Question about LG WM-2277HW Front Load Washer
LG WM-2277HW will stop at the rinse cycle and flash te code. Manual says to unplug and call tech. Is there anything else that can be done?
  • LG Master
  • 43,501 Answers
If you are having a problem with your top load washer then check out this tip...
Washing MachineLG WM-2277HW will stop at the rinse cycle and - 2_bing.gif does not Pump or Spin
http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
Front Load Washing Machine2_bing.gif not draining and or not spinning
http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
heatman101
Posted on Jun 01, 2010
Lg front loading washer flasing LE and stops midcycle
In new installations, this error can sometimes present because of a miscommunication between the control panel and the wash motor. In this instance, the washer simply needs to be reset.
Step 1: Unplug the washing machine.
Step 2: While the washer remains unplugged, press and hold the [Start/Pause] button on the front panel for 5 seconds.
Step 3: Plug the unit back in, and run a rinse and spin cycle to test if the LE code is cleared.
OVER SUDDSING
Jun 16, 2012 | LG WM-2277HW Front Load Washer
TE error code problem How to fix the thermistor
The TE error code indicates a heating error, usually caused by a faulty thermistor. First, attempt to clear the error by unplugging the power cord, waiting for 10 seconds, restore the power, and restart the wash cycle. If the same problem happens again, close water tap, unplug the washer because the unit may require service.
Check in the next link the Service Manual for LG WM2277 Service Manual that could help you.
Hope this helps (remember to rate and comment this free answer).
Sep 27, 2011 | LG WM-2277HW Front Load Washer
Model wm2688hwm stop working screen show TE
TE Error Code = Heating Error - Thermistor failure
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Sep 12, 2010 | LG WM-2277HW Front Load Washer
How I fix an error code on a LG wm2669hna washer that says TE error
May 17, 2010 | LG WM-2277HW Front Load Washer
Error code tE, customer service recommended replacing thermoster, replaced but still getting error code. Can it be something else or does something have to be rest?
Ive looked through a service manual for your washing machine and that give the exact same fault and solution you mentioned (tE = Heater Error - The THERMISTOR is out of order)
Here is the service manual for you to look at:
WM-2277HW Service manunal
I had to scroll down to the troubleshooting section though but it has everything you would need to know in it.
I hope it helps
Regards
Mike
Mar 24, 2010 | LG WM-2277HW Front Load Washer
Washer stops during rinse cycle and "OE" code shows up. we've cleaned filter and keep draining drain hose. is there anything else to do or check?
You may have to inspect the entire drain system back to the pump, it may be partially clogged. When the unit drains it should drain a substantial amount of water. View the drain discharge, if it appears the discharge rate is not what it used to be, inspect the drain system
Nov 12, 2009 | LG WM-2277HW Front Load Washer
LG WASHER
Unplug your machine for a few minutes or more and plug it back in. This will fix the LE error most of the time.
Apr 27, 2009 | LG WM-2277HW Front Load Washer
Intellowasher WD-12126RD
it is coputer box in the washer. if it work on all other cycles. and stop on rinse. it need a new computer box . and in not hard to change.
Feb 15, 2008 | LG WM-2277HW Front Load Washer
Oe code
I had the same problem. First the grinding noise during the rinse cycle and then after four weeks the OE code. LG had a local repair service come out and he determined that the drain pump was dead and ordered a replacement. Still waiting on part after only 3 days.
Dec 22, 2007 | LG WM-2277HW Front Load Washer
LG WM-2277HW Front Load Washer Logo
230 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
