Question about Karcher 2500 PSI Pressure Washer
What's wrong when you only get full pressure for the first few seconds and then it stops and won't spray fully anymore?
    Problem Solver:
  • 6 Answers
Air pockets in the supply hose or the supply is feeding the power washer too slowly.
These things can really put out quite a bit of water, so make sure you've got a good supply going to it. No kinks in the hose, spigot opened all the way, etc.
If the problem is air pockets, make sure you're running the feed hose long enough to get a good flow of water before hooking up to and starting the power washer.
Posted on Jun 01, 2010
My kenmore stick vaccum model. 116.36025510C stops after a few seconds and the light is blinking. This is after it indicates it has been fully charged
It sounds like the battery is no good, even if it shows full charge that doesn't preclude a defective battery.
Dec 01, 2016 | Computers & Internet
Not charging
The chances are that the battery has failed. The age of the device would indicate that the battery is probably NiCd - these batteries have a memory effect that means after a while the battery thinks that "fully Discharged" would be the state that is the most usual for the charger to be used most often. You will need to open the device to get the battery out to find the part number. You will then be able to order on from an online retailer.
Jul 11, 2013 | Aluratek APMP101F Cinepal HD Media Player...
1990 s-10 4 cylinder 2.5, 5 speed, throttle body injection, 120,000 miles won't start without stating fluid. Runs fine after started, I've changed fuel pump, filter, plugs. I appreciate any help.
My first question would be is the injector spraying when you crank it ?
The way its supposed to work, the fuel line to the tank should have about 10psi of pressure before you crank the engine. When you turn the key on the pump gets power for 3 seconds to boost the pressure. The pump stops working until the engine has oil pressure which takes a few seconds.
If the base fuel pressure leaks back to the tank, or the pump relay is not powering the pump, you won't have any fuel pressure or spray until you get oil pressure.
Dec 12, 2012 | Cars & Trucks
I have a 96 chevy suburban 1500 that only started if i sprayed starter fluid in it but now it stop working ,whats wrong
you need to install a fuel pressure gauge on the system and see what the fuel pressure is doing
Jul 09, 2012 | Cars & Trucks
Does not give a continous high pressure flow cuts in and out
that is sure signal of insufficient water supply!
try easy solution first:
make sure that your mains is fully open, that tap on whihc hose is hook up is fully open and hose is of "decent" diameter to allow sufficient flow.
if above solution do not work then you need to make another, more difficult arrangement:
prepare 20litres pressure tank with inlet connected to mains and outlet by short hose to power washer, fill it with water from mains, keep it under mains pressure and use karcher power washer normaly. this will solve water supply problem. twenty litres will last about 2min, because it is re-filled, under standard pressure therefore it will last about 3min...
third possibility is to stop washing...
if you find my advice helpfull, please do not hesitate to left the comment and vote for me, thanx!
Jul 31, 2010 | Karcher K2.26 Electric Power Washer
GX 08 spray gun problem
drain your system of pressure. remove your air cap and nozzle from the gun. slowly increase fluid pressure till it comes out of gun. this will clean out debri from gun. reduce pressure so you don't wast anymore fluid.
clean nozzle properly / completely
clean aircap. properly / completely
inspect needle tip for abnormal wear.
if cleaned properly you will find your gun works much better.
Oct 17, 2009 | Wagner GX08 Airless Spray Gun
Generac Generator won't stay running
It sounds like you are not producing any voltage. When you start your generator have a volt meter on the generator breaker to see if there is voltage present when the genset is running. Also, check you oil pressure switch, which is near the oil filter.
Apr 11, 2009 | Electrical Supplies
Karcher 2500 PSI Pressure Washer Logo
403 people viewed this question
Top Karcher Garden Experts
John Trevino
andy just round the...
Level 1 Expert
Are you a Karcher Garden Expert? Answer questions, earn points and help others
