Question about HP Pavilion dv4000 Notebook
Need to remove key board for cleaning. I can't figure out how to remove the screen and keyboard cover
    President:
  • 1,335 Answers
The service manual for your dv4000 can be downloaded from
http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=468789&
This manual will give you the screw by screw disassembly and assembly of your laptop to service the keyboard.
Please rate this solution. Thanks.
Posted on Jun 01, 2010
    President:
  • 3,085 Answers
My volume control keeps popping on and off my screen when i use my Logitech key board cover
Have you popped off the volume control key and cleaned out any debris? It's possible the key is partially depressed and the cover is finalizing the press.
Feb 22, 2015 | Logitech Computers & Internet
How to activate malfunction keyboard of Letter D?
If both the upper and lower case don't work you have a keyboard problem. If one works you need a print wheel.
DickyO
Oct 23, 2013 | Brother GX-6750 Typewriter
Black screen delld600
Several things can cause your Dell Latittude D600 laptop's LCD screen to stop working.
Two of the most common causes relate directly to the inverter board and the backlight lamp.
The inverter board is a thin circuit board placed inside the LCD panel.
It's main function is to transfer power from the motherboard to the backlight bulb inside the LCD screen.
If the inverter board goes bad or the backlight lamp burns out, the screen will appear dim or eventually go completely black.
Turn off the laptop, unplug the power cable, close the LCD panel and place the laptop face down.
Remove the battery pack from its compartment on the bottom of the computer.
Flip the laptop back over and reopen the display panel all the way until it is in a 180-degree position.
Insert a flat head screwdriver into the right side of the keyboard bezel.
This is the plastic strip situated above the top row of keyboard keys. Carefully pry the bezel from the laptop.
Remove the two Phillips screws located above the top row of keyboard keys.
Grasp the top edge of the keyboard, tilt it upward and lay the keyboard face down on the palm rest area.
Unplug the keyboard's ribbon cable from the motherboard connector.
Carefully remove the entire keyboard from the laptop.
Disconnect the video and speaker cables extending from either side of the LCD panel to the motherboard.
Loosen the Phillips head screws on each LCD panel hinge.
Carefully lift the entire LCD panel off the laptop's base.
Relocate the panel to a flat work surface, and place the panel so the screen is facing upward.
Use a thin, flat head screwdriver to pry the rubber screw covers from the LCD panel's front plastic cover.
Remove the Phillips head screws revealed by the rubber covers.
Carefully remove the front plastic cover from the display panel.
Locate the inverter board situated below the LCD screen, inside the bottom edge of the display panel.
Disconnect the two cables from each end of the inverter.
Remove the two Phillips head screws fastening the inverter to the display panel.
Carefully lift the inverter board out of the display panel, and dispose of it.
Repeat this procedure in reverse to install the new inverter board, and reassemble the laptop.
Hope this helps
Oct 23, 2012 | Dell Latitude D600 Notebook
I need to R&R the keyboard. How do I remove the cover safely? Thankyou Bernice
It is virtually impossible to fix because you cannot get to the rubber contacts in the keyboard. The best solution is to replace the keyboard.
You maybe able to get a replacement keyboard from this WEB site.
Keyboard replacement, LCD screens for mobile phones, Ipodsand computer equipment.http://www.yallstore.com/index.php?main_page=advanced_search_result&search_in_description=1&zenid=1lrjst3ncshlb4c7frn9bev3c3&keyword=keyboards
Jul 24, 2012 | Computers & Internet
How do I strip key board on my laptop to clean spilt coffee
http://www.laptop-repair.info/laptop_keyboard_repair.html
the steps to remove the keyboard is to remove the hinges cover first ..than the screws holding the keyboard in place (under the hinges cover) ..than slide it an inch forward (toward the screen ) ..and after that lift it up ...remove the ribbon from the plug ...and this is all ..replace it if you have the possibility ..or ..remove all buttons ...and clean it up ...and dry it well before replace it and see if it work s..If the damage is permanent you need a new one and the procedure is just the reverse..
http://www.youtube.com/watch?v=_IN1RKtiFC8
Nov 29, 2011 | Samsung R519-53S Notebook
The b key strikes to hard, so there is any touch resopnce on the middle B key, what can i do to fix if?
You will have to clean the keyboard touch pads. its a pain full job because one has to remove at least 50 screws before one gets access to the key pads. Remove the back cover and make a note of what screws goes ware.Then remove the screws that hold a long circuit board over the keyboard ( lots of small screws ) . Invert this board and clean the black carbon tracks as well as the rubber key pads with solutions like WD40. Install it back in the reverse order making sure you put all the right screws in the right place. Should work fine after that until dust again gets in between.
Sep 26, 2011 | Yamaha Mm6 Synthesizer Keyboard...
Remove Keyboard Acer 6292 TravelMate
Tilak, try to remove the cover above the key board and just below the lcd screen, though it will look like it cannot be removed but it can be, below that you will find few screw which hold keyboard with the rest of system n you are at ur place, now do it urself.
Apr 15, 2010 | Acer 91.63X07.001 Keyboard
Some of the keys don't work. I've tried the solutions suggested so far with no luck
I would remove the keyboard from the laptop, clean the keyboard and the flex cable that goes to the computer, make sure its clean and reconnect it, then try it again.
To remove a keyboard it varies from laptop to laptop, take it to a local professional if you can't figure it out, it involves unscrewing 2-6 screws and possibly removing the plastic keyboard cover from the top of the keyboard which is between the display.
Sep 10, 2009 | Advent 4211c Notebook
Keyboard not working properly
Suggestion for you it is not that hard to open the keyboard turn the key board up side down remove the all the screws and the bottom cover will pop up. have a acohol and swab just clean the keys contacts on the board I do this so many times and it work and save you money.
Nov 17, 2008 | HP TouchSmart IQ770 PC Desktop
Acer aspire 5610 keyboard replacement
1. you need to remove the power cover (if you see the power button, that what i mean).
2. after you remove that cover, you will see 2 screw that hold the keyboard. Remove both screws.
3. Remove keyboard and replace it with new keyboard.
May 07, 2008 | Acer Aspire 5610-4648 Notebook
HP Pavilion dv4000 Notebook Logo
164 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
