I can provide the radio wire colors and each function of the wires by color.
2001 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink
Car Radio Switched 12v+ Wire: Blue
Car Radio Ground Wire: Gray
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Left Front Speaker Positive Wire (+): Pink
Left Front Speaker Negative Wire (-): Blue
Right Front Speaker Positive Wire (+): White
Right Front Speaker Negative Wire (-): Black
Left Rear Speaker Positive Wire (+): Light Green
Left Rear Speaker Negative Wire (-): Violet
Right Rear Speaker Positive Wire (+): Blue
Right Rear Speaker Negative Wire (-): Pink
2002 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Ground Wire: Chassis
if u have a local autozone they have a radio harness kit its around 8 dollars it has all the color code u need tells wire color and which wire goes where saves lots of guessing and trouble
if you are just looking for the B+ and ACC just wire it directly to the ignition switch. im pretty sure it is labelled properly. you can also try using a multi meter to test for power
I have the same car...04 nissan sentra....with the exact same problem....left side speakers just quit working. I still do not know what caused the problem, or how to fix it. I know it not the wiring, it is a defect within the stereo.
1995 Nissan Sentra Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Pink Car Radio Switched 12v+ Wire: Blue Car Radio Ground Wire: Chassis Car Radio Illumination Wire: Red/Blue Car Stereo Dimmer Wire: Red/Yellow Car Stereo Antenna Trigger: N/A Car Stereo Amp Trigger Wire: N/A Car Stereo Amplifier Location: N/A Front Speakers Size: N/A Front Speakers Location: N/A Left Front Speaker Positive Wire (+): Pink Left Front Speaker Negative Wire (-): Blue Right Front Speaker Positive Wire (+): White Right Front Speaker Negative Wire (-): Black Rear Speakers Size: N/A Rear Speakers Location: N/A Left Rear Speaker Positive Wire (+): Light Green Left Rear Speaker Negative Wire (-): Violet Right Rear Speaker Positive Wire (+): Blue Right Rear Speaker Negative Wire (-): Pink
Omega and alldata match , i expect the second set to match . obviously only one of these color codes match your radio , which ever one matches , is the one . cheers
