Question about RCA HD52W58 52" TV
Picture seems sunk in and the color distorted with doubleing effe
We were out of town and when we returned the picture came on with the color changed and the picture seemed to have a radius effect. The figure on the sceen are doubled and it kind of loooks like you are looking at the screen through a glass or a coke bottle. The volume seems to be ok. When you turn the satelite off to where there is a black screen there is three wavy lines. They are blue, green, and red wavy lines at the top of the screen. The bottom left corner where it shows whether it is on satelite or not is in the same colors(blue,green,red).
  • RCA Master
  • 3,459 Answers
Projection TV sets need to have all three colors - RED - BLUE - GREEN - lined up correctly on the screen in order for the video to look normal. When its out of alignment the video will look 3D, wavy, distorted, etc. Most of the time you just need to adjust your convergence in the TV menu. If you cannot adjust it in the menu - then your convergence is broken and needs to be repaired.
This is a very common failure on these projection sets and a fairly simple DIY fix. All projeciton sets including Samsung, RCA, Sony, Philip Magnavox, Panasonic, Pioneer, Akai, GE, JVC, Toshiba, and others at some point will have the same problem.
Common Symptoms include....
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
  • TV shuts off after powering on. Power light will blink. TV may also make a chirping noise.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the settings menu then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move RED and BLUE in all directions - up, down, left, and right. And you should be able to get the grid straight.
If you can't move them in all directions or cant move them far enough your convergence chips are bad and should be replaced. This is a common problem.
Note: If you TV has as flash focus or magic focus button only try pressing the bPicture seems sunk in and the color distorted with - 69189a5.pngt fails to fix the convergence your need to fix it. See below for a fix
69189a5.pngCONVERGENCE SOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses.
This is a a fairly easy DIY job if you are handy and can follow directions. You can get complete repair kits from TvRepairKits.com or click here. They have put together DIY repair kits that include the OEM parts and step by step photo instructions for each repair. If you are not handy or can't follow directions we would suggest calling a shop.
Posted on Jul 03, 2010
How do I fix the picture?
there is a T con error please replace the T con in this condition
Feb 15, 2016 | Sony BRAVIA KDL-40V2500 40 in. LCD HDTV
3 Horizontal lines distorting picture
When you say "distort the picture", are you referring to dark image? double picture
Jan 20, 2013 | Samsung Touch of Color LN52A650 52 in. LCD...
My RCA Model number HD52W59 has color distortion and double image and sunk picture in the middle. Is there any way of fixing this problem. This tv is a projection TV
Yes.The tv have a problems known as a convergence problems,it dead.The tv colors lines R,G,B mis alignment,have colors shadows pictures or 3D pictures look alike.The tv convergence board have 2 STK convergence ICS and some or all it resistors are dead.These parts on the tv convergence board,must be change to solved the tv picture convergence problems.The shop,will cost u like $300-350 for parts and labors.
Nov 08, 2010 | RCA HD52W58 52" TV
JVC-AV48WPT74 picture colors are distorted, looks like 3-D image
The convergence ICs and feed resistors need to be replaced. You can get the repair kit for your specific model at the following link. The convergence repair kit contains the replacement parts and the step by step repair proceedure on CD. Very easy repair. Just look under the JVC repair kit category
http://www.tvrepairworld.com/
Jul 12, 2009 | JVC AV-48WP74 48" Rear Projection...
Distorted picture. changes from color to black and white.
Hi, this is a bad main board that is causing this issue you are experiencing. simply replacing this board will fix this issue.
Click Here
May 21, 2009 | Mitsubishi WS-55511 55" Rear Projection...
Distorted picture on RCA LCD TV
it can be replaced with a t0220 stile case dioded 220k ohm go to nte look up and do a search on the rca part #moz-screenshot.jpg 259638 search the web for the part.
Jun 29, 2008 | RCA R52WM24 52" HDTV Projection Television
I have the same tv. Had repair man come to my home in late april. Said it is the power convergence board. $225 for parts and labor I was told. Bad thing is part was supposed to arrive mid-may,then mid-june and now mid-july. He say's part is on back order. I'm actually going to contact RCA soon to find out if this is true. This seems to be a common problem with this particular T.V
Mar 07, 2008 | RCA P52937 52" Rear Projection Television
your set has convergence problems i dont have the answer yet ,i do know that convergence broad is not what is causing this! I have one in my shop now with same problem as soon as i find out problem i will post it !!!!!
Jan 09, 2008 | RCA HD52W59 HDTV Projection Television
Samsung Hc-p4752e - Double Picture
Dane,
The convergence amps most likely failed. That unit takes two STK392-010 amps and the most likely cause for their failure are one or more of the 3.9 ohm 1/2watt resistors out in front of the Ic's which have opened or changed in value. There are several of them too, Rz142,143,146,147,144,145,123,124,125,126,127 and 128 and do check them all...
Bill
Nov 24, 2007 | Samsung HC-P4752W 47" Rear Projection...
RCA HD52W58 52" TV Logo
507 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
