Question about Samsung WF337AA Front Load Washer
There seems to be water being retained in the machine
When I manually turn the drum in the front loading washer, I can hear water in there. It must be somewhere that is not draining as it smells like stagnant water, and leaves the clothes smelling if you do not take them out of the machine right away. Is there some place water could have spilt over? and if so how do you get it out
  • 159 Answers
The machine will always leave about 3 cup fulls of water in the bottom but usually you cant see it inside the metal drum.It's possible that the pump is restricted & not flowing out properly,there should be whats cauld a button trap,a little flap door at the lower front of the machine that should be opened & cleaned regularly.Alternatively water might be sigphoning back thru the drain hose into the machine.I hope this was helpfull.
Posted on Jun 01, 2010
I have a Kenmore HE 2plus front load washer and during any wash cycle the drum won't spin and at end of cycle displays F01
Front-loading washer Kenmore HE2 plus - spinning not ...
www.shopyourway.com > Manage My Life > Questions
My Kenmore HE2 plus washer has problems with spin funciton. almost all of the ... or twins size blanket, it just won't spin, even with extra spin cycle only. ... Check to see if the washer will spin without any clothes at all in the basket. ... My HE2 will wash a very small load. ... Any bigger loads The drum will try and turn but wont.
Front Load Washer Won't Drain or Spin Video: Washing ...
? 1:54
https://www.youtube.com/watch?v=wlMoT9rgvAg
Jun 1, 2012 - Uploaded by searspartsdirect
... won't drain or spin. For more front load washing machineinformation and repai. ... If the cycle has completed and water is still left in the machine select "Drain and Spin" to remove anywater remaining in the washer. This can be caused .... I have aKenmore HE2 plus front load washer. I can't seem to get it ...
Kenmore HE2 Plus 3.6 cu. ft. Front-Load Super Capacity ...
www.kenmore.com > Laundry > Washers > Front-load Washers
KenmoreFront-Load Super Capacity Washing Machine (4753) .... super wet, and to spin the empty drum after each load to hear if anything was caught in that gap. .... 1st of all: You cannot use any other detergent than HE rated detergent - PERIOD. ... will create too many suds and clog up the machine, and the clothes won't be clean.
Jan 15, 2016 | Kenmore Washing Machines
The washer always seems to have water trapped someplace...when I turn the drum after a load has finished I can hear the water moving around. Now I've noticed a sour smell. Also sometimes at the end of a...
There is a solution inside the inner tub cover that helps serve as a balancing aid during the spin cycle. It is a normal sound on the washer. There is not a problem.
Jul 21, 2010 | Maytag MLE2000 Front Load Stacked Washer /...
There seems to be water left in the machine. When
Water gets inside the top plastic ring on some machines. You would need to remove the inner tub to get at it to empty the darned thing!
Oct 24, 2009 | Maytag Neptune MAH5500B Front Load Washer
LGWM2277HW Front Load High Efficiency set Code "LE"
may be a belt problem since you have this sound
thank you
Jun 21, 2009 | LG WM-2277HW Front Load Washer
WMA54 Hotpoint Aquarius drum does not turn during wash or spin
If the machine pumps water inside but does not start :
Start checking the lid switch, if this is stuck the machine wont start.
If the drum does not move at all, the motor, the motor control unit, the motor coupler, the control board may be faulty.
For more details , see: It doesn't spin
See also a general diagram here: redarrow.gif Front Load Frigidaire/GE/Kenmore Style
Jan 06, 2009 | Hotpoint WMA30 Front Load Washer
Water stays in drum after cycle is complete and odor
I think from what you have said, that you have a pump problem. The water pump on most washers collect all sorts of bits and pieces including small coins. You may be able to clean out the pump if it is not a sealed unit.
Dec 02, 2008 | Maytag Neptune MAH5500B Front Load Washer
Water in drum
thats normal forthins machine they actuall use a water filled front ring for balance, woll always sounds as water is there. desgined that way
Nov 24, 2008 | Maytag Neptune MAH5500B Front Load Washer
GE Front Loading Washing Machine seems to be holding water....
The high speed spin of a front load washer should normally do a good job of getting squeezing out the water but if there is an oversudsing condition that makes it hard for the drain pump to operate then the suds and water will just stay there. First make sure there is no actual clog in the drain line then run a load with no soap or detergent and see what happens. It's always better to use a low suds detergent with this type of machine
Mar 08, 2008 | GE WSXH208A Front Load Washer
Samsung WF337AA Front Load Washer Logo
418 people viewed this question
Top Samsung Washing Machines Experts
Jaime Hernandez
shaun taylor
Are you a Samsung Washing Machine Expert? Answer questions, earn points and help others
