Question about Pentair Pinnacle 1 1/2 - Hp In Ground Pool Pump
My water flow stops with my proline pump after a few minutes and i have to pump the filter to get it going
I was having the same problem. the connections were touching. once i open the moter, taped the connection from not touching each others, it works great
Posted on Jun 13, 2010
  • 819 Answers
What do you mean by pump the filter?
Posted on Jun 01, 2010
Why the intex pool 2500 pump stops water flow after 3 hours
bad pump motor replace pump its overheating
Jun 23, 2014 | Intex Pool & Spa
Blanco Dishwasher BIDW605 does not
I would check the hose/water filters. make sure that you have proper flow from the hoses
Apr 04, 2008 | Dishwashers
Water Flow to Booster Pump
plastic bag with a few socks in it, can be used to block the skimmer plumbing, if the pump is lower than the pool ! if not it will stop draining after the filter emptys
Apr 25, 2013 | Polaris Pb4 - 60 Booster Pump
How to use backwash to waste
When the filter get clogged the pressure in the filter increases and there is less water flow returning to the pool.
If your filter is a sand filter, when you turn the valve to backwash and turn on the pump it reverses the water flow in the sand filter to flush the dirt out of the filter to waste. Look at the window openning in the waste pipe and keep the backwashing goinging until you see clear water.
Then turn off the pump and move the control valve to Rinse, turn on the pump for a few minutes, this returns the water flow back to normal but the water goes to waste to make sure the sand filter is clean.
Turn off the pump and move the control valve to filter and turn on the pump. This mode is the normal operating mode and the pressure gauge in the sand filter will show a drop in pressure.
Some pressure gauge shows a red section to indicate when backwashing should be carried out.
May 02, 2012 | Hayward Pool & Spa
I have a Proline High Rate Sand Filter that i purchased at NAMCO. During the last few days, when I turn the filter on, I get a water leak in the area where the top unit of the filter is connected to...
I have a Proline High Rate Sand Filter I purchased at Namco.I only had it a year, now it have a leak coming from underneath it.What can I do to stop it ?
Jul 28, 2010 | Garden
After I vacuum the pool, backwash it and then turn the filter system back on it blows in a lot of green water back into the pool. What should I do?
1st Green water is algee. Kill the algee in the pool. 2nd when you're finished backwashing the filter. Stop pump and move valve handle to rinse position. Then restart pump. Run in rinse mode until glass is clear. Then stop pump again, and move lever to filter position. When you're backwashing, you're reversing the flow of the water through the filter. When you switch directly back to filter, anything left loose in the filter flows back to the pool. When you select rinse, it reverses the flow back to normal, but keeps the water going to the waste outlet until clear, that way that green puff of water will go out the drain. You can get complete manuals from www.haywardnet.com
Jul 20, 2010 | Hayward SAND FILTER, PRO SERIES
Fridge water filter replaced now flows very, very slow
Hi .. first I would try and eliminate the filter as the problem. Remove the filter and try the water again. If the water flows strong, then the filter is the problem. If the water stills sputters and is low flow, then there is a partial blockage in the internal tubing , or a problem with the supply. If you roll the fridge out to get at the suppl. you could shut it off and disconnect the supply tube from the fridge, then turn the water on slowly to check the flow at the supply. If the flow is good there , then the blockage is internal.
May 03, 2010 | Kenmore 21.7 cu. ft. Side-by-Side...
I keep getting an error OE on my LG WM0532HM front load washing machine and it won't spin out the water, just stops after a few minutes
The OE error is "Outlet Error" for the draining the water from the unit.
The unit is having trouble draining the water from the unit and that is why there is an error code.
You need to be sure there is nothing in the pump's filter (located at the bottom left on the front panel) that is restricting the water's flow.
If the pump's filter and housing is clear then it is the pump that has or is going bad.
The pump will fail because a seal will let water into the back side of the motor and case it to lock up.
If you need a part number for the drain pump, let me know.
Apr 24, 2010 | LG WM-0532HW Front Load Washer
Will not pump when it has a filter in it
filters are too good for pump system.
These pool pumps seam to over heat fast, no quick fix.
* Try getting more air flow around pump.
* Only use pump when using pool or near by.
* Use a pool cover - will help stop dirt/rubbish getting into pool - less to filter.
Jun 02, 2009 | Intex Easy Set 1500 Gph Filter Swimming...
Pentair Pinnacle 1 1/2 - Hp In Ground Pool Pump Logo
432 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
