Question about Fisher and Paykel DD605SS Stainless Steel Dishwasher
Display f1 cant change out of this mode
Dishwasher in f1 blinking mode will not shut off or change mode
  • 523 Answers
There is a leak
Posted on Jun 01, 2010
F1 error. Loud noise and vibrating. I turned off my braker because the machine would not shut off. What do I need to do. Or is it better to call a tech.. What price am I looking at for the repair. Thanks
F1 error means flood switch at base of dishwasher under bottom drawer has been set off. This is due to water leakage.
Unsure why the vibration is occuring. Can you please confirm by adding some information in the comments field if the F1 is displayed on both drawers or just one and which one.
May 25, 2014 | Fisher and Paykel 23 in. DD-603 Built-in...
Eletronic oanel displays F1
The reason for F1 fault code in your dishwasher is due to the flood switch that has been activated in your unit. The best way to solve your problem is to turn off the water supply and power supply to your unit and call an authorized service center. These problems cant be fixed on your own.
Thank you !!
Jun 21, 2010 | Fisher and Paykel DS603SS Stainless Steel...
The code F1 keeps blinking and I can't shut it off.
f1 means u have a leak on your machine and the water has triggered the flood switch underneath the lower drawer. if u need more help please reply.
Apr 27, 2010 | Fisher and Paykel DD605HSS 23 in. Built-in...
Fisher & Paykel DD603 both drawers turn on and blink the code Fl. I turned it off at the breaker and cleaned it. let stand for 24 hrs and reconected still does same thing
It is not clear if the problem started suddenly or whether you have been doing some reconnection / renovation work and have reconnected the dishwashers.
F1 means the flood switch is activated, ie, the dishwasher is not able to control the inlet water.
This happening at the same time in both drawers is hard to understand. Have you tried shutting off and turning on the water supply? Is there any chance the water pressure has changed from the normal for your supply.- How to check what pressure your unit is set for is shown in the user guide - HP or LP. But I am not sure you can check that if the F1 display comes on.
You will need a technician to look at it if problem does not go away.
Nov 16, 2009 | Fisher and Paykel 24 in. DD603H W Built-in...
Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Fisher and Paykel 24 in. DD-602 Built-in Dishwasher Both drawers are flashing and beeping, displaying Answer Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If... (More) Both drawers are flashing and beeping, displaying the message F1 with a wrench symbol underneath. If turned off, they come back on after a few seconds,
Sep 23, 2009 | Fisher and Paykel 24 in. DD-602 Built-in...
My fisher paykel nautlis dishwaher display error code F1
What is the Model #? If both drawers, if a double, display F1 and won't shut-up then the flood switch is tripped and you have to unplug it to keep it from beeping and the drain motor running. The causes for the F1 fault can be numerous but not excluding bad lid lifts, broken link support, cracked drain line and wrong soap. Call F/P
Jul 19, 2009 | Fisher DS603W / DS603B / DS603I Dishwasher
Dishwasher "F1 and a small wrench symbol" blinks continuously
The unit has a leak causing floor sensor activated.
1- Unplug power cord.
2- Pull oull half way the drawer so an access from the bottom left could be obtained.
3- Use Paper towel or small towel to dry out the water on the bottom housing.
4- Wait for 48 hour so the sensor can be dry out.
Plug in the power cord. The unit will act as normal.
Your problem is solved.
However you can't operate since you know you have a leak problem. Let me know how it in progress and you decide to call service to fix it or I can guide you to fix it. Good luck.
Apr 05, 2009 | Fisher and Paykel 24 in. DS-603 Built-in...
My oven is beeping!
F1 Circuit board defective Replace control board
Good Luck and Please Rate Fixya!
Jan 07, 2009 | Electrolux Frigidaire Professional Series...
Setting the time
Setting Time
1 Press TITLE repeatedly until the time is displayed.
For details, see “Displaying the Text” (page 13)
2 Press and hold TITLE for at least 2 seconds while
The time indication will blink.
