Question about Chicago Pneumatic 1/4" Air Screwdriver
I have a 21gal.125psi compressor,that will not pump up over 60-65
I put an automatic drain on it, and taped the threads w/ tefflon tape. I keeped the tape from hanging over the end of the fittings. Ifound 1 small leak, but not big enough to leak fast enougn to keep the compressor from pumping up to 125psi. Plus when I shut the compressor off it dose't leak the air pressure down.
  • Ronny Bennett Sr.
    Ronny Bennett Sr. Jun 01, 2010
    What is the exact problem?The compressor will not pump up to 125 psi?Does it shut off?If this is the problem,there should be an adjustment in the regulator box.
  • parrill2 Jun 01, 2010
    It pump up to 60-65psi but no higher, and it does not shut off.
  • 6,927 Answers
Change the check valve
Posted on Jun 01, 2010
    Problem Solver:
  • 6 Answers
On most compressors of decent size (yours fits this category), the shutoff and startup pressure points are adjustable. This is usually done using a pair of screws under a pretty accessible cover. The on/off switch usually goes through this cover and the smallest of the air lines will go here, too.
Run the compressor with this cover off and watch which set of contacts opens when it shuts itself off. The screw that adjusts how resistant these contacts are to opening is the one that determines at what pressure the unit will shut off.
Turn the screw 1/4 turn clockwise, bleed down the compressor enough for it to start back up, and note its pressure when it shuts off. This will help you determine that clockwise is the right direction, and roughly how much more to turn it to hit your target pressure.
One other thing to keep in mind. Many compressors have an adjustable outlet with a gauge. If you've got two gauges, it's likely one is for the outlet and the other for the tank. If you've got two gauges, make sure you're reading the right one. If you've got an outlet gauge you also have some kind of easy to use control for adjusting it without taking any covers off.
If this doesn't help, some clarification would help, specifically the make and model of compressor.
On the teflon tape, I see it applied the wrong direction frequently. Not saying this is the cause of your problem, but seems a handy place to mention it.
When looking at the business end of whatever male fitting is getting the tape (business end being the part that meets the fitting first), wind the tape CLOCKWISE. This way, when you install the fitting, the friction from the threads is trying to tighten rather than unravel your tape.
The thread keeps coming off the thread take-up lever.
This happens on some machines. I just put a tiny piece of tape (double the tape in the process so the sticky sides stick together) over the opening in the take-up lever to keep it from jumping out. You may be able to use something else like a tiny washer, but this will work in the meantime.
Nov 23, 2016 | Sewing Machines
Tsurumi pumps parts breakdown
In order to create a good seal for these plastic fittings you can apply Teflon tape to the threads.
http://www.freshwatersystems.com/p-4968-dmfit-teflon-tape-12-w-x-60-l-4-density.aspx
Jun 04, 2013 | Plumbing
My G4 barracuda's diaphram assembly has started to unwind from the cleaner head when it is operating. I have had this particular model for three years and have never had this problem.
Keep in mind that they are made of plastic and the threads change shape over the years.. Try applying several wraps of Teflon tape on the cassette threads and re tighten. This should keep from unwinding... Good luck and hope this helps you... If helpful, please take the time to write a comment and rate,,
Sep 01, 2011 | Zodiac Baracuda G4 Automatic Pool Cleaner...
I have a central pneumatic compressor 21gal 2hp a couple years old the unit runs but will only pump up to 75psi and keeps running and does not build more pressure.It was building up to 110psi and then it...
Its the pressure regulator, if you discharge the air and can set the regulator to a lower psi, and it pumps
to that psi. you will have to replace that part, make sure to have make, model , serial# of compressor
so that the correct part can be fittted to you compressor. good luck!
Jul 31, 2011 | Air Tools & Compressors
When the compressor fills the tank up then shuts off, there is a air leak. When it goes below the amount, the pump starts up but sounds like it struggling. Then I need to manually bleed the air, then...
First locate leak with a spray bottle filled with soapy water.Use Teflon tape on the threads so it will seal.Check all fittings.If there is water you need to drain it or blow it out.
May 07, 2011 | Porter Cable C2002 Wk Oil Free Umc Pancake...
How do i stop my mr. heater from leaking fuel @ the drain plug? I have put a new drain plug in with rubber oring but it doesnt solve my problem.
Hi, try wrapping some plumbers tape around the threads, use about 4 to 5 wraps. This will stop the leak. Wrap the white tape the same direction the threads go, or the tape will come right off when you tighten it. You will no when you try it.If the fitting screws in cw, wrap the tape on the fitting ccw.
Shastalaker7
Mar 28, 2011 | Mr. Heater MH125KT Utility
Temperature gauge not registering on dashboard
is this a gt or ? change your water temp sending unit (not much info from you) buy the sending unit and replace it should be near where the top rad hose where it connectes to thurmostat housing. drain some antifreeze before removing sending unit use tefflon tape to prevent any leaks do not over tighten it's aluminum good luck CJ
May 20, 2010 | 1989 Ford Mustang
Need to replace drain valve
The "welded nut" is the pipe fitting into which the drain valve or drain plug is screwed. It's usually brass and the valve or plug can be obtained through Sears or possibly and good harwarde store. Be sure to use pipe sealing compound or teflon tape on the threads when you re-install the valve or plug.
NOTE - THE AIR MUST BE DRAINED FROM THE TANK BEFORE REMOVING THE VALVE OR PLUG. ALSO, POWER SHOULD BE DISCONNECTED FROM THE COMPRESSOR!
Mar 04, 2009 | Craftsman Air Tools & Compressors
I have an Intertherm waterheater in my park model trailer. It is less than a year old, and leaks around the drain valve. (I think) How do I get the valve off, is it just threaded on?
Yes and most likely it is a cheap plastic valve. You will need to turn off the water to the heater and drain it completely. Pick up a new Brass valve at your local Lowes or Home Depot and wrap 5 windings of Teflon Tape on the threads of the new valve. When wrapping the tape on, hold the valve so the threads are up and start wrapping the tape Clockwise. If you do it the wrong direction the tape will peel off when threading it in the heater.
Jul 30, 2008 | Intertherm Heating & Cooling
Chicago Pneumatic  1/4" Air Screwdriver Logo
Top Chicago Pneumatic Air Tools & Compressors Experts
John Trevino
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Chicago Pneumatic Air Tool and Compressor Expert? Answer questions, earn points and help others
