Question about IO Magic Corporation GigaBank (I250HD35) 250 GB USB 2.0 Hard Drive
Iomagic gigabank 250 will not show up on pc
I plugged the external drive into my laptop it said "new hardware found" and did the whole set up the said "your hardware is installed and ready to use" i went to "my computer" and it just isnt there. I tried ont a different computer and the same thing happened
  • 1 more comment
  • Anonymous Jul 03, 2008
    I pulg my external disk but it does not appear into the Windows environment. It just keep blinking but doesn't work, O tried at least in 5 PC's but is not working properly.
  • gavanman Nov 18, 2008
    My 320 isn't recognized by either of my Vista computers. Is it the OS or the Celeron processor?
  • squidracerX May 11, 2010
    My drive is new, never used. I know for a fact 100% that my USB works. 3 MP3 players and 2 thumb drives can't lie. But its still not reading my drive as there, and it seems liek it should be working. Everyone who seems to have a problem says they have a blinking light, mine is not blinking, and it shows up as "safetly remove hardware", just not in "my computer" as a drive. I tried that "my computer/computer management/disc management" thing Lolita said, and it seemed like it worked, but still nothing! Now under disc management it displays the three volumes of hard drives I had before (2 drives, 1 is partitioned). But down below has it listed as "disc 2" but it has a black bar on top and it says Unallocated and I cant do anything with it. It does read that its 298 Gigs though (why not 320?) The other 2 disc drives have blue bars above them. No idea what that means. So thanks, it ALMOST worked!
Let me add acouple things to Lolita's solution: This worked on a I/O Magic Gigabank 320. If the initialize wizard does not appear. Go to the left side of the window that should have popped up listing all of your drives. Right-click on top of the drive you are adding. There should be a red circle with a minus sign on it. Right-click there and select initialize. Now the initialize wizard should start. The drive gets hot. I'd keep it off and only start it when needed. This may make it last longer and help with power surges as well.
Posted on Sep 24, 2008
I have an I/O Magic Gigabank 320.
Here's what I did.
Right-click on My Computer
Click Manage
Then choose Disk Management in side pane.
You have to right click on the left side of the window that pops up. Right on top of where it lists the Drive you are adding. There should be a red circle with a white minus in it.
Right click and select initialize disk.
Now the initialize wizard will start working.
If you don't use the quick format it may take one hour. I'm not sure of the difference.
Remember this is a usb driven external hard drive. It appears to be a sealed case with no vents.
It gets hot. Use it like a thumb drive and turn off when not in use.
I suspect that if you do this it will last longer and avoid power surges.
  • 385 Answers
If the external hard drive is new, you have to follow these steps:
right-click on My Computer
click Manage
then choose Disk Management in side pane.
a disk initialization wizard should appear.
Get the new drive formatted now and it should be ready
when you open the My Computer.
Let me know if you have any problems.
Lolita
Posted on Apr 08, 2008
Hardrive light flashing iomagic 250gb
try disconnect your hard drive and then connect it again,start your cpu,if that don't work i thing your hdd is near end.....
Apr 06, 2010 | IO Magic Corporation GigaBank (I250HD35)...
I plug in my external hard drive and my pc will not read it. It shows up in the usb remove saftly as mass storage. I can not get to my data??
is the external HD formated ?
open My Computer and press F5 or click Refresh from the View option in menu...
check if u get a new drive letter....once u refresh...
Dec 14, 2009 | IO Magic Corporation GigaBank (I250HD35)...
GigaBank 250 GB USB 2.0 External hard Drive - How to open case ?
Remove the cover plate from behind the drive (where the plugs and on/off switch are.) You have to then remove the 2 screws. After that pull on the end with the blue lights to slide the hard drive out. If you have a tower computer, you can permanently install the hard drive and it should work fine as a secondary drive. Just make sure the jumper pins are set to "slave".
Mar 29, 2009 | IO Magic Corporation GigaBank (I250HD35)...
I/O Magic databank 250Gb External Drive
just installed 250g iomagic. getting runtime error when clicking on create vault- c:\programfiles(x86)\iomagic\databank\databank.exe any help would be great
Feb 22, 2009 | IO Magic Corporation GigaBank (I250HD35)...
