Question about Whirlpool Duet GHW9150P Front Load Washer
The plastic boot has a rip in it. How difficult is
The plastic boot has a rip in it (the plastic around the inside door of the front loading washer) How difficult is it to change it?
  • 5,911 Answers
If you are referring to the door bellow (gray rubber seal), the following link explains how to access and replace one:
http://www.fixya.com/support/r3574186-installing_a_door_bellow_on_a_front_load
Replacement parts can be found at any of the following websites:
searspartsdirect.com
pcappliancerepair.com
appliancepartspros.com
repairclinic.com
All these sites are reputable, offer great service and have competitive pricing, so shop and compare. The first three sites also have helpful exploded view parts diagrams to assist you with locating and properly identifying the parts you may need.
Read through the link provided and if you have questions, please post back and let me know. I hope this helps you.
Posted on Jun 01, 2010
Front Load Washer won't start. Shows F and then dL.
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Sep 14, 2010 | Kenmore Elite 45986 Front Load Washer
My Kenmore Elite front load washer is displaying a dl then F codem
1. Unplug washer.
Jun 24, 2010 | Kenmore Elite 45986 Front Load Washer
Whirlpool duet front load washer F dl door lock how to fix
1. Unplug washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.%^&*
Jun 28, 2010 | Whirlpool Duet GHW9150P Front Load Washer
My kenmore front load washer won't start. It thinks the door is not locked
1. Unplug washer.
http://media.fotki.com/1_p,wkkrqtwwwgtsgwdxgtqsskgwtqkq,vi/krqsddwkbxktttdstrw/1/1303472/5961857/image48287img-or.jpg
Jul 09, 2010 | Kenmore 44102 Front Load Washer
Trying to start the wash cycle on my Whirlpool Duet front-load washer and "DL" and "F" keep alternating on the control. What do I do?
1. Unplug washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.@#$%
Jun 07, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Kenmore Front load He 3 I am getting a DL F error code. How do I fix it?
1. Unplug washer.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!
Feb 28, 2010 | Kenmore Elite 45986 Front Load Washer
What is FdL on a kenmore elite front loading quiet pak 2 h3 washer
1. Unplug washer.
Nov 11, 2009 | Kenmore 3.5 cu. ft. Front Load Electric...
Kenmore Elite HE3 front load washer door locking mechanism issue
1. Unplug washer.
Aug 07, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Front load washer leaks
It's not difficult to line up the boot around the door. The difficult part is taking out the tub (basket and plastic shell). Everything needs to be disconnected, and removed from the back, as well the tub is very heavy and best to do as a two person job.
If your washer is only 5 years old, it's kind of a 50/50. The cost (with labour) to fix the leak would come to approx $450 cdn.
Jan 30, 2009 | Kenmore 43142 Front Load Washer
KHWS01PWH0 Front Loading Automatic Washer Leaking
out the bottom of door?? no through the bottom panel???. check the rubber door seal for rips or tears pull it back and look around entire circumference. smalll rip in very front of seal where door should close against will cause leak for sure
Mar 07, 2008 | KitchenAid KHWS02RMT 3.7 Cu. Ft. Ensemble...
Whirlpool Duet GHW9150P Front Load Washer Logo
107 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