3 Turn the Rotary encoder to adjust the hours while
the time indication is blinking.
4 When the hour has been adjusted, press MODE.
5 Turn the Rotary encoder to adjust the minutes
while the time indication is blinking.
The time is automatically set 5 seconds after the minute
adjustment. The time can also be manually set by pressing TITLE.
• To synchronize the clock to another clock/watch or radio time
announcement, press and hold MODE for at least 2 seconds after
setting the “hour.” Minutes will reset to “00”. If the display shows
over “30” minutes when you do this, the time will advance one hour.
Listening to Radio
1 Press SOURCE/POWER until a radio frequency
appears on the display.
2 Press BAND repeatedly until the desired radio band
is displayed.
F1 (FM1) F2 (FM2) AM F1 (FM1)
3 Press TUNE to select the tuning mode.
DX SEEK (Distance mode) SEEK (Local mode)
OFF (Manual mode) DX SEEK
• The initial mode is Distance mode.
Distance mode:
Both strong and weak stations will be automatically tuned in
(Automatic Seek Tuning).
Local mode:
Only strong stations will be automatically tuned in (Automatic
Seek Tuning).
Manual mode:
The frequency is manually tuned in steps (Manual tuning).
4 Press or to tune in the desired station.
Holding down or will change the frequency
continuously.
Manual Storing of Station Presets
1 Select the radio band and tune in a desired radio
station you wish to store in the preset memory.
2 Press and hold, for at least 2 seconds, any one of the
preset buttons (1 through 6) into which you wish
to store the station.
The selected station is stored.
The display shows the band, preset number and station
frequency memorized.
•You will need to start from set up or you will not be able to set the mins
Dec 31, 2008 | Alpine CDE-9852 CD Player
Whirlpool dishwasher
Is it blikning 7 times and then repeating??? If so its a water heating fault. look in my solved solutions for more info on how to clear this fault.
Jan 14, 2008 | Whirlpool GU2400XTP Built-in Dishwasher
Open Questions:
Why does my Fisher and Paykel DD605SS stalls midway through wash cycle? I'm not sure if the following incidents are related but my Fisher and Paykel DD605ss now stalls part way through the wash cycle. A few nights ago I loaded the dishwasher hit timer and left it to run in the wee small hours. When I got up the next morning the circuit breaker had tripped on the circuit with the dishwasher. Once I reset the circuit breaker I started the dishwasher. I almost always run it on Normal (Eco) 154 minutes. It ran and then started beeping which I presumed was it finished. It continued to beep and was displaying an E4 error. After searching the E4 error I took the most popular solution and unplugged the machine and left it without power for about 10 minutes. After that plugged it back in and hit the start button again. It seemed to run well and when I walked into the kitchen late in the cycle it was displaying 28 minutes to go with a scrubbing brush flashing in the LCD. I left it alone and went about my life and returned to the kitchen about an hour later and it was still on 28 minutes to go. I hit pause and had a look, there was water and foam in the bottom of the draw. I took the wet plates out and hit the rinse option to see if it was a pump problem. The rinse option ran and the draw was almost empty. I then took the rack etc out of the raw and cleaned it all out. There was a little gunk but not much. I put a light load of dishes in the machine and ran it on the Normal wash mode. It started up and made all the right noises so I left it. I came back to the kitchen and it was stuck on 94 minutes with the flashing scrubbing brush. I paused it, took the dishes out and again ran the Rinse option which drained the draw. So my question is are the three events linked? Circuit breaker tripping, E4 error and random stoppages during the wash cycle?
Feb 27, 2017 | Fisher and Paykel DD605SS Stainless Steel...
See all Fisher and Paykel DD605SS Stainless Steel Questions
Fisher and Paykel DD605SS Stainless Steel Dishwasher Logo
100 people viewed this question
Top Fisher and Paykel Dishwashers Experts
Brian Coughlan
marley mcelhinney
Are you a Fisher and Paykel Dishwasher Expert? Answer questions, earn points and help others
