Question about HP PSC 2210 All-In-One InkJet Printer
Fax starts when phone rings interrupting the caller
    Scholar:
  • 53 Answers
Make sure that rings to answer on Fax is greater than the Rings to Answer on the Phone.
Posted on Jun 02, 2010
Caller ID not working on Norstar terminal using line dedicated to fax and phone
You must have latest software to have Caller ID
You must have a Caller ID line card
Caller ID must be programmed on the phone to allow it
Caller ID signal from carrier is sent between 1st and 2nd call
FYI on the fax: Analog ports (ATA's) on the Norstar system do not show Caller ID, instead you would need to use a line share device that supports caller id such as the STICK.
Oct 25, 2012 | NorStar M7310 Corded Phone
Epson Stylus CX5700f I have just setup fax. I am having problems receiving faxes and telephone calls
You need to do two more steps.
1. contact the phone company about distitive ring. This will have a different ring for incoming faxes.
2. set the fax up for distitive ring once the phone company sets you up. This will cause the fax only to answer when another fax is calling, due to the distictive ring set up.
Feb 14, 2012 | Epson Stylus CX5700F All-In-One InkJet...
The model of my AT&T answering machine is 1720...it is linked to a Brother's fax machine...when a call comes in I am not able to pick up the phone and interrupt the message from the answering machine...
Connect the telephone line of the answering machine from the series connection of the facts machine
.Now set the number of rings for the answering machine to activate to the maximum.{This is found on the side of the machine as a reed switch.}
Now when the calls comes in there is enough time for you to allow it to the answering machine or to attend a call or to set it to facts if a document is comming.While you are away you have to decide the priority needed for either facts or answering as it is a commonline. If answering machine has to work set the facts to telephone mode.If facts has to work set it to facts as the machine will activate before the answering machine.
Sep 02, 2010 | AT&T Lands Phones
Phone calls interrupted by fax tones
if you are using the EPABX pls. check the technician regarding that programming.....
Feb 17, 2010 | Samsung SCX 4521F All-In-One Laser Printer
I cannot receive faxes. The machine rings, the
check to see how the rx mode is set up as it may be set to manual it should be auto.. this means if a fax comes in you will have to lift phone or pressthe start button to receive the fax in manual mode whereas the auto or fax mode will turn the fax on automatically
Aug 13, 2009 | Office Equipment & Supplies
BROTHER FAX 1840-C.
Set your machine to MANUAL, this will allow you to answer every call yourself, then if it is a fax, the machine will take over. Sounds like you have it in fax/tel mode now, which allows for the fax machine to answer every call then if not a fax, double rings to you.
Sep 19, 2008 | Brother IntelliFAX 1840C Plain Paper...
Pixma mx 310 fax auto
enter rx settings and select teleline as fax priority.
Mar 30, 2008 | Canon FAX-JX200
Auto-answer issue: fax beeps on line when voicecall received
Try changing the receive mode from automatic to FAX ONLY and set the number of fax rings higher. You should be able to receive phone calls and if you are not answering your phone it will automatically receive a fax.
Mar 27, 2008 | Office Equipment & Supplies
All calls go directly to fax. Calls don't go to answering machine. I can't answer calls manually to speak with caller.
You seem to have chosen the correct answering mode which is ans/fax.Also pls check whether DRPD mode is correctly set .
It should be off in case your tel line does not have dual ring feature.
happy faxing
omnipresent
Oct 16, 2007 | Office Equipment & Supplies
HP PSC 2210 All-In-One InkJet Printer Logo
22 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
