Auto sensing water level
Will not auto sense water level and over fills.
error code 12 or 21 wife cant remember!
I am thinking there is a dirty senser or something
any ideas ?
wagdom
  • 64 Answers
SOURCE: Unable to control water level
Some water may have got into the pressure switch. Remove the pressure switch and see if you can shake any water out. Make sure the cables go back on the correct terminals. make sure the tub is empty when you refit the pressure switch, so no water is allowed to enter the pressure tube
Posted on Oct 29, 2007
SOURCE: Fisher&Paykel Intuitive eco IWL 16 Auto washer Fault code 51
Our washer did the same but it was after I took the excess drain hose and pushed it into the drain in the wall. I thought it looked "more tidy" In doing so I created a siphon effect. Once I pulled the excess hose back out it was fine.
Posted on Feb 14, 2009
  • 2468 Answers
SOURCE: whirlpool thin twin ylte6234dq2 washer/dryer water overflow!
first access the tech sheet and run any diagnostics it shows for the machine and if this passes,then check/change the fill switch on the control panel along with fill tube from the wash tub base if kinked or plugged
Posted on May 10, 2010
SOURCE: Fisher and Paykel MW058U won't fill
Fault is out of balance switch stuck on i removed and cleaned mine with crc but if still stuck on may need replacing hope this solves your problem
Posted on Oct 17, 2010
  • 1891 Answers
SOURCE: I have a Kenmore 800
this could be a pressure sw . too ck remove the air tube and blow on the sw it should click . or use a ohm meter to ck it it has 3 wires going to is power in ond power out to valve when it gets full of water it shuts of water and turns on motor .. . the spin does not have anything to with fill & wash . but it does help for the diag of mach ( thanks ) hope this has helped mm feed back pls ..
Posted on Nov 08, 2010
Can you tell me what error code E12 is on a Bosch vision 300 washer?
I am not quit sure if my answer will help you, but I am going to tell you the cycle
The unit fills to whatever water level you choose to use
After reaching the water level the the wash begins, after 20 or 30 minutes of washing it needs to drain the soapy water. The drain pump turn on draining the water, after draining the unit fill back up to the settings and or sprays water while doing the draining and spinning to remove as much dirty water as possible from the first wash. After the first draining, fills back up again for the final rinse and the final drain
The symptom you are describing, here tell me, that issue is with the drain valve, drain hose, the sewer, or is a big possibility that there is is a sock or woman garment stuck in inside holding the rotor causing the water not drain inside the water valve, if the sensors are not sensing the opening of the pressure switch after the first fill. it will not continue This units lately has been added many sensors the only thing this unit doesn't has is the ability to speak but if using common sense you can get to the part that needs to be replace. You need to read and understand the wash cycle first.
Nov 24, 2017 | Bosch Washing Machines
How do I increase water level in my wfxd8400uc?
I get this complaint a lot from home owners , I take it you have just got your first front loader washer , and you don't think it adds enough water to wash anything , this is the water saving feature of front loaders
but a simple test I tell most folks to do if they think there water level sensor is not working right
set washer to auto load sense on water level , normal wash cold water, permapress add nothing to drum completely empty! no soap unless you have a auto soap dispenser then it wont start to you add some and close door
start cycle wait till fill is complete just as it goes to agitate stop cycle (plug can be pulled for this if buttons have locked out )and open door see if water level is two fingers wigth under door seal , if its close your ok if it's a long way off then contact a repair department to look at auto sense water level
May 07, 2015 | Washing Machines
Whirlpool gas dryer (WGD9450WR1) not drying on auto-cycles
try cleaning the 2 silver senser bars located inside the dryer drum on the door side with isopropyl alcohol and lint free wipes,these bars sense moisture and control timer speed,and when they get coated with the chemicals in dryer sheets they become coated and can no longer sense the damp clothes (these sensers use capacitance to sense moisture)
Feb 18, 2012 | Dryers
Whirlpool washer WTW57ESVW agitates right away (doesn't fill first)...any ideas?
My wife had the same problem and it had one other problem where it added water at the end of the spin cycle which left the washed clothes all wet. After doing some research on the internet I narrowed down the problem to two parts, auto-sensing switch or timer control. I called Whirlpool (800-253-1301) and ordered an auto-sensing switch (part# W10292584 which is replacement of W10177795 which is discontinued) and a timer control (part# W10177827) for $26.30 total at 75% off, plus $8.99 Fedex shipping and $2.12 PA sales tax for a grand total of $37.41. The original part costs were $65.62 and $39.60 respectively. I took the control panel off following the video from http://www.youtube.com/watch?v=9QELKlLEZeI and first tried the replacement timer and it made no difference, i.e. it still agitated immediately while filling and it filled at the end of spin cycle but only on the normal wash cycle which is on the top half. The agitation problem exists on all wash cycles except for the handwash option, but the filling problem at the end of spin cycle existed only for the normal wash cycle and not on any of the other 3 wash cycles. Then, I put the old timer back on and tried the replacement auto-sensing switch and that fixed the problem. I should have known that was the problem because when I was ordering the parts on the phone, the woman from Whirlpool told me they had over two thousand of the auto-sensing switches in stock and when I heard that I was thinking to myself "I don't know how many of these washers they sold, but that part must break a lot to keep that many in stock." I don't know how long ago the original auto-sensing parts were initially manufactured, but the Whirlpool parts website says that it's discontinued, so that only leads me to believe the original part wasn't very reliable to begin with. I called several local appliance repair folks and just to diagnose the problem, it was going to cost me anywhere from $75 to $100, so it was more cost effective for me to just buy the parts and tried them myself even though I ended up with a spare part (timer control) I didn't need.
