Question about Water Heaters
New Rheem electric 50 gallon not heating
I just installed a new Rheem electric 50 gallon hot water heater. I am getting power (220) to the unit. The heating elements are getting power. I have waited over 2 hours with the thermostats set at 120. No hot water. I then changed the thermostats to about 140. Now 3 hrs and no change in temp. The old water heater had a secondary ground to the frame of mobile home. I did the same.
  • 1 more comment
  • Rich Jun 01, 2010
    Hi ,, can you tell me how you wired the heater? how you tested for the voltage? where you tested the 220volts? and where on the elements you tested for the voltage .. Thanks ..
  • phillip helms Jun 01, 2010
    I wired using 10/2. From the 30 amp breaker I ran the wires to each of the wires in the junction box, one red the other black. The ground to the green screw. The old water heater had a secondary ground hooked to the frame of my mobile home. I replaced this with new. The manuel said I should run a secondary ground if I wasn't using conduit. I tested the voltage from the green ground screw to each of the load wires. 110 on each. I tested each wire individually on the elements with the green screw as a ground
  • Rich Jun 01, 2010
    I wish you had said that you tested your power between the two hots and confirmed that you have 220 volts. Yes I see you have two 110 tests .. but please test between the hots and confirm the 220volts. Your secondary ground is OK .. not usually necessary but a good safety , specially in a trailer. Do you have no hot water , or a limited hot water??
  • 349 Answers
Check the elements, if you have access to a meter to check them. If they are getting power to elements and you have no hot water.
The elements are not working correctly. I had some elements check out ok till the thermostat's turned on and the elements didn't heat.
Sounds like the elements are bad.
Posted on Jun 01, 2010
Testimonial: "Thank you for the information. What if the elements are good?"
I have water in the junction box on top of my hot water heater and into the electrical conduit leading to the hot water heater.
I do not see your earlier post with photo.
The problem could be the conduit.....
-disconnect the conduit and wires from water heater
-run wire into a junction box set lower than top of water heater... -then run another #10 wire from the junction box up to water heater...
-So if water is coming from conduit, it will accumulate into junction box and not in the water heater wiring cavity.
Next thing....
... a water softener can cause rusted tank.
-Softened water adversely affects anode rod...
-causing anode rod to deplete faster...
-once anode rod is gone, then tank begins to rust.
-Here are details for checking anode rod each 2-3 years:
http://waterheatertimer.org/Replace-anode-rod.html
http://waterheatertimer.org/How-to-maintain-water-heater.html
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html
Gene
Water Heater Timers Save Money
Mar 05, 2015 | Rheem 82v52-2 Tall Electric Water Heater...
Energy factor rating
Rheem 50 gallon Pro52-2 has EF .95, which makes it ordinary 240Volt 4500 watt non-simultaneous electric water heater that produces about 21 gallons hot water per hour, with 67 gallon first hour delivery.
Recommend 80 gallon per hour first hour for oversized bathtub.
http://bostonheatingsupply.com/Rheem/Rheem%20Residential%20Electric/Professional/Rheem_ResidentialElectric_Professional%20Spec%20Sheet.pdf
Maintain electric water heater and it will last indefinitely.
http://waterheatertimer.org/9-ways-to-save-with-water-heater.html
Anode rod is located on top in separate port.
Anode keeps tank from rusting.
Year of Rheem water heater manufacture shows 3rd and 4th digit of serial number.
Nov 25, 2012 | Water Heaters
Rheem 50 gallon Electric Water Heater 81V52D C repair ideas needed
It could be element shorted to ground through steel tank, so don't touch tank when breaker is ON.
Or you have undersized 12 gauge wire and 20 amp breaker and the heat has loosened breaker on the busbar. Breaker trips when heat exceeds breaker limit. Jiggle breaker and listen for crackling sound.
To restore hot water now:
Turn off circuit breaker, and open top cover then Push in reset button on top of heater to restore functionality. Put back insulation and factory cover.
To fix water heater: test and replace bad element.
http://waterheatertimer.org/How-to-test-water-heater-element.html
If problems continue
http://waterheatertimer.org/How-to-troubleshoot-electric-problems-with-water-heater.html#trip-breaker
http://waterheatertimer.org/Troubleshoot-household-electricity.html
Sep 25, 2012 | Rheem 81V52D Water Heaters FOR 220 VOLTS
Rheem electric water heater 50 gallon, lukewarm water. Water is warm but not hot, where should we look for problem?
Luke warm water is the result of top element bad and the bottom is the only one heater. The best solution I can reccomend is to change both out due to the fact the bottom element may go bad and since you have to change one you might as well change both.
Turn power and water off, drain heater down and once water is drained out change them out. Once new ones installed turn water on to fill heater and open faucets and get air out on the hot side of each faucet once water is flowing out of each faucet you are now ready to turn power back on.
Oct 12, 2011 | Rheem 50 Gallon FVR NATGAS Water Heater...
I put a new top thermastate, bottom thermastate, new top element, bottom element, on my electric 50 gal tank and didn't get hot water. Only 4years old. Bought a new GE 50 gal. tank and installed, even a...
The next thing you need to do is find out whether you have 240v to the bottom element....the top will not heat till the bottom is satisfied...
An electric meter is critical when working with these units....trace the power and see where it stops....
here also are some tips that will help you...
Electric Water Heater Wiring Diagram
Electric Water Heater not Working
heatman101
Dec 04, 2010 | Rheem Water Heaters
If my 50 gallon water heater is leaking can i replace it with a smaller water heater?
There should be no problem replacing a 50 gallon heater with a smaller size heater as long as the codes for your city/town allow it. You may also need to pull a permit for the installation, check with your municipality. Some codes state that a home with X square feet or whatever measurement they want to go by, will need at least a 50 gallon hot water heater. Obviously all installation instructions and codes apply to any new hot water heater installation.
Sep 10, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Rheem 21VP50-1. On hot water for 3 days. Shut of and turned on power...no ignition, no blower, no clicking.
Unplug the power supply for 10 minutes and plug it back in. If the standard start up does not occur, you have bad control valve or the Flammable Vapor Censer has trip the unit. In either case you need to contact Rheem for repair parts or a new heater.
Sep 07, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
Top heating element was broke. Replaced got hot water for week. Now have to run hot water for 20 mins before it goes from warm to hot. Top heating element reads 240VAC bottom heating element reads...
look for a badly connected power line ont he bottom element, or any connection upstream of the power terminals. voltage readings usually drop to that range when you only have one side of the 220v circuit connected.
Jun 20, 2010 | Rheem 50 GAL ELEC TALL Water Heater 6YR SC...
We just installed a Rheem 50 gallon water heater. When you use any hot water a low pitched vibrations occurs that you can hear in the bathroom and bedroom. When the water heater completes the heating cycle...
Every electric water heater I have ever installed makes a low hum while heating. I believe this is a combination of the current going through the elements and the minerals in the water cooking on the elements. That is the best explanation I have. Hope this helps.
May 11, 2010 | Rheem 81VP6S/430126 Water Heater
Water Heaters Logo
254 people viewed this question
Top Water Heaters Experts
Donni Steen
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
