Question about NEC VT37 Multimedia Projector
Nec projector
Attempting to show image onto  smartboard the projector is mounted upside down from the ceiling thus the controls are facing the floor.  all images are upside down on screen  is there a default image invert function ?????
  • Anonymous Aug 25, 2008
    The image from the ceiling mounted projector is upside down on the screen. I have tried all the menu controls but can't get it to show the right way.
  • Anonymous Jan 07, 2009
    Exactly same problem!
  • 2,237 Answers
Go into menu, under image, and chose ceiling.
Posted on Aug 04, 2009
MY EPSOM PROJECTOR IMAGE IS UPSIDE DOWN. WHAT DO I DO?
Hi, Your projector is probably set for ceiling mount which will project an upside down image because the projector is normally mounted upside down when installed on the ceiling. Go into the menu and select extended then select projection then select front. That should return the image to right side up.
Aug 22, 2011 | Epson EX30 LCD Projector
My dell 4610x projector is mounted on the ceiling; it is showing the image upside down. I went to setup>projector mode and it only has two icons not 4. and no matter which one i choose, it just flips...
There is usually a section for the orientation of the projector, maybe the ceiling/table mounted section is in a differnent place in the settings menu than the front/rear facing section.
Good luck
Aug 02, 2011 | Dell 4610X Wireless Plus Mainstream...
HI? HOW TO PUT MY IMAGE UPSIDE DOWN AFTER A CEILING MOUNT NP210G NEC BEAMER.? THANKS, Noel Belgium.
hi,
1. press menu button
2. select setup
3.go to orientation (This sets your image for your type of projection. The options are:
desktop front projection, ceiling rear projection, desktop rear projection, and ceiling front projection.)
ok,
Dec 17, 2010 | NEC VT47 Multimedia Projector
The ceiling mounted projectors image is upside down, how do i turn it the other way?
Go to the menu, in the "Setup" section, then go to "orientation"..and select "ceiling"...image will invert for you.
Good Luck
Aug 12, 2010 | NEC MultiSync VT580 Multimedia Projector
My projectors image is upside down. how do i fix
Go to Menu> Extended> Projection> select Front ( to project from the front of the screen ).Front/Ceiling ( If the projector is mounted upside-down from the ceiling ). Rear ( to project from behind onto a transparent screen ).Rear/Ceiling ( to project from behind when the projector is mounted upside-down from the ceiling ).
Apr 11, 2010 | Epson EX30 LCD Projector
Mounting the Projector from the Ceiling
Projectors, in general want to project the bottom of the image 1 foot above the lens at a typical range. When mounted upside down, they project the top of the image 1 foot below the center of the lens. If you don't want to turn the projector over, you'll have to change the angle and probably go to the extreme on the keystone correction.
Aug 05, 2009 | Dell 1200MP DLP Projector
Data Projector projecting upside down
If you go onto your menu and click on "setup". Press orientation and select the right one for your projector. It allows you to choose whether your projector is on a table top or ceiling mounted etc.
Feb 10, 2009 | NEC VT47 Multimedia Projector
Image on screen is upside down
The orientation of your projector can be setup from the "Option" menu. You may need to select the "FRONT" and "CEILING" options to display the correct orientation of the image.
Jan 19, 2009 | Panasonic PT-L785U Multimedia Projector
Nec vt 675 projector
Hi there
Simply go into the menu and flip it back in the subfolder that will either read Mirror or Horisontal / Vertical Positioning
Apr 09, 2008 | Office Equipment & Supplies
Image is upside down on projector
in amodel nec projector vt490 the status lamp is blinking or flashing and the machin not work
plz send me the problem and solusion.
Oct 28, 2007 | NEC LT20 Multimedia Projector
NEC VT37 Multimedia Projector Logo
2,141 people viewed this question
Top NEC Office Equipment & Supplies Experts
jasbo
jasbo
Are you a NEC Office Equipment and Supply Expert? Answer questions, earn points and help others
