Question about Fujitsu ScanSnap S1500 Instant PDF SheetFed Scanner (PA03586B005) Flatbed Scanner
Will not scan light just blinks
I have an scansnap s1500 i have not used it in a month or so and now when i try to scan the light just blinks and nothing happens. i have tried unplugging and re-plugging but it just blinks. any suggestions?
SOURCE: No communication between computer and scanner
For interim jams like you mentioned, pull the power cord out of the scanner, close the scanner up, restart your computer, then plug the power cord back in and open up your scanner. Hopefully you will be back to scanning.
I am having a similar problem, but there nothing works permanently. My ScanSnap stopped communicating with the computer, reboots etc, don't work. An interim solution that worked was to reset the computer to an earlier configuration. That worked great for about 20 scans. Then it stopped communicating again. You can tell because the icon-tray changes to an S with a slash through it, and the power light no longer illuminates.
I have tried every uninstall, reinstall, etc. that I can think of. I would like to try to find the registry items and try to fix it there. In any case, if you have an updated answer, I am eager to hear it.
Posted on Feb 10, 2008
  • 6 Answers
SOURCE: My Fujitsu ScanSnap S510 only flashes 5 blue lights
I got off the phone with Fujitsu and i was told you need to make sure that the ScanSnap Icon is in the system tray without a Red Line cross through it, so if it is not in your system tray start the snap scan program, if it's disabled re-enable it and you should be good.
Posted on Jul 13, 2009
  • 4 Answers
SOURCE: PFUSSMON HAS STOPPED WORKING ON MY SCANSNAP S1500
Find your specific scansnap product and update it:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
A user had a similar issue and I found this update for the scansnap S1500 manager:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
This occurs with certain Intel dual core processors, so you might be effected accordingly.
--Rob
Posted on Aug 14, 2009
SOURCE: I installed ScanSnap on Windows 7 under the
OK; after giving up on lousy tech support I got it working after doing the following (not sure if all required, but this is what I did)
1. Gave admin rights to C:\Program Files (x86)\PFU
2. Updated to latest ScanSnap Manager V5.0 L21
3, Copied C:\Users\<admin acct>\AppData\Roaming\PFU directory to C:\Users\All Users
Good luck...
Posted on May 10, 2010
  • 2069 Answers
SOURCE: I'm trying to install the
ok, for scansnap software, you have to first install the software before you connect the scansnap. so since it was there before and probably got corrupted (deleted incorrectly), first uninstall it completely. then, reinstall software. and just as stated on their site here, Imaging devices are one of the most tempermental installations for computers, and there is usually a very specific order and method to installing them. post back for a followup.
Regards
Posted on Nov 14, 2010
Scansnap hardware error 0x00048004
I had this exact same problem. Turned out that I was using the wrong power adapter. Enough power to turn on the scanner lights and connect to the computer, but not enough to actually perform a scan. As soon as I realized I was using the wrong power cord, I switched it up and voila!
Jan 23, 2013 | Fujitsu ScanSnap Manager
Scan snap won't work
This is a known problem with Fujitsu ScanSnaps. Some units experience the "blue button of death" meaning they no longer respond to waking the driver up when you press the blue button. Customer service is aware of the problem and if you are under warranty you should be able to get a new unit.
Mar 21, 2012 | Fujitsu ScanSnap S1500 Instant PDF...
Everytime i try to scan any document using my Fujitsu ScanSnap S510, the blue light on the front-right side of the device blinks 3 or 4 times and nothing else happens (the document, therefore, is NOT...
I had a similar problem. All I did was unplug the USB cable from the scanner and reattach it. Sometimes I would have to close scansnap (blue "S" icon in the sys tray at the bottom right), and then power on the scanner.
Nov 28, 2011 | Fujitsu ScanSnap S510
I have a solid line appearing top to bottom down one side on documents after I scan them, how can I remove it
You need to open up the unit and clean all pieces of glass. There is something on the glass causing the line.
Aug 04, 2011 | Fujitsu ScanSnap S1500 Instant PDF...
My scanner keeps flashing and not pulling the paper through, I cannot seem to figure out why it will not scan. It does this quite often, what is the problem that is causing this? Scansnap S1500
Go to msconfig or if you have a registry cleaner, go to the startup menu. Disable and ssmgr (scansnap manager in pfu). Reboot. Open the ScanSnap 1500 and then start the ScanSnap manager. The scanner is now ready to scan.
Jan 26, 2011 | Fujitsu ScanSnap Manager
My Scan Snap won't scan. The Scan light just blinks and nothing happens.
My Scansnap was being used through a USB powered hub.
This worked....Shutdown EVERYTHING and unplug computer from your powerstrip for 10 seconds (or just turn off your powerstrip for 10 seconds) It resets the BUS power. This solved why almost all of my USB devices stopped working or were behaving badly.
Jun 01, 2010 | Fujitsu ScanSnap Manager
I installed ScanSnap on Windows 7 under the administrator account and it works successfully. The problem is with the other non-administrator account. The ScanSnap icon was not installed on the...
Good luck...
Mar 21, 2010 | Fujitsu ScanSnap Manager
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
--Rob
Jul 08, 2009 | Fujitsu ScanSnap Manager
Fujitsu ScanSnap S300 PfussMon has stopped working
--Rob
Apr 09, 2008 | Office Equipment & Supplies
Open Questions:
See all Fujitsu ScanSnap S1500 Instant PDF SheetFed Questions
Fujitsu ScanSnap S1500 Instant PDF SheetFed Scanner (PA03586B005) Flatbed Scanner Logo
687 people viewed this question
Top Fujitsu Office Equipment & Supplies Experts
Tony
Electro Med Services...
Are you a Fujitsu Office Equipment and Supply Expert? Answer questions, earn points and help others
