Question about Honda Pressure Washer PSI 3000
Engine will not run but a few minutes at a time
This is my fourth honda pressure washer.It is a 5.5 hp the smallest one i have owned.When I try to wash something it will only run about 2 or 3 minutes and shut off.Then it is very hard to crank.Runs another couple of minutes and shutes down again.I have checked the oil level in the motor and pump.This machine only has about 4 to 5 hours total on it.Any suggestions will be appreciated.
    President:
  • 1,902 Answers
Check your spark plugs, see if they are failing, if they are then your motor is getting to hot. meaning that you either have the fuel mixture set to high or the setting on the spark plugs are not correct causing you to burn hot.
Please rate
Posted on Jun 01, 2010
Honda 5.5 hp stops
Honda had a problem with the gas cap not venting properly, but commonly it will run for several minutes at a time before stopping. 30 seconds sounds like possible fuel delivery problem like a sticking float or dirty carb jet..especially if you have to run it with the choke on. A bad air filter...very dirty, or oil soaked might do this. Check your oil level. Sitting, oil is a little higher level than when running and these motors will not run if the oil level is too low.
Oct 18, 2012 | Briggs & Stratton Gas Pressure Washer...
Honda Pressure Washer won't start
Blue smoke is def oil burning so I would guess that is the ain cause of the non running. It is possible that oil has got into the carb and jet . Turn fuel off and unscrew the slightly off set 10mm bolt on the bottom of the carb bowl to drain the fuel. If oil came out with the fuel then you should undo the other 10mm bolt and remove the bowl. Spray some carb cleaner around the floet and jet and also up the post that the bowl was fixed to as the jet is up there. Also, remove spark plug and pull over a few time to get rid of anything in the cylinder. Refit all back together and try again (don't forget to turn fuel back on).If it tarts it may run smokey for a few minutes while any oil residue burns off.
Jun 27, 2012 | Garden
Oil comeing out exhaust and gas in oil but runs for a few minutes and shuts down
sounds like the needle valve is not seating and over flowing the fuel into the crankcase change the valve and seat then change the oil a couple times
Apr 27, 2012 | Honda Horizontal Engine 8 HP OHV 2:1...
GX (or GTX, not sure) 360, 5.5 hp Honda engine on a pressure washer; engine will start and run perfect for about 30-45 seconds, no smoke or rough idle during that time, then engine dies and will not start...
Try draining all the fuel from the tank and carburetor. Replenish with fresh fuel. Try using an additive that keeps the fuel fresh longer and will displace some moisture. Good luck.
Mar 05, 2011 | Honda Garden
My Pressure washers runs for a few minutes and loses pressure then shuts off. What should i do?
Use a high quality carb cleaner poured directly into the gas tank and use a liberal (large) amount. Run the engine as long as you can with the choke on full or half full in order to get the carb cleaner into the carb. Then turn the engine off and let it sit for two or three days so that the carb cleaner can do its thing. While this is going on, why not do the below as well to improve water pressure.With the engine turned off, pour liquid TSP into the fresh water inlet until it comes out the other end at first just water that is already within the pump will come out but make sure you put enough TSP that it starts to come out the wand outlet. Then, let it sit for 48 hours and don't run it at all. This is how I fixed my no pressure problem tomsimmonds@yahoo.ca owner of Honda 5.5 with Comet pressure washer pump
Apr 08, 2010 | Honda 8 HP Engine
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
% hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
Nov 02, 2008 | Karcher 2500 PSI Pressure Washer
No Pressure
is the engine still turning up good or does the press. fall when engine rpm drops? your not very clear on this.if the engine is dropping rpm there is several problems causing this and without being able to actually see and hear what is going on there's no way i can go thru all that could be wrong.
Jul 09, 2008 | Karcher 2500 PSI Pressure Washer
Honda Pressure Washer PSI 3000 Logo
837 people viewed this question
Top Honda Garden Experts
John Trevino
JOHN LAPIER
Are you a Honda Garden Expert? Answer questions, earn points and help others
