Question about PANDIGITAL PANSCN01
Where can I get spare anti-curl plastic sheaths?
    Top Expert:
  • PANDIGITAL Master
  • 10,875 Answers
Where can I get a spare spring for the arm of my curling Iron? I live in South Africa
no where unless from the manufacturer.they usually are made as a throw away item
Sep 01, 2016 | Conair BaByliss Pro Spring Curling Iron
What is the part called it the clutch cable is inserted to on a 2000 suzuki katana 600
The cable (long, bright, shiny, braided/twisted wire) is inserted into a sheath before the two end pieces are crimped onto the cable. The sheath or housing is the black plastic tube that houses the cable.
Jun 13, 2014 | Motorcycles
I have 1981 yamaha maxim xj550. just replaced speedo cable for second time in 9 months. how do I know if speedo gear is bad or should I just replace it??
Probably its the bushing it the speedometer. Look where the cable spins in the speedometer...and where the cable sheath screws on.
You need to get some light grease sparingly into the space between the rotating head and the stationary part...I use white grease on my fingertip to push some in.. If the bushing is dry....it slows down the rotating head and the cable starts twisitng till it snaps. Normally a dry bushing starts making noise though.
When you say you replaced the cable....you meant the cable and the outer sheath correct....if the cable only was replaced there may be an issue in the sheath that is snagging the cable.
Apr 04, 2011 | 1981 Yamaha XJ 650
Replace the motor shaft cover on cuisinart dlc 7
I have a DLC7pro from around 1982 that I just replaced the sheath on.
To remove the sheath I use a small pipe cutter and took the sheath off in approximately ½ inch sections. Once the circular cut was complete I used a plier to pull off the section. - This method worked GREAT! Be sure you get ALL of the white plastic off and be sure to remove the ½ inch brass "ring" which is part of the old sheath. Also, make sure no plastic "crumbs" are in the base of the shaft where the new sheath will sit. You will see that the metal shaft has a flat side. With a sharpie marker, mark the metal shaft near the base to indicate where the center of the flat side is.
When you look at the replacement sheath, you will notice flat sides on the outside of the sheath. If you look inside the sheath, you will see two "nubs", these nubs form a flat inner side of the sheath . Unfortunately these nubs do NOT line up with the flat outside sections. Use a sharpie marker to mark the center point of the two inner nubs. The inner flat side HAS to match up perfectly with the flat side of the shaft. The marker helps you do that.
Line the inner flat side of the sheath up with the flat side of the metal shaft and push the sheath on your hand as far as it will go. It should go about an inch from the base.
Put the base on a mat on the floor ( you don't want to damage your floor) . Next you will need a hammer, piece of 2x4 wood and BRUTE STRENGHT! - Please note that once you hammer this, even just one strike and the sheath will NOT come off. Put the 2" side of the wood against the top of the sheath. Using more force than you think you should need - strike the wood to hammer the sheath all the way down. It should take 3 - 5 very hard strikes. If the base of the sheath rubs on the bottom of your workbowl - they will fuse together, so be sure the sheath is seated as far down as you can get it. Again, it takes a LOT
Dec 06, 2010 | Cuisinart DLC-10S Pro Classic Food...
The curl motor is not working properly
In the printer properties panel, select the print on the backside option. This disables the anti-curl function.
Jul 20, 2009 | Alps MD 5000 Thermal Printer
Cuisinart DLC-8 Plus Motor Shaft Cover broken.
I had the same problem: Cuisinart sent a "replacement" sheath for my DLC-8E which turned out to be the wrong one. When I replaced mine,which was cracked, none of my blades would fit over the new sheath! I "solved" the problem by purchasing a new DLC-8E motor base on Ebay for only $9.99!
Mar 09, 2009 | Cuisinart Food Processors
My demister in rear windscreen not working
Do you have rear window tinting?( the plastic sheet type ) If so,check that the edges over the demister tapes have not curled up pulling the tapes off the window and diconnecting them. If they need repair, a small bottle of tape repair solution should be available from a spare parts retailer.
El Nombre
Nov 06, 2008 | 1999 Daewoo Lanos
Anti-curl motor error
Yes.
On the Document/Quality tab, select "Print On Backside" in the Media Type box.
Apr 14, 2008 | Alps MD 5000 Thermal Printer
Print Problem error after 1/3 to 1/2 prints
This is not for changing carts, it's for the anti-curl function. You need to attach your printer to a computer, load the driver, try a test print from the computer, and check to see if the printer is reporting an Anti-curl motor error
Oct 14, 2007 | Alps MD 5000 Thermal Printer
PANDIGITAL PANSCN01 Logo
410 people viewed this question
Top PANDIGITAL Office Equipment & Supplies Experts
Mike
LP
Are you a PANDIGITAL Office Equipment and Supply Expert? Answer questions, earn points and help others
