Question about Best Software ACT for Palm OS - Instantly Access Every Contact Detail (804526027776)
Sync problems The sync does not seem to be working properly from my computer to the handheld. When I sync not all of the activities or entries transfter to the handheld. I think this might be an Act for Palm issue can you advise??
    Brigadier General:
  • 3,614 Answers
May i know the OS you are using right now..?
Posted on Jun 07, 2008
After sync no address book shows. Can I get to backup files?
seeme like you have synced your computer/laptop to handheld, not handheld to computer/laptop.. unfortunately there is no such way to get the backup..
Mar 18, 2010 | Palm Zire 72 Handheld
Double entries in Palm and Outlook
The closest I have come has been from a firmware update for the Palm phone. After the update, the phone saw my original contact list and created a second contact list from what was present in the Palm calendar.
If you have changed firmware and this issue started happening, you'll need to delete the duplicates in Outlook or it will continue to try and update/save them. Also, this is most likely why your sync sessions are taking more time...the phone is trying to read the different entries already present in outlook, and it is taking time to default when it cannot open the entries. Multiply that time by 4 or 5 times per entry and you have a very long sync session.
Hope this works for you!
Apr 02, 2008 | Palm Treo 650 Handheld
Hot sync does not complete!
Something similar happened to me due to incorrect periodic entries in the Datebook, try disabling all elements in the Hot Sync, try it, and if it works, then add them one by one until you find the offending one, then focus on clearing that DB.
(Actually i simply stopped synching Datebook since i didn't wanted to loose all the history of appointments i have).
Nov 04, 2007 | Palm TX Handheld
Manual Hot Sync
If u need to make connectivity between computer and Palm mobie then u need to install hot sync software on ur Pc and activate hotsync option from ur mobile then with cable u can transfer the data . if u  not have proper software of hotsync then download it from palm Site.
Gizmo1
Oct 22, 2007 | Palm LifeDrive Handheld
Lost calendar on hotsync
The information is unfortunately lost.
Unless you synced the palm on another computer, the palm only can back up the information when synced.
So if you sync it and the computer overwrites the handheld, the information never made it to the computer and thus cannot be restored.
The only thing you could check would be the backup folder in the palm directory under your profile name. Palm puts all of the .prc/.pdb files in there when you sync.
Sep 13, 2005 | Palm LifeDrive Handheld
Help active sync will stay in limbo attempting to connect to cradled axim
Does your system detect the handheld? After you connect the cradle or cable to the computer, then you should be prompted to install drivers for the handheld. Make sure that Dell Pocket PC appears in the Device Manager.
Sep 13, 2005 | Dell Axim X5 Pocket PC
Windows XP, Palm m130, & Outlook 2003 - Sync problem
It sounds like the computer is noticing the USB activity (from when you hit the HotSync button) but for some reason it can't find the correct information/driver. I'd first try a soft reset (stick a paper clip or the end of your stylus may screw off to reveal a pin, in the hole at the back of your palm) Don't worry, it won't delete your info UNLESS YOU HOLD DOWN THE POWER BUTTON (SO DON'T). Once it's booted back up, try the hotsync again. If that doesn't work, you may need to find the usb driver for your palm and reinstall it. This could just be copying a file from disc, or reloading your Palm Software. Good luck
Sep 12, 2005 | Palm m130 Handheld
Active sync and Outlook xp
Maybe i should help, because i was solving similar problem with C-Series handheld from Compaq, which is almost the same. I am using Active sync 3.0 as the newer versions didnt work properly and i got no problem...
Sep 12, 2005 | HP Jornada 568 Pocket PC
Outlook not synching
This is how I got it working. Don't use wireless sync software, someting is definitely buggy with it. Here is what I did to resolve sync errors: 1. Perform a hard reset on the Palm 2. Go to the Palmone folder on your hard drive (C:\Program Files|PalmOne. Look for the Backup folder. Rename this folder Backup Old. 3. Connect the Treo to your computer. 4. Right click the Hotsync icon in the taskbar and click Custom. Change the four Outlook conduits (Calendar, Contacts,Tasks,Memos) to Desktop overwrites Handheld. 5. Run a Hotsync with the Treo. It should sync without errors. If you need to install additional applications you can add them now
Sep 12, 2005 | Palm Tungsten E2 Handheld
Sync Doubling Calendar & Contacts in Outlook 2002
your t5 is UNSTABLE possibly due syncing to an old username from an old PDA. To correct this: -delete manually the doubles (PDS has a tool but none for outlook) -perform hard reset on your t5 -hotsync - creating a new user name (do not use the old one) -you will be asked to use the same profile name for the outlook Then you should be good to go.
Sep 12, 2005 | Palm Tungsten T5 - Multilingual Handheld
Computers & Internet Logo
35 people viewed this question
Top Best Software Computers & Internet Experts
Michael Galve
Michael Galve
Lee Parker
Lee Parker
Martin Graham
Level 1 Expert
Are you a Best Software Computer and Internet Expert? Answer questions, earn points and help others
