Question about Toshiba MD20F51 20 in. TV/DVD Combo
Tv turns off after 30 sec. - 2min.
It just loses power...have tried unplugging to reset to no avail...appreciate any info before I crack it open :).
    President:
  • 1,099 Answers
If you can turn it back on with the s momentary key or power button:
When it shuts off, do you need to push the power button once or twice to get it back on? Also, does anything else about the picture or sound change as it warms up?
If once, then the controller is shutting the TV down either as a result of a (thermally induced) fault in the controller or it sensing some other problem. Monitoring the voltage on the relay coil (assuming these is one) could help determine what is happening. The controller thinks it is in charge.
If twice, then the power supply is shutting down as the controller still thinks it is on and you are resetting it. A couple of possibilities here would be low voltage or high voltage regulation error (excessive high voltage is sensed and causes shutdown to prevent dangerous X-ray emission). A partially dried up main filter capacitor could also cause a shutdown but there might be other symptoms like hum bars in the picture just before this happened. Clipping a good capacitor across the suspect (with power off!) would confirm or eliminate this possibility.
If it uses a pull-knob (or other hard on/off switch), then this may be like pulling the plug and would reset any abnormal condition.
Posted on Jun 01, 2010
I have a Sharp LC-42D62U AQUOS TV. As a result of my grandchildren pushing buttons, inputs 1 and 2 are no longer available. We have followed every proceure in the operation manual to correct the problem to...
Resetting the TV
If the buttons on the remote AND the buttons on the TV case do not work (channels do not change and you cannot open or navigate the menu), the TV has stopped responding. Reset the TV as follows:
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 27, 2008 | Televison & Video
I need to access my NetgearN150 from a command prompt as the GUI is not working can someone tell me if there are telnet or ssh commands available for this unit? The following lists the systems I am...
I think if you're using stock firmware you might be out of luck using ssh.
Still try telnet. (telnet IP address) if it was enabled before on the router (disabled by default.) If you have Win 7 you have to enable telnet in "Programs and Features/Turn Windows features on or off".
Find more info here.
Anyways - I would first try a 30-30-30 reset.
  1. Hold reset button for 30 sec.
  2. pull power whilst holding the reset button for another 30 sec.
  3. plug in power and keep the reset button holding for an additional 30 sec.
Let me know how that goes.
Aug 13, 2013 | NetGear Computers & Internet
I have a mitsubishi wd-62525 the power light keeps blinking, and i can't get picture. i unpluge it than want 2min than it stop blinking and i can turn to tv on and get a picture than after 30-40mi
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 06, 2012 | Mitsubishi WD-62525 62" Rear Projection...
Forgot my password I cant watch any channels
The easiest way is to reset the TV. There are 3 possible resets for this TV. press and hold Action and Power on the TV until self check appears-- then unplug the TV wait for 30 sec. then plug back in. The reset should take care of any channel lock/ game guard settings
Also Volume down on unit and sleep on remote. Same process wait for self check then unplug for 30 sec. plug back in and turn on.
Last Volume down on the unit and RH-Split on the remote-- same process
hope this will be helpfull. Please rates me . Goodluck...................
Feb 03, 2011 | Panasonic TCL42U25 42 in HD-Ready LCD TV
Why does your PANASONIC tv ask for a password?
or
Panasonic sets need to be reset to clear the v-chip settings. To do this, put it in standby mode, then press the POWER and ACTION buttons at the same time and then turn the power off. The set should reset to the factory defaults, and reset the v-chip
Dec 30, 2010 | Panasonic (TH-50PZ700U) Television
Wii shows up as "no signal" on T.V. It worked fine until I turned the wii off. All connections are fine.
Sounds to me like its a issue with the TV accidently being put on the wrong AV settings. Double check to make sure your on the right settings for instance av1 on your cables and av1 on the tv settings through the menu or remote control options. If that isnt the issue try it on another tv just to be sure it still isnt a tv component.
You can also double check to make sure nothing is lose or backwards getting one of the colors in the wrong position (we all have done it hehe).
Also try unplugging the wii, all together and unplug the power cord from the unit and from the wall leave it unplugged for 2min minimum and this will do a soft reset on the unit. Nintendo taught me that one hehe.
Apr 27, 2010 | Nintendo Wii Console
We were watching our 42LG50 the other day and it shut off and now wont turn back on I called an lg tech but they werent interested in helping since it is 4 month out of warranty. Do you have any reset...
not going to be an reset but you can try ... the reset on LG is unplug the tv power hold down the power button for 30sec's while still holding the power plug in the TV and hold for another 20 to 30 sec's then try and turn it on.
if i remeber right the LG50 is an LCD you will more then likely need eather the power board or the main board ...no way to know with out opening it and testing afew things (helps to be LG trained also :)
good luck
Feb 15, 2010 | LG 42LG50 42 in. LCD HDTV
Will not power up. Stays in standby mode.
these particular tvs are very sensitive to voltage changes spikes etc.first turn off main power switch wait at least 30 sec if standby come on wait another 30 then turn off main power again and unplug tv for 1 min then plug in turn on main switch wait 30 sec then turn on tv with remote resets system.then buy a ups and always wait at least 30 min after turning tv off to turn back on if not causes power failure and after each press of power button wait 30 seconds before trying again lmk good luck
Jan 08, 2010 | Hitachi 42HDS69 42 in. Plasma Television
Helpme please
Resetting the TV
NOTE:
7. Turn on the TV.
hope this may help;
Regards,
VOTIT
Aug 25, 2008 | Philips 150S4FB 15" LCD Monitor
Toshiba MD20F51 20 in. TV/DVD Combo Logo
96 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
