Question about Weber SPIRIT E-210 (NG)
Cant get it to light even with a match/lighter
Brand new tank of propane. ..worked fine last night with new tank although ignitor is nit working ...had to light it with a lighter... today cannot get it to light even with a match/lighter
    Guru:
  • 1,051 Answers
Check for a gas leak using soapy water and tighten all connections.
Posted on Jun 01, 2010
I have a HD2515U Stainless Steel Dual Fuel stove (hooked up to propane, not natural gas). Oven still works, but burners wont ignite. It has electric ignitors. I've followed all the steps to make sure...
The wiring harness for the burners sound like is shot! I would think about buying a new one! have You tried to light the burners with a lighter or match to see if they will ignite? If so,replace the wiring harness, over time they go bad and short out! If You Can use lighter to ignite burner I would use the long nosed ones like You start charcoal with till The new wiring harness arrives! You will save the hair on Your arm that way! LOL! Good Luck!
Jul 14, 2017 | Siemens HD2515U Stainless Steel Dual Fuel...
I have a Kenmore Quantum grill and all of a sudden the burners do not want to ignite. The propane tank is new. I tried with a lighter to ignite the burners and nothing. The ignitor button doesn't...
The problem you're having is related to the OPD Valve in the Propane Tank. But, it is solvable by following the instructions below.
1. Turn the gas tank valve OFF and disconnect the hose from the tank.
2. Wait 5 minutes and reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow motion, slow).
4. Once the tank valve is fully open, light the burner farthest from the tank first and set the burner
control knob on HIGH. Does the flame height look correct for being set on HIGH? If so, light
the remaining burners the same way. Do all the burner flames look correct? If so, you solved
the problem. Remember, to always open the tank valve Very, Very Slowly.
If that didn't solve the problem, you will need to replace the grill's Hose/Regulator Assembly. It runs about $30.00 at any home center or hardware store that sells grills & accessories. If you replace it, turn the tank valve ON Very, Very Slowly.
Hope this helped you to troubleshoot and solve the problem. Happy Grilling and thanks for choosing FixYa.
Aug 09, 2011 | Kenmore 570 sq. in. Cooking Area Gas Grill...
I have a kenmore quantum series propane grill which i cleaned and now i cant get it to light and i smell the propane what should i check?
Donna, are you saying the ignitors are not working or that the burners just won't light? Not even by match lighting them? All this makes a difference in providing a solution for you.
Please advise. Thanks
Jul 29, 2011 | Kenmore 16228 Grill
Won't light! New tank, regulator is positioned right. It's brand new! Ignitors work! Can smell propane when i turn the tank on....Can't get it to light. It's set up for propane.. Can't...
Sheldon, this happens a lot, but it's easy to solve.
1. Turn the gas tank's valve OFF & disconnect the hose from the tank.
2. Wait 5 minutes & reconnect the hose to the tank.
3. Open the tank valve VERY, VERY SLOWLY (Slow Motion, slow).
4. Once the valve is fully open, light the burner farthest from the tank first and turn to HIGH.
Did the burner light and does the flame height look correct? If so, light the remaining burners
one at a time the exact same way. Do all the flame heights look correct? if so, you solved
the problem (with a little help). Just remember to always open the tank valve Very, Very Slowly.
If the above did not solve the problem, you will need to replace the grills Hose/Regulator Assembly as it is permanently locked up. You can pick one up for about $30.00 from any hardware store or home center that sells grills and accessories. Take you old one with you for comparison purposes.
I hope the helped you and Happy Grilling!! Thanks for choosing FixYa.
Jul 21, 2011 | Jenn-Air JLG7130A
How to you start it
Grill should have a push button igniter located on control knob panel. The ignitor requires a battery, usually AA. Remove the cap and put in battery. Make sure propane tank has propane and turn on. Make sure all connections are tight. You can also manually light it by going through the view hole located at bottom front or side. Make sure your match or lighter is in and lit before turning on gas.
Jun 20, 2011 | Char-Broil CharBroil 4637318 Grill
I have a small propane reddy heater with an electric ignitor if power is out can i manually light it
Yes, you can. Use either a butane grill lighter or a long stick match. Make sure the control knob is in the "light" position and the wick is in the right position. Light the long stick match or butane grill lighter, press the control knob in and while holding it in, touch the flame of the match or butane grill lighter to the wick and the wick should ignite. Once it ignites, quickly remove the match without knocking the tip off into the heater.
Jan 31, 2011 | Reddy Heater-40,000 BTU Kerosene w/T'stat
Berkeley Forge Outdoor Propane Heater Sunrise Model SR1001
I believe the company is out of business but I just got my heater fixed using a local gas service company. Took them a while to find a compatible thermocouple assembly but he found it so there is hope.
The unit works like new now except for the ignitor but not a big deal as it works fine to light the pilot with a lighter.
Jun 10, 2008 | Berkeley Forge G-PH001PSS Open Flame Patio...
My oven isn't warming up
can you verify the ignitor is working (ie: can you hear it sparking)?
1. If no, and you are absolutely sure there is not a buildup of propane inside the oven (or house for that matter), you can try lighting it with a match. If that works, you need to replace/reposition your ignitor.
2. If yes, do you smell propane after trying to light the oven?
A. If yes, STOP and get it fixed..
B. If no,
1. Check to see that your propane tank isn't empty?
2. Verify the regulator supplying the oven with propane is actually sending gas to the over (might need a repairman for this)
Dec 22, 2007 | Kenmore 30464 / 30465 / 30469 Gas Single...
Weber SPIRIT E-210 (NG) Logo
328 people viewed this question
Top Weber Grilling Experts
Gary Kenady
Gary Kenady
Paul Carew
Dan Webster
Dan Webster
Are you a Weber Grilling Expert? Answer questions, earn points and help others