Oct 07, 2010 | Whirlpool Washing Machines
Soap left in clothes
Is the machine a FAV6800A or FAV9800A? Do you take the “Sd” error code for high level of suds? If we are talking about a FAV6800A or FAV99800A and the series is 12 or more you have a 2 level sensing pressure switch. This will give you about 3.5” for mid fill and 7” for high fill. I have only seen the Bulky wash cycle fill to High level fill.
Are you using HE detergent and the amounts called for in Use & Care section of the FAV6800A/FAV9800A Service Manual ?
If you have a series 10 thru 12 FAV6800A you will have 3 Level pressures switch sensing. Disregard the Low Fill setting IMOP it doesn’t put enough water in the machine for adequate wash. I believe that is why Maytag did away with it and went to 2 level sensing pressure switch in later series…………Rich
Jul 03, 2010 | Maytag Neptune FAV6800AW Top Load Washer
Model 601V2 dishdraw showing U3 error message
I have had my Fisher Paykel dishdrawer for 8 years and it has never completely worked. I would get a U3 code on the top drawer intermittently. I have had my drains rerouted twice, LP - HP reset, service men replace the back flow flap and mother boards without luck... until I was able to get my hands on the service manual. Turns out the solution is quite easy. If you have a problem with the U3 code it means the drawer is not draining appropriately, The washer only gives a preprogrammed 60 sec to drain the drawer. So if your drawer is overfilled, it will think it has a drain problem. The following is taken from the service manual...
"U3 - Time to fill was too short, indicating water was still in the tub.
Possible Causes:
· Drain pump is blocked.
· Drain hose is blocked.
· Sprayarm or rotor not turning
freely.
· Motor electronics have failed.
· Machine set to 'LP' on a high
pressure water supply.
The tub fills with approximately 2.2 litres of water, level with the base of the spray arm attachment. Once this level is reached, the wash pump (which has sensed the fill at 30 second intervals during the fill), becomes primed and pumps the water through the spray arm which will then rotate.
The water level is monitored by sensing the motor load through the electronics."
The solution is to turn your water supply valve part of the way on to limit the gpm flow to the drawer. This way, the drawer will not have over-filled in the 30 sec it took to sense the motor load. I have tried it and wow no more U3. Hope it makes sense and hope it works for you.
jim
Jul 13, 2008 | Fisher and Paykel 24 in. DD-602 Built-in...
Error codes
Hello ALARM CODES Alarm code Description of fault User code Effect E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2 E12 Problems with water fill in drying E10 Cycle PAUSED 8.3 E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4 E22 Problems with water drain during drying or drying condenser blocked E20 Heating phase skipped 8.5 E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked with door closed 8.6 E32 Incorrect calibration of analogic (electronic) pressure switch --- Cycle PAUSED 8.7 E33 Incongruency between level of analogic (electronic) pressure switch and level of anti-boiling pressure switch 1 --- Cycle blocked with door closed 8.8 E34 Incongruency between level of electronic pressure switch and level of anti-boiling pressure switch 2 --- Cycle blocked with door closed 8.9 E35 Water level too high --- Cycle blocked with door closed and water drain 8.10 E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked with door closed 8.11 E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked with door closed 8.11 E38 Pressure chamber blocked --- Heating phase skipped 8.12 E41 Door open E40 Cycle PAUSED 8.13-14 E42 Problems with door closure E40 Cycle PAUSED 8.15-16 E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18 E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19 E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked with door closed 8.19 E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door closed (after 5 attempts) 8.20 E52 No signal from tachometric generator --- Cycle blocked with door closed (after 5 attempts) 8.21-22 E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked with door closed 8.23 E54 Relays (motor) contacts faulty --- Cycle blocked with door closed (after 5 attempts) 8.23 E61 Insufficient heating during washing --- Heating phase skipped 8.24 E62 Overheating during washing --- Drain, end of cycle 8.25 E63 Insufficient heating during drying Heating phase skipped 8.26 E64 Overheating during drying --- Heating phase skipped 8.27 E66 Power relay to heating element faulty --- Drain, end of cycle 8.28 E71 NTC wash sensor faulty --- Heating phase skipped 8.29 E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30 E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31 E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle (door open) 8.32 E85 Circulation pump faulty --- Drain, end of cycle (door open) 8.33 E91 Communications error between main PCB and user interface --- --- 8.34 E93 Configuration error E90 Cycle blocked 8.34 E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34 EF1 Drain filter blocked LED-EF0 --- 8.35 EF2 Excessive detergent LED-EF0 --- 8.35 Regards David Marsh
May 06, 2007 | Zanussi ZWD1470W Front Load Washer / Dryer
Washing Machines Logo
95 people viewed this question
Top Washing Machines Experts
