Question about Apex Digital AD-1225 DVD Player
How to remove a stuck dvd-drawer will not open
    Problem Solver:
  • 10 Answers
Refer to a qualified technician
Posted on Jun 01, 2010
  • 979 Answers
SOURCE: DVD recorder DMR-E55
Describe "self check" mode?...accordianman
Posted on Nov 26, 2007
  • 70 Answers
SOURCE: DVD stuck in player SONY RDR-VX 515
Take the lid off by taking the 2 to 4 screws out of the sides of the unit to get the disc out.
Posted on Feb 19, 2008
bluegreenash
  • 661 Answers
SOURCE: dvd recorder /vcr combo
possibly what has happened is the disk is not lying flat in the drawer, and is jamming as you try to remove, otherwise it could be a mechanical failure of the tray itself.
for the first you could try turning the unit upsidown, shake gently, and then put the right side up and try to eject drawer, if there are any rattling noises when doing this it may be that the disk failed in the drawer(broken into pieces),
if this does not help , you may need to dissasemble your DVD drive to recover your disk and reset the drive mechanism. only do this if your machine is out of warranty
Posted on Oct 15, 2008
pferd
  • 94 Answers
SOURCE: 2 dvd's are stuck in dvd player
This may need a trip to the shop.
I would try to bring the device to a worktable and using gentle probes, ease the door open when activated.
I assume that there is a noise when you activate the door open feature.
Posted on Mar 21, 2009
zlittell
  • 30 Answers
SOURCE: vcr/dvd combo, dvd drawer stuck open
they are either gear or "belt" (rubber band lol) driven trays the rubber band has slipped off or the gear is off track if your brave and skilled enough just open it up and reset it or fix it if not take it to someone who is
Posted on Aug 03, 2009
Magnavox ZV457MG9 A DVD drawer won't open
one of the faults with the home dvd player it seems we have to open them to remove the stuck dvd .and more often than not we end up braekingthe danged thing anyway
Mar 15, 2015 | Magnavox Televison & Video
Tray won't open on my MRX-530L CD/DVD recorder
leave the unit plugged off from power for one night and try to open.
else you will have to open the unit and force the tray outside.
Aug 10, 2008 | Memorex Televison & Video
Cant open dvd drawer
Sometimes DVD player drawers get stuck closed because the disc inside isn't seated properly. At other times the player may have another problem. The first step in discovering if it is the disc or another issue is to remove the disc. Most DVD players have a secret eject button. It allows you to open the drawer when a disc gets stuck and cannot be ejected normally.
For this you'll need a standard size paperclip.
  1. Unfold the paperclip and make it as straight as possible.
  2. Look closely at your DVD player . Push the tip the paper clip into the small hole on the tray cover on the front of the Toshiba. The hole is on the right side of the cover.
  3. Press inward gently with the paperclip until you feel a slight resistance, then continue pushing to engage the internal eject button. The tray should pop open partway.
  4. Gently pull the drawer until it's fully retracted. Be careful not to pull too far.
  5. Remove your disc from the drive.
  6. Before you reinsert another disc, use the remote and/or buttons on the player to close the door, and reopen it. You can also press carefully with your fingers. If you cannot open/close the drawer normally at this point, do not put in a new disc until you have repaired the problem.
What You Need
Dec 09, 2013 | Toshiba SD Computers & Internet
Dvd tray wont open
Hello
1. Turn off your DVD player. You do not want to risk electrical shock while working with it.
2. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
3. Insert a stiff wire-such as a paperclip or safety pin-into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
4. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling, remove the label.
5. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs.
6. You might need to see a technician.
GOODLUCK
Jan 27, 2011 | Amphion Mediaworks S99 DVD Player
The dvd drawer won't open. it is "stuck" closed.
Hello
A stuck drawer indicates a jammed mechanism or the presence of a mechanical drawer lock.
Nov 23, 2010 | Denon DVM-1805 DVD Player
The DVD door will not open when the button is pressed
Please check the bellow instructions:-
Turn off your DVD player. Locate your DVD player's manual Eject button. It is usually a small hole located underneath the DVD drawer.
Please get back to us if you have any further query or else accept the solution.
Nov 01, 2010 | Panasonic NVVHD1BS DVD Player / VCR Combo
I have a DVD that is stuck in my TIVO. The screen
Take the DVD player aparts,take out DVD disc out of the drawer,check the open/close drawer button again.Same result indication on the screen say is open infact it close.The motor the help open and the dvd drawer it dead.Need the motor replaced.
Jun 26, 2010 | Humax T800 TiVo 80-Hours Video Recorder
DVD drawer does not open when you push button to open DVD drawer
The most likely cause is damage, which should be seen with the eye. It could be a belt, broken cogs/teeth in the sledge mechansim, or a micro leaf switch bent out of place.
Apr 05, 2010 | HP dc4000
The DVD drawer will not open on the model TT 320
Hi
Thanks for using FixYa. Please locate the DVD player’s manual eject button which is a small hole located underneath the DVD drawer. Now insert a stiff wire like a paperclip or safety pin into the hole and push gently to open the drawer. Now pull the drawer gently to open it. Remove the DVD and see if there is a problem with it. Most DVD player drawers get stuck when a DVD is warped or the label is starting to peel. If the DVD is warped, discard it. If the label is peeling then you need to remove the label. Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player and you need to have it serviced.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 11, 2009 | TruTech TT320
DVD drawer will not open on Zenith ZHX-313....help???
hi friend,
Locate your DVD player’s manual Eject button. It is usually a small hole located underneath the DVD drawer.
Insert a stiff wire—such as a paperclip or safety pin—into the hole. Push gently and the drawer should open partway. Gently pull the drawer the rest of the way open.
Turn your DVD player back on. If it gets stuck again on a different DVD, then the problem may be with your DVD player rather than with your DVDs. If this is the case you should have it serviced or perhaps it is time for a new one.
I hope this helps.
thank u for using fixya
regards,
sivaranjini
Aug 05, 2009 | Zenith ZHX-313 System
Apex Digital AD-1225 DVD Player Logo
272 people viewed this question
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
