Question about GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
Ge refrigerator won't dispense water - GE GSH25JSRSS Stainless Steel Side by Side Refrigerator
SOURCE: GE Refrigerator model #gss25sgress Water dispenser problem
What you describe was a common problem with this model and one that still pops up. Your refrig *might* qualify for an upgrade under terms of a program GE initiated a few years ago. Call 800-432-2737 first it might save you a service call
Posted on Jan 06, 2008
  • 1073 Answers
SOURCE: GE Arctica (PSS26NGSB) ice and water dispenser
need to call ge at 1800-386-1215 some of these sxs have a door insulation issue that they will either send replacement doors to an authorized service company to exchange at no cost to you or offer a rebate for a newer model. yours might be in this group
have your model and serial number out of the ref located in the refrigerator section, about 4-5 inches from the celing down the right side and call and see
Posted on Apr 12, 2008
  • 74 Answers
SOURCE: GE Profile Refrigerator Ice/Water dispenser not working
Check the connector at the bottom of the freezer door first , you should also be able to hear the micro switch click when you press the paddle
Posted on Aug 28, 2008
  • 3 Answers
SOURCE: GE Refrigerators - Water dispenser not working ? I
remove front grill then disconnect the water line at the quick connector. Place line on right side into container and push lever for water. If no water flows the problem is a solenoid on the left side of the back of refrig behind lower panel. If water flows into container the problem is related to freezing of the water line in the freezer door. GE fix is a $500 plus door replacement. Thaw from back of door behind the dispenser with hair dryer (do not get plastic too hot). Cheap fix is to insulate back of door with insulation such as a foam sleeping bag mat or the foil and bubble wrap type of ducy insulation
Posted on Dec 04, 2008
  • 10865 Answers
SOURCE: water does not fill ice tray GE refridgerator
Hi Alice. If I was nearby I would stop by and take a look for you but since we are cyber only I will assist you and yes, you can fix this yourself!
If your ice maker has stopped producing ice completely, check these, in this order:
  • It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these:
    • If your ice maker has a small red plastic lever, lower it to lower the wire.
    • If there's no plastic lever, simply lower the wire.
    In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly.
  • The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary.
  • The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Posted on Aug 15, 2009
Profile series pfs22slsbss water dispenser not working.
Fixing GE Side by Side Refrigerator Water Dispenser ...
? 4:00
https://www.youtube.com/watch?v=7G81-kJrqWI
May 24, 2012 - Uploaded by The Handyguys
But he then explains how he fixed his particular water dispenserissue by ... Refrigerator Repair - Not Dispensing Water through door- GE, ...
Nov 06, 2015 | GE Refrigerators
Water also comes out behind dispenser when used. Could this have something to do with water filter?
How to fix GE Refrigerator Frozen dispenser or water line ...
? 3:00
https://www.youtube.com/watch?v=52OfpE8zENA
Jan 10, 2012 - Uploaded by doublewide6
How to fix the frozen water dispenser on the GE refrigerator, How to fix, How to repair Ge refrigerator. You have ice, but nowater coming out the ...
Nov 06, 2015 | Refrigerators
GE refrigarator ice and water
Looks good to me! What is the model number? I thought I was going to get a demo! Sea Breeze
Apr 26, 2013 | Refrigerators
Replaced water filter and still won't produce water
If the ice maker works and the dispenser does not the most likely cause will be the=> WR57X10032 Dual Water Control Valve
In rare cases the water will freeze in your water tank or iside of the freezer door but if this has not happened before and you are seeing no extreem cold temps in lower half of refrigerator section where the water tank or coil of water line that cools the water before it reaches dispenser you will possibly resolve this problem by replacing the dual water control valve. Let me know should you have questions, Thanks Sea Breeze
Feb 27, 2013 | GE GSH25JFR Side by Side Refrigerator
GE refrigerator water dispenser won't stop after lever released
water valve in dispenser in bad,, check with store for possible replacement ,,or maybe the shut off valve isn't open all the way in water line connection
Jan 20, 2013 | Refrigerators
GE GSH25JFRF BB ice maker doesn't dispense. Water dispenses and ice maker makes ice but won't come out.
There should be a plastice hinge cover on the left top hinge on freezer door. Take it off and press the plug together firmly. Try that and let me know, Sea Breeze
Aug 19, 2012 | GE Refrigerators
Ice won't come out
if it's making ice, but the ice won't come out, it is likely going to be the dispenser motor (found behind the ice bucket).
the other possibility is the lever where you put the cup could not be hitting the switch, but most likely it is the dispenser motor.
May 21, 2012 | GE Mwf Ge Refrigerator Smart Water Filter...
GE TFX24E side by side refrigerator, ice maker won't fill with water.
Hi, I have a GE TFX24E refrigerator. The ice maker is not filling with water. I replaced teh water valve with no joy. If I pour a cup of water into the dispenser the ice maker will freeze and harvest the ice. Any ideas? Is there a replaceable water fill sensor?
Sep 03, 2011 | GE WR30X10093 Refrigerator Icemaker Kit
My ice maker is working fine. My ice dispenser is working fine, There is no water from the water dispenser. When I push the button, I hear a click but no water.
I had this same issue with my GE refrigerator and figured out it is a common problem with these units. The water line freezes up near the dispenser panel. Fortunately, GE has an inexpensive solution, a water line heater, that fixes the problem with little work. Check out my blog post on my ge refrigerator water dispenser not working for complete details.
Oct 28, 2010 | GE GSH25JFR Side by Side Refrigerator
GE GSH25JSRSS Stainless Steel Side by Side Refrigerator Logo
180 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
dweatherby
