owners' manual:
Registering a handset
If you see a "not registered" message on a handset,
you must register it to a base before using it.
1.
On the base, open the menu and select
Register Accy.
2.
On the handset, press and hold #/DND
until the handset display says
Handset Registering (about 2 seconds).
3.
Wait until the handset display says
Registration Complete (about 30 seconds),
then pick up the handset.
If you don't hear a dial tone or the display says
Registration Failed, charge the battery completely,
then try again.
Feb 19, 2015 | Uniden Lands Phones
I can't get a dial tone. It says connecting and
It sounds like you have a defect in the main base, I suggest returning the item because you have gone as far you can go short of taking it apart.
Jun 09, 2011 | Uniden 2.4GHz DSS Cordless Dual Handset...
We just bought a new uniden phone system and the Answering Machine keeps answering the phone after 2 rings. I set the base machine setting to answer after 6 rings but it didn't change.
If you have changed the setting on the base station and that did not work, power your base station off completely and try again if that does not work you have an out of box defect and need to exchange it.
May 06, 2011 | Uniden DECT 6.0 Cordless Phone ID
The base ringer on my Uniden TRU9480 base station rings very loud and cannot find where to either adjust or discontinue the ringer. Jackgee1
I found my owners manual and to adjust the ringer on either the Base Station or Hand Set as follows:
with the hand set in place just use the base arrow up or down to go from 0 (off) to 2 (loud) and on the hand set just use the arrows for high low or off. Just bew sure to have the hand set on the base before adjusting the ringer
jackgee1
May 01, 2009 | Uniden 2.4 GHz Cordless Phone System
Does Uniden sell Satellite Dishes? Several years ago people were able to purchase Satellite Dishes from Radio Shack. This enabled them to get non scrambled television stations from around the world. Does...
What you are referring to is a FTA receiver. These are generally considered to be illegal and people who install them are then charged 4500.00 by direct tv because of the assumption that their signal is being stolen. Uniden no longer sells them for this reason
Apr 17, 2009 | RCA DISH Network(r) 311 Satellite System
My base won't stop flashing it just start it today
Our handsets and base are flashing and the base is lit up constantly.
My model is Power Max 5.8ghz.
span.jajahWrapper { font-size:1em; color:#B11196; text-decoration:underline; } a.jajahLink { color:#000000; text-decoration:none; } span.jajahInLink:hover { background-color:#B11196; }
Nov 29, 2008 | Uniden Cordless Phone
Uniden Cordless Phone Logo
85 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