Hard drive shuts off after 10 seconds
There are a variety of things that can malfunction on your external hard drive:
1) The cable
2) The external hard drive casing
3)  The hard drive itself
If you have tried plugging in your hard drive to different computers and are still having the same issue, then there is either a problem with your casing or with the hard drive itself, because you've already switched out cables.
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computerstore, and also available by going to our website at www.iomagic.com and clicking on Drive Enclosure.  Make sure to get the right size enclosure.  The GigaBank 320 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within your warranty period.
For specific warranty and replacement information, go to www.iomagic.com  and click on Support.
Have a nice day,
I/O Magic Technical Support
Sep 08, 2008 | IO Magic Corporation GigaBank (I250HD35)...
My computer will not read my io magic giga bank 6 gb
Was your computer ever able to recognize your GigaBank, or is it new?
The most common problem people have with a new drive not showing up in My Computer are:
1) The drive is not formatted
2) The drive letter is mapped incorrectly
You can check both of these things in Disk Management by right-clicking on My Computer and choosing Manage, then clicking on Disk Management on the left hand side.
If your drive doesn't show up in Disk Management, and you are also unable to see the drive on multiple computers, then you may be experiencing a hardware malfunction.
If you are still within your warranty period and you are experiencing a hardware malfunction, we will be happy to replace your unit for you. Specific warranty and replacement information is available at www.iomagic.com, by clicking on Support.
Have a nice day,
Aug 14, 2008 | IO Magic Corporation GigaBank (I250HD35)...
DRIVERS FOR IOMAGIC 250GB (WIN XP)
The I250HD35 is plug-and-play with Windows XP. That means that all of the drivers needed to run your hard drive are included in Windows.
If your computer is asking for drivers when you plug in your drive, one of two things is probably happening:
1) Windows XP doesn't know where to look for the right drivers
2) Your drive has malfunctioned
The easiest way to assess which of these is happening is to take your drive and plug it into another computer that is running Windows XP. If it is detected properly on the other machine, then your computer doesn't have the right drivers or is looking in the wrong place for them. If it doesn't, then I/O Magic will be happy to replace your drive if it is still within the warranty period
If it is detected properly on another Windows XP machine, then when it asks for drivers, make sure to point it to the WindowsINF directory. This is where the default drivers are located.
If your drive is not detected properly on the other computer, your drive is probably experiencing a hardware malfunction. Please visit the I/O Magic website at www.iomagic.com and click on Support for specific return information.
Have a nice day,
Aug 03, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Iomagic
Have you looked both in Device Manager and in Disk Management?
Have you tried plugging your external hard drive into another computer?
If it isn't recognized on multiple computers, then you are probably experiencing a hardware failure.
1) The USB cable - Have you tried switching the USB cable?
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available on our website.  Make sure to get the right size enclosure.  The I250HD35 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within the warranty period. For specific warranty and replacement information, go to www.iomagic.com and click on Support.
Have a nice day,
Jun 15, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Where
If your hard drive casing has malfunctioned, then retrieving your data is as simple as putting the hard drive inside another hard drive enclosure.  Hard drive enclosures are available at any local computer store, and also available by going to our website at www.iomagic.com and clicking on Drive Enclosure.  Make sure to get the right size enclosure.  The I250HD35 has a 3.5" Hard Drive inside it, which is a standard desktop hard drive.
If you put your hard drive in another enclosure and it still won't show up on any of your computers, then your best bet at retrieving your data is to contact a data recovery specialist.   After you have retrieved your data, we will replace your unit if you are still within your warranty period. For specific warranty and replacement information, go to www.iomagic.com and click on Support.
Have a nice day,
May 14, 2008 | IO Magic Corporation GigaBank (I250HD35)...
Magic usb hard drive
Just buy new external ( hdd is fine ) then pun that hdd in new external and everything will work fine
Feb 29, 2008 | IO Magic Corporation GigaBank (I250HD35)...
IO Magic Corporation GigaBank  (I250HD35) 250 GB USB 2.0 Hard Drive Logo
344 people viewed this question
Top IO Magic Corporation Computers & Internet Experts
David Payne
David Payne
Are you an IO Magic Corporation Computer and Internet Expert? Answer questions, earn points and help others
