Question about Amana ABB1927DE Bottom Freezer Refrigerator
Refrigerator is warm
The freezer and ice maker area (below is cold)
    Guru:
  • 1,524 Answers
Sounds like a defrost problem.
Posted on Jun 01, 2010
My refrigerator part isnt working but freezer part is cold..
Posted on May 04, 2011
Samsung_rf267 stopped making ice and it feels warm inside the ice maker area. Does this mean it is the refrigerator or could it just be the ice maker.
the ice maker is not integrated, it is just an addition like an ice cube tray. duh?
is your freezer cold? or warm?
sounds like a valve or timer issue. if you dont know about that you NEED TO CALL A PROFESSIONAL
Dec 30, 2014 | Refrigerators
Why is Refrigerator warm, Freezer is cold
This seems to be a common problem with bottom freezers.
Usually there is ice buildup in the cold air passage from the freezer to the refrigerator. There are videos on Youtube that will help.
Link below.
bottom freezer refrigerator not cooling YouTube
Jul 31, 2014 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Kenmore classic bottom freezer refrigeration warm but freezer is cold
I would guess you have just caused a build up of ice to block the air way, which normally takes cold air into the fridge. manually defrost (unplug and wait until the ice goes away) then restart and it should be fine
Nov 11, 2013 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Our Whirlpool refrigerator model ED5SHAXMB10 is keeping our freezer food cold, yet no cold air is being blown into the refrigerator. Refrigerator is getting very warm. What can be done to fix it?
The defrost is not taking place on time or the defrost ventilation door is stuck closed.Its controlled by motor,that motor is got faulty.
Replacement parts can be purchased at any of the following web sites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
partsselect.com
Before going to buy any parts directly.
Go through this troubleshooting help links.
This is list of refrigerator problems, which is normally faced in refrigerator.
You can go through the details, by clicking the link below:---
Refrigerator is not cooling properly?
http://technoanswers.blogspot.com/2011/06/refrigerator-is-not-cooling-properly.html
Both refrigerator and freezer not cooling properly in refrigerator?
http://technoanswers.blogspot.com/2011/06/both-refrigerator-and-freezer-not.html
The ice maker not working: ---
http://technoanswers.blogspot.com/2011/06/ice-maker-stopped-working.html
Compressor not running on refrigerator?
http://technoanswers.blogspot.com/2011/10/compressor-not-running-on-refrigerator.html
Water dispenser not working on refrigerator?
http://technoanswers.blogspot.com/2011/10/water-dispenser-not-working-on_19.html
Ice maker stopped making ice?
http://alltypesofpartsreplacing.blogspot.com/2011/10/ice-maker-stopped-making-ice.html
Water Overflows in Ice maker and freezes inside?
http://alltypesofpartsreplacing.blogspot.com/2011/10/water-overflows-in-ice-maker-and.html
How to replace Ice maker assembly?
http://alltypesofpartsreplacing.blogspot.com/2011/10/how-to-replace-ice-maker-assembly.html
These will help.
Thanks,.
Dec 23, 2012 | Refrigerators
Water do not get cold it stay room temperture and stay warm.
Its faulty compressor if freezer section is also not cooling.
But if freezer section is working fine,then problem is confirm defrost assembly.
repairclinic.com
partsselect.com
These will help.
Thanks,.
Freezer is very cold but fridge area is warm. what is up.
Sometimes the defrost drain pan stops up. Instead of the water goin outside is pools up between the compartments. This forms a slab of ice and blocks the air flow from freezer to fresh food. Of course the other thing that comes to mind is the freezer fan could have quit or stopped due to an ice buildup.
If you need further help, reach me via phone at https://www.6ya.com/expert/dan_73bbd84fe1d95b61
Feb 13, 2011 | Whirlpool 21.0 cu. ft. Top Freezer...
Bottom of fridge and freezer cold ice maker not
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing then check out thelast two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Nov 28, 2010 | Whirlpool 25.6 cu. ft. Side-by-Side...
Freezer builds up with frost about every 60-75 days. have to empty the freezer and allow to thaw for a few hours
I think I can assume the freezer isn't a "frost-free".
A short physics lesson; hot air holds more moisture than cold air; hot air will flow from a warm area to a colder area, and the colder area will cause the moisture to condensate and freeze(if colder area below freezing, as a freezer should be), causing frost build up.The more often the freezer is opened, the more frost will build up.
Now for 3 possibilities:1) If it is a self-defrosting type, check your defrost timer control...not working, or not working often enough.2) Door seals damaged and need replacement.3)Make the kids stay out of freezer.
Mar 07, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Freezer on bottom cold but frig is warm
Just additional clues..(general). The defrost timers (on non-electronic) usually located at the bottom (underneath), have a tendency to fail. (One of mine is in the center, one was on the left side) There are usually about 5 wires connected to it. If it fails while defrosting.. the fridge will warm quickly and stop cooling, if it fails in cooling mode, you will have the icing up problem. (other) A squealing noise is usually a fan motor. -also- (Freon issues)..as freon is lost from a small leak, first the freezer will actually get colder, but the refrigerator section may be too warm (I know it sound stupid). When enough is lost the compressor will get hot and the fridge will not cool.
Jan 02, 2008 | Amana ARB8057CSL Bottom Freezer...
Kenmore refrig not making ice and top shelf area in refrig not cold
if you are having tempurature issues make sure the fan in the freezer is operating. it should be on when the compresor is running. this may explain both warm fridge and no ice.
Sep 10, 2007 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Amana ABB1927DE Bottom Freezer Refrigerator Logo
459 people viewed this question
Top Amana Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Sal De
Are you an Amana Refrigerator Expert? Answer questions, earn points and help others
