Question about Emerson EWC19T3 19 in. TV/VCR/DVD Combo
Shut off comes back on by itself with no audio
    President:
  • 1,099 Answers
The power light may be flashing or if you are runing with a series light bulb it may be cycling on and off continuously. There may be a chirping or clicking sound from inside the set. (Note: using too small a series light bulb load during testing for the size of the TV may also result in this condition.)
If there is a low voltage regulator or separate switching supply, it could be cycling on and off if the horizontal output, flyback, or one of its secondary loads were defective.
Does this TV have a separate low voltage regulator and/or switching power supply or is it all part of the flyback circuit? For the following, I assume it is all in one (most common).
Some simple things to try first:
Verify that the main filter capacitor is doing its job. Excessive ripple on the rectified line voltage bus can cause various forms of shutdown behavior. An easy test is to jumper across the capacitor with one of at least equal voltage rating and similar capacitance (make connections with power off!).
Use a Variac, if possible, to bring up the input voltage slowly and see if the TV works at any point without shutting down. If it does, this could be an indication of X-ray protection circuit kicking in, though this will usually latch and keep the set shut off if excessive High voltage were detected.
Hope this works...
Posted on Jun 01, 2010
My kenwood dpx500bt shut off out of nowhere and won't come back on
It failed and shutdown to protact itself. Repair needed by a tech.
Nov 26, 2013 | Audio Players & Recorders
Yamaha sound bar YAS101BL periodically shuts off by itself
It has an auto sleep function. if no button is pressed after 12 hours it will automatically shut down. See http://faq.yamaha.com/us/en/article/audio-visual/digital-sound-projector/ats-1010/7727/6890
Mar 01, 2013 | Yamaha YAS101BL
Sony Bravia TV
If you get a blue screen at turn on and a short time later it shuts off--power supply is ok--set is shutting down as no signal detected to protect the screen.
If using a box first unplug it and wait and plug back--let box try to reboot itself.
Also as a test hook a DVD etc to a rear set of audio/video inputs and go to that input quickly when the set comes on (have DVD connected and on---see if set works that way.
No signal either a problem with the set or the signal source (box?).
Mar 31, 2012 | Televison & Video
MY sony kf50xbr800 tv will shut itself off for about 20 seconds and then come back on.While it is off the standby light will blink.What do you think?
If your tv set shuts off by itself at any time, sometimes earlier or sometimes longer, there mus be lost contact on the pins of the parts of your unit. Usually it occurs when the audio is loud. The vibrations will cause some of the pins to lost contact from the circuit causing the automatic voltage regulator to shut off, detecting the abnormal flow of currents and voltages in the circuit. Ask for a qualified serviceman to have it check and solder the pin or pins having a lost contact.
Oct 03, 2010 | Sony Grand WEGA KF50XBR800 50" Rear...
Help me
Either lamp or ballast(driver) bad, likely.
Apr 07, 2010 | Philips Magnavox 51MP392H Rear Projection...
Repeated off and on
speaks are hooked up wrong or speakers are blowin.
Apr 01, 2010 | JVC KD-SX980 CD Player
My Magnavox digital converter box shuts itself off every 5 minute
Check that you have not got an auto power off setting on. Check that the aerial connections are good. That the signal is strong from the stations it is picking up. Weak signals can cause the box to shut down.
It the box is very hot when it shuts down, you might have a fault on it.
Apr 04, 2017 | Philips Magnavox M61117 (DBM61117)
Pioneer VSX-D509S keeps shutting off
Aside from any intrinsic problem with your receiver, the usual suspects are;
1) Poor receiver ventilation. 2) Very high levels of bass. 3) Shorts in the speaker wiring. 4) A rubbing loudspeaker voice coil.
Sep 20, 2009 | Pioneer VSX-D509S Receiver
55" TV keeps shutting off automatically
Green light flashes 5 and then red light flashes 6
Sep 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Quits and comes back on
The reason it shuts off is because it's trying to stop itself from damaging itself further, which means it's probably already damaged, make sure you have sufficient grounding, make sure there is enough ventalation in the boot, make sure you're not running a 2 ohm sub to a 4ohm amplifier. Also check your wiring, check the Rcas and the REM wire.
Aug 02, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Emerson EWC19T3 19 in. TV/VCR/DVD Combo Logo
53 people viewed this question
Top Emerson Televison & Video Experts
matt martin
matt martin
 Grubhead
Grubhead
Are you an Emerson Televison and Video Expert? Answer questions, earn points and help others
