Question about Dryers
Kenmore Dryer won't heat
I have a Kenmore dryer model 110 666 42500 Series MS 2711399 Type dwjr-ele-fm54 that does not heat. The dryer has power and the fan blows, just no heat. It looks like there may be 2 switches on the heater unit but the schematic is destroyed. What should I check for first and how do I identify the component?
  • Dryers Master
  • 43,501 Answers
Hi, If you have a gas dryerKenmore Dryer won't heat - 2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...Kenmore Dryer won't heat - 2_bing.gif/>Dryer2_bing.gif Troubleshooting Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Posted on Jun 01, 2010
Whirlpool admiral clothes dryer won't turn on. It's approx 8-9yrs old & in good condition. The Model number AED4475TQ1 Serial number MY1739210 Type DWJR-ELE-2406026-FM54
Check breaker in breaker box (30 amp). Check door switch plunger on door, check door switch. Check dryer plug in to outlet.
Sep 06, 2015 | Whirlpool Dryers
What is the capacity of a Kenmore dryer model 110 62622100
The dryer should hold what the washer will hold especially if there a matched set this one looks like a super cap. hope this helps
Feb 18, 2015 | Kenmore Dryers
Kenmore electric dryer DWJR-ELE-2406028-FM54 Model 110.64632300. when we close the door the start button doesnt work until we close it 5 or 6 times. Help.
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 01, 2011 | Kenmore 64722 Electric Dryer
Electric dryer model # 110.68422700 type:dwjr-ele-2406028-fm54. Heater not working. I am an electrician so when i get my meter I will check points. Just sort of wondering what to check and where? Also just...
take the back off the heating element will be on the right side as you face the back of the dryer inside a metal container. The heating element is resistor wire. The other part that commonly goes bad is a thermal fuse it will be connected to the heating element but mounted on the back of the dryer near the bottom center right. The fuse should show continuity so should the heating element. Elements sometimes ck good but if you shake them the wire will seperate.
Aug 10, 2010 | Kenmore Dryers
Whirlpool Electric dryer type-DWJR-ELE-2406028-FM54. model LER7646JQO the heating element get very hot. the dryer does not turn on. the drum does not turn either.
If the heating element is getting very hot that means there is no air flow across it. If the drum doesn't turn then the blower is not turning causing the element to get very hot. Could be drum belt, drum rollers, or motor.
Mar 17, 2010 | Whirlpool Dryers
Where do you find a heating element for a Kenmore Model #110.66662500. Serial: MT0203728 Type: DWJR-ELE-2406028-FM54
Grainger.com is easy or you can look thru the yellow pages for a local appliance repair store, for parts.
Nov 10, 2009 | Kenmore 62602 Electric Dryer
It appears the heating element went out on our older Kenmore dryer - Type DWJR ELE 2406028 FM54. mod 110.62622101. Is this an easy fix?
Yes it is fairly easy to replace from the back. First verify it is the element and not the thermal fuse or a loss of one leg of the 240VAC circuit.
Eric
Jul 06, 2009 | Dryers
Kenmore electric dryer Mod. 100.66662501, type dwjr-ele-2406028-fm54 Dryer blew fuses, so we replaced the fuses. Dryer then ran about 10 minute, was heating fine but then blew the fuses again. Help!
Assuming that the fuses you speak of are the external pair, and not the internal motor or timer resets:
Check the fuse holder for corrosion on the plates. Often the fuse is not properly seated because of this build-up and therefore has an intermittent connection. This will cause the fuse to either heat up, or overload; ultimately failing.
To remedy this, turn OFF the breaker, or main switch if necessary, and fix a wooden dowel with a piece of emery cloth (or sand paper) on the end. Remove any visible black corrosion from the contact plates.
Finish with a spray of WD40 to protect the plates and fuse end.
Replace the fuse, ensuring that it's tight, reinstate power and try again.
Was this  helpful?
May 13, 2009 | Kenmore Dryers
Dryer runs no heat
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
Jan 09, 2009 | Kenmore 64602 Electric Dryer
Dryer don't blow hot air, everything else runs ok.
you need to check the heating element and the thermal fuse to see if they are blown.
Dec 19, 2008 | Kenmore 659 Electric Dryer
Dryers Logo
311 people viewed this question
Top Dryers Experts
