Question about Robinair Cool Tech 34700Z Recovery, Recycling, Recharging
Need to know where to find a service manual for a robinair 342000
    President:
  • 180 Answers
You can get it only from Robinair or any Athorize Dealer
Posted on Jun 01, 2010
I need operation manual for robinair 34801 recovery machine.
The service manual is online, here:
http://www.aescosc.com/pdfs/RA_34800.pdf
Dec 05, 2014 | Robinair Measuring Tools & Sensors
Where Can you purchase a 34700Z service Manual?
No, The service manual are a restricted item due to manufacturing specs. Only approved Robinair service centers have access to them. But if there is some thing you are looking for try the tech support. A lot of times they can send you a page from it if there is something that you need ex, wire diagrams or plumbing diagrams.
Dec 18, 2012 | Robinair Cool Tech 34700Z Recovery,...
Robinar Cooltech 342000 - on start up stops on the "Initalizing System" screen. Is there a reset procedure available?
You can try the following : 1# Check main 15 amp circuit breaker (located on back of the machine), reset the circuit breaker. If breaker tripped again after reset, the circuit breaker need to be replace.
2# Verify line voltage is present at input of main power switch & output at switch turn ON. If line voltage is not present at power switch input, check connections between power switch and AC plug. If line voltage is present at power switch input, but not at output with power switch turned ON, replace power switch.
3# If all proceeding steps tested OK & problem still exist, you may nee to replace The main control module.
Hope this will help you, if so please vote for it.
Mar 07, 2011 | Robinair Cool Tech 34700Z Recovery,...
NEED WIRING DIAGRAM FOR ROBIN AIR 34700Z MINE WILL NOT RECOVER FOUND YELLOW WIRE MARKED #67 WAS UNPLUGED. WHERE DOES IT GO.
You can try to get it only from any Robinair service center, No one can post any Robinair service manual at web site because of copyright! If you wish you may check my other solutions which i've post earlier for the same problem.
Yellow wire marked with 67 is a ground wire & you can hook-up anywhere in machine body
Nov 17, 2010 | Robinair Cool Tech 34700Z Recovery,...
I need a service and repair manual for 34700Z
This is not possible to get it from this site, because of copyright. You may try to get it from local robinair service center of you area. Also you can check to robinair web site at www.robinair.com
Aug 17, 2010 | Robinair Cool Tech 34700Z Recovery,...
Wont recover
Please Check the following:1# Press recover & fix a vacuum gauge on your machin Compressor suction port & monito the gauge is going up to13"HG suction,if not then you may need to replace the compressor.2# Check spin on-filter weight(total amount of refrigerant you have been recover since last filter changr,Max.filter Capacity is 68KG/150LBS) if it's more then max.cap. replace the spin on-filter.3# Check low side clearing sensor (Vacuum sensor) for proper operation.4# Also you can try to reset (clockwise & counter clockwise) automatic expension valve for any block of refrigerent flow.
May 25, 2010 | Robinair Cool Tech 34700Z Recovery,...
I have a robinair 342000 and it will not recover need help what do i do to fix
May 24, 2010 | Robinair Cool Tech 34700Z Recovery,...
My robinair isn't working and shows high pressure
This is a common problrm of Robinair 34700Z series machine.so don't worry just do the following :- 1# Verify the ISV tank is not overfilled.if full,remove refrigerant from tank. 2# Verify if there is high pressure in the tank.Purge excess air from the tank manually.( Open air purge hose from the tank,then press tank valve as needed) 3#Check the high pressure switch for proper operation,if not then replace high pressure switch.Hope this will solve your problem.
Jul 12, 2009 | Heating & Cooling
Robinair  Cool Tech 34700Z Recovery, Recycling, Recharging Logo
396 people viewed this question
Top Robinair Measuring Tools & Sensors Experts
Mike
Jay Finke
Jay Finke
Are you a Robinair Measuring Tool and Sensor Expert? Answer questions, earn points and help others
