Question about Maxent MX42X3 42 in. HD-Ready Plasma Television
The tv picture flickers while in tv mode or dvd mode, sometimes for so long that I just turn it off. MX-42X3 mode.
  • 10,515 Answers
Based on the way you describe this issue,I would say that the problem is the power supply board.I do not think it needs replacement,probably just some defective capacitors are causing all the trouble. Please open the back cover and take a visual look at the power board.You might see one or more bulged top capacitors(not perfectly flat like the others). If you see any please replace them,this will restore the normal operation. The explanation for this is,that these defective capacitors cannot filter right the power supply 's output voltages,causing main board to malfunction. You can replace the power supply board instead of repairing it,but this will increase considerably the cost of repair.
Other than this, it could be Y Sustain Board or Z Sustain Board.You need to Check all the Boards before replacing it.
Let me know,if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
Posted on Jun 01, 2010
When i turn on tv no picture
need to check or replace main board .
Aug 24, 2013 | Maxent MX-42VM 42 in. Plasma HDTV
Picture take 3-4 minutes before it comes on
The main power supply regulator section circuit fault. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Jun 24, 2017 | Maxent Mx-42x3 42-inch Flat Panel Plasma...
My Maxent mx-50x3 has a intermitten problem, when I turn it on, it does not have a picture, 5 minutes later it will flicker than a couple minutes more it has a picture while flickering, another ten minutes...
i had the similar problem. i'm not a tech but like to take stuff apart to find the problem. on my tv i took the back completely off. do not touch the boards. if you follow the power supply from the plug up two boards i found a small white adjustment screw. it was just up and to the right slightly from the plug. with a small screw driver i turned it slightly to the right and the flickering and delayed picture went away. couldn't tell you why it worked but it did. hope this helps, saved us $800 to buy a new tv.
Aug 20, 2011 | Maxent MX-50X3 50 in. HD-Ready Plasma...
Maxnet mx-26x3 tv toconnect toan HDMI input
Maxent ,mx 26 x3 turns on for 5sc.( all white) then picture flickers and screen goes black.. green light on throughout..none of button on the remote or the tv will work expect the power .i wonder is their a way to reset the tv?
Jun 10, 2011 | Maxent MX-26X3 Television
We have a Maxent MX-42X3, it has flickering througout the whole picture.
This problem is caused by a faulty powersupply/standby board. I have seen this happen way too often on plasmas for the power supply is the most hard working part in a plasma. A component level repair might be possible but it depends on your prior experience in electronics. If you have never worked on a tv before I strongly suggest that you seek professional assistance to get it fixed as it holds dangerous amounts of voltages for several days after its turned off and unplugged from the power supply. As my guru always says "Your life and limb is worth much more than this". You can use our repair directory to search for techs in your area.
http://www.fixya.com/repair
Please give me a positive rating if I have provided sufficient advice or let me know if you need more help.
Sai.
Mar 29, 2010 | Maxent MX42X3 42 in. HD-Ready Plasma...
I have a Maxent 42 inch plasma.When you turn it on, it flickers for 5 minutes then comes on.recently the flickering continues non stop and now is almost unwatchable.Any idea what I can do to fix this? I...
What is the Product Name or Model number of your Maxent 42" Plasma TV? If it is a MX-42X3, Model # P420542HM8, I think I can help you. I have encountered this exact same problem with 2 Maxent MX-42X3 Plasma TV's. I found that C766, a 220uF, 16V surface-mount electrolytic capacitor on the main board is bad. This capacitor is located just to the left of the green multi-fin processor heat sink. This capacitor will test good using capacitor meter or an ESR meter, but if you spray it with Freeze-It with the power on, you will find out that this is the problem! To get it out, I found I had to remove the little 10uF 16V surface-mount capacitor just to the left of it. I then replaced these 2 capacitors with regular (radial), high-temperature, low-ESR capacitors. I cut the leads short, and bent the ends out just a little bit so you can solder them back onto the surface-mount pads. You can get these parts from Digi-Key Corp. I used Digi-Key part # P12383-ND ($0.32) for the 220uF capacitor, and P11212-ND ($0.30) for the 10uF capacitor. Both of these capacitors are rated for 25V and high temperature, so they won't go bad again. You can purchase surface mount capacitors there too, but I find them very difficult to solder back into those locations due to the tight placement of other capacitors in that area. If you're not an expert in soldering, I suggest you take the main board to a qualified electronic technician, and let him do it. But you better put the board in an anti-static bag before you take it anywhere! Hope this helps!
Oct 31, 2009 | Maxent MX42X3 42 in. HD-Ready Plasma...
Maxent MX42X3 first on
If it flickers on start up it will only get worse. Mine got were it took over 3 hours to settle down, and never would stop flickering with DVD'S. Solution for mine: Replace bad capaciator on input circuit board, I found it by using a heat gun to speed up coming on process, Cost me 62 cents to replace the capaciator my self.
Mar 03, 2009 | Maxent MX42X3 42 in. HD-Ready Plasma...
Flickering of screen (comes and goes) and weird DVD/reception problems
Depending on how old this set is, there might be a bad Hyper board bad. good Luck
Jun 29, 2007 | Toshiba 43H70 43" Rear Projection...
TV picture flickers
If your DVD player is separate from your tv, you might have a loose cable plug or connection. Depending on the type of flicker you have, a vertical circuit loose connection would cause this. If you could connect it to a cable or antenna it might tell you where the problem is located. A faulty circuit in the DVD might cause this too. Stargazer
Mar 01, 2007 | Sanyo DS31520 31" TV
TV/Cable will only play after inserting DVD
ya service is better its lose connect the tv controlpower
Dec 27, 2006 | JVC AV-27D303 27" TV
Maxent MX42X3 42 in. HD-Ready Plasma Television Logo
71 people viewed this question
Top Maxent Televison & Video Experts
Michael Harrier
Jaime Hernandez
Are you a Maxent Televison and Video Expert? Answer questions, earn points and help others
