Question about Homelite Mighty Lite Lawn Trimmer
I changed the bubble on my gas homelite mightlight trimmer and
Now it leaks, no matter how tight it is screwed down. what do I do, no one said I needed to change the gasket. ? thanks denise
  • 66 Answers
I assume you are talking a primer bulb. Did you get the correct bulb? I ask because we carry over 20 different ones here on the shelf and some look close to each other but still will not work because of the lip seal and size. The other thing is that you don't want to over tighten because you will cause more damage than good. We do not usually change the gasket when changing the bulb unless the gasket was the culprit in the first place...try a new gasket. www.nnyparts.com
Posted on Jun 01, 2010
Cannot get primmer to **** up gas replaced bubble an all gas lines
could possibly be dirt clogging the air flow in the carb or make sure all screws and gaskets are good and tight
Feb 03, 2011 | Homelite Carburetor Trimmer Blower...
Need to know what carb screw adjustment need to be set at weedeater starts for about 4-7 sec then shuts down put new hoses on checked gas filter and cap checked out ok. i pump the ball about 10 times...
If there is a choke adjustment you should set that at full until the trimmer warms up, don't touch the gas. Then repull start at half choke, don't touch the gas either at this time. Then start at no choke, and then set your idle on the carberator with the adjustment screw. Also don't push the primer bulb so many time you will cause the spark plug to get flooded and drown out the spark, which is exactly what is happening.
Sep 06, 2010 | Homelite Mighty Lite Lawn Trimmer
I have a homelite gas trimmer and i replaced both feul line on in the one bigger line goes into the tank and rests on the bottom and the other smaller has a fitting it slides on to on top of the tank the...
the fule lines need to be a good tight fit or the lift pump will pull in air not fule check there a very good fit from the tank pick up to the pump
Aug 10, 2010 | Homelite Garden
Gas leaking from damaged plastic bulb on primer. How ccan I replace it? Homelite Trimmer ST 175G.
If its built into the carb, 2 screws and a cover plate hold it in place. If it is externally mounted, if you look at it closely, you will see it may be snapped into place in the cover its in. Small engine shops and Ebay have the replacements.
Jul 31, 2010 | Homelite Mighty Lite Lawn Trimmer
Homelite mighty lite 21506a
There wiil be a nut or a knob at the end of the spool where string comes out turn it left to loosen and right to tighten it. Rmove spool pull down and spool will come off foll directional arrows that shows which way the string should go put spool back on tighten screw or some you can turn with knob at end make sure it's tight before starting.
Jul 06, 2010 | Homelite Mighty Lite Lawn Trimmer
How do i replace the pull cord on the ht-22 homelite gas hedge trimmer.I can not find the manual on line.......
Remove the housing with the coil in it. Remove the screw on it, its the screw with about 3/8 washer on it. It is where the old rope was hooked up, and should still have a piece of it under the washer. It has a D shaped groove under it. take the new rope and burn the frays on it make it stiff and small. Turn the pulley around and around until it gets real tight, and align the hole in the pulley with the hole in the shroud. Take a c clamp or visegrips and clamp it in place if you can. I just hold it, then feed the rope through the hole in the shroud and pulley and rap it round D shape groove. Replace the screw and washer. Tighten it up then let go of pulley. It should zip up real quick and all way to the handle, and be real tight.
May 11, 2010 | Homelite Factory Reconditioned 26cc...
Primer button on homelite gas trimmer
It's possibly the filter, can't help there. I would check for a split line or loose connection between the tank and bulb and even splits in the bulb itself.
Apr 24, 2010 | Homelite Mighty Lite Lawn Trimmer
My Homelite UT-20002A trimmer have a hard starting problem. I remove the muffler and cleaned the carbon in the exhaust port. I also replaced the spark plug, but still the trimmer is dificult to start.
If you can, check to make sure there is a spark. Check the plug and notice if there is a presence of gas/oil mix on the plug or in the cylinder. Also, make sure the air filter is clean Try to make sure all bolts and screws are tight as lots of vibrations can loosen some of them.. An air leak on the engine could be causing your problems. A carburetor that is in need of a rebuild will do the same.. Finally an engine that is badly worn and has weak compression will not start, period.
Nov 17, 2009 | Homelite Garden
Is there a gasket under the primer bubble;it won't **** up gas
the pick up tube in the fuel tank is probably bad
Sep 16, 2009 | Garden
Gas weed eater pull cord wont retract after pulling cord
remove the cover and the screw holding the recoil down, turning the pulley ccw should release the spring then wind rope around pulley and (hopefully yours has the slot in it) wind in the direction of the pulley teeth then, holding rope in slot put back on spring and wind cw till almost tight, and install screw. Usually you can do this without taking rope handle off. sometimes you have to remove handle. look at spring end in the middle and make sure its not broke as long as you have it apart. Its a easy fix.
Thanks for using fixya
Jul 25, 2009 | Garden
Homelite Mighty Lite Lawn Trimmer  Logo
105 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
