ILO I have power to the TV. But it will not turn on. the light flashes fron green right back to red, and will not turn on. Pete
  • Anonymous Jun 19, 2008
    my ilo 32inch sdtv will not turn on. no light come on.
  • Anonymous Feb 05, 2009
    Has anyone been able to solve thi problem yet? I am certain others have not waited nearly a year for repairs and troubleshooting tips.
It very simple if you know how, it,s all in what buttons to press at the same time, to reset it.
thank you.
Posted on Apr 13, 2008
SOURCE:
Will not power on led flashing red and now no led
Reset your TV. Unplug your iLO TV from the wall and remove any connected devices. Hold the front power button in for five seconds, then release. Plug your TV back in, turn it on and confirm that it is working again.
Read more: http://www.ehow.com/how_5458819_troubleshoot-ilo-tv.html#ixzz2tRuiKHvE
Jan 21, 2014 | iLO LCT32HA36 Television
Ilo LCT32HA32 tv wont turn on, no red standby light
It could be the power or main board that is giving issues...if your able pull the back off and look for a pin on connector marked PSON or PON...that is line that tells the power board to come out of sleeping and go to work, you should see a change in the voltage when the on button is pushed, if you do then the main is doing its work and its the main if you don't see a voltage change then chances are its the power board
Dec 14, 2017 | iLO LCT32HA36 Television
My ilo rc-370c wont turn on.the red light just blinks????????
If you get a flash on the red light when you try to turn it on and hear a popping noise. Unplug it then use a hair dryer to heat the inverter up on the right side (power button side) of the tv (up through the vents in the back for 10-15 mins). Plug it back in and turn on.
Apr 05, 2010 | iLO 3200 32 in. LCD Television
Power green light will flash then flash red when first turned on
Please intimate exact model of your Sony TV to find out reason of no power up.
Jul 09, 2009 | Sony Grand WEGA KF50WE610 50" Rear...
Ilo 27 inch tv
I too have the same problem. We've had the ilo27 for almost 2 years and it suddenly decided to not turn on anymore. Red light-itus.
I did find a little trick if you are not so mechanical like me and don't want to risk opening the back. I know this isn't a cure, but you CAN get around this by simply pulling the plug from the wall and plugging it back in. It comes on with remote or manually every time!!!
A little inconvenient, but a way around it temporarily!
Oct 13, 2008 | iLO V27DMBX Television
Ilo 27" lcd tv
If your LCD has a defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Apr 29, 2008 | iLO LCT32HA36 Television
Junk tv
My ilo 27" tv did the same thing (red light on front but would not turn on) and after much frustration looking around on the net I finaly cracked it open. After removing enough screws to remove the back the first thing I saw was the main power board. This board has quite a few capacitors on it and I found 4 of these that had bulging tops. 3 were 1000uf/16volt and 1 was 470uf/16volt. I disconnected all wire connectors from this board and replaced them with parts from radio shack PN 272-1032 and 272-1030. The voltage rating of these are different but ok if larger than the original part. It fired right up when I put it all put back together
Apr 02, 2008 | iLO V27DMBX Television
Toshiba TP50H95 TV Won't turn on - Pete
You will need to trouble shoot the start up and shutdown circuits. Often this is a minor component failing causing the set to not power up or go into protective shutdown. Do you have the service manual for this TV?
Mar 01, 2008 | Toshiba TP50H95 50" Rear Projection...
Televison & Video Logo
Top Televison & Video Experts
Ekse
