Question about GE A730 Digital Camera
Message says to format memory card but it has been previously formatted and has many pictures on it which it says will be lost if formatted. Same thing happens when trying to download to PC. How do we save those pix?
    Genius:
  • 1,234 Answers
Preformat : By Fix-shad0w
#1
Insert your memory card into your computer's reader if you have one. If not, you can purchase a multi-format USB Memory Card reader from Amazon.com or Buy.com
#2
Open up 'My Computer'. You should see it under the list of available drives.
#3
Check its contents first to make sure that you have the right drive.
#4
In 'My Computer', right-click on the drive and choose 'Format'.
#5
Leave all the options as they are and click on 'Start'. This is a non-reversible process so make sure this is what you truly wanted to do in the first place.
#6
Once the process is completed, take the memory card out and insert it into your Digital Camera or any other device. Try to browse to it to make sure it works fine now.
With A USB , CELLPHONE , Camera The SameThing
Posted on Aug 27, 2010
Format recovery
Here is a video tutorial that can help you restore card data back from this formatted SD card step by step:
https://www.youtube.com/watch?v=7PAMc6eNPbU
I find it when my Seagate hard drive was formatted by my friend and it helps me restore most of my drive videos, files and images.
So, it can also be useful for you.
From now on, make SD card data backups all the time.
Oct 20, 2014 | SanDisk Electronics - Others
Screen is black and memory card should not be full,
the error could be due to several things - the card reader, pins bent, card getting hot or near magnetic source...
go ahead and re-format your card, even though u might risk never being able to retrieve your photos.This is better cuz if u send it for repair they will charge between $100-$150.
But I found a free recovery software called Zero Assumption Digital Recovery (http://www.z-a-recovery.com) which will able you to recover photos.
Goodluck,
Please don't forget to rate me as fixya..
Feb 09, 2008 | Nikon COOLPIX S6 Digital Camera
Tip
How To Fix You Camera's "Card Error" or "Card Not Initialized" Message
When you recieve a "Card Error" or "Card Not Initialized" message, this indicates that your memory may be temporarily corrupted. This can be due to not formatting your memory card on a consistent basis. Most consumers will use the "delete all" feature and continue to take pictures. By doing this, the file format of the card may become unstable.<br /><br />We recommend formatting your memory card in your camera after saving the images from your previous shooting session. Once a memory card is formatted, the images will not be recoverable.<br /> <br /> If this doesn't fix the Card Error, try replacing your batteries with a new, fresh pair of batteries. Also, if you haven't tried already, replace the memory card with a known working card and see if this fixes your error.
on Feb 14, 2011 | Cameras
Card error or camra on or of problem
If the camera was working properly while taking the pictures on this card then the problem lies with the card. Format the memory card, formatting the memory card cleans previously taken pictures and allows for new pictures to be made. Even if you are using a "new" card it needs to be formatted to the camera it's being used in. Your camera dates back to 2004 so a problem I recently ran into with my own camera was I needed to update the "firmware" when I tried to use a memory card larger then 2gig. If you have just purchase a new card and it is larger then what you have been using this might be the case as well. The card error message may also be caused by removing the memory card from the computer without "ejecting" or "safely remove" which shuts off the connection to the card then disconnect. Another reason is if the user constantly deletes pictures and doesn't format.
Hope this was helpful not not confusing.
Dec 22, 2010 | Fuji FinePix S7000 Digital Camera
Card error
If you get a message as "Memory Card Error" on your camera AND you still need some of the photos , the first step is to format the card through the camera menu (Note: if you have an sD card, once you re-format your card any photos cannot be recovered.). check your camera manual to see how to format your memory card. If this does not help, try another memory card (say the small 16/32mb card that came in the box with the camera). If this card does not display a "memory card error", then the other card is at fault.
To format* a memory card:
(*instructions on formatting memory cards can be found in your camera's user manual) you equally format the card using your computer if the above method fails,if the micro sd card is inserted into the sd slot of your system the computer sees it as a storage device in that way you can format it the usual way you can format a drive on your system but mind you if you have valuable pictures on it ,they will be lost but in that case you can use the low level format utility
Jan 06, 2010 | Olympus SP-700 Digital Camera
Lost pictures in memory after answering "yes" in Format.
Formatting will delete all images stored on the card. They are gone
Dec 30, 2008 | Samsung L100 Digital Camera
Write protect message appears on screen
Sounds as if the memory card may be corrupted. In order to remove the write protect, make sure you have downloaded and saved all of the images from the memory card to your computer and then having the card in the camera you will need to run the format option and this will permanently remove the write protect as well as all of the images from the card.
The card should be able to be used again after the write protect is removed.
Dec 14, 2008 | Olympus MJU 400 Digital Camera
Bluetooth
Back up first files on your memory card on your computer. then format the memory card on the pc. Then put back the formatted memory card and format it again on the phone. Take out your memory card then put it back again on your pc to copy your previous files. This should work.
Memory cards need also formatting same as HDD's
Hope this helps...
Jul 24, 2008 | Nokia 6131 Cellular Phone
Fuji Finepix XD card was being used last night
Jan 01, 2008 | Fuji FinePix A345 Digital Camera
Memory card formatted in error
Once the memory card is formatted, the files saved or pictures will be deleted and there is no way to retrieve the images.
I would advise that you transfer the pictures first to your PC before formatting the memory card.
Sep 25, 2007 | Cameras
GE A730 Digital Camera Logo
20 people viewed this question
Top GE Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you a GE Camera Expert? Answer questions, earn points and help others
