Kt400-a4c i would love to get the right settings for this, unfortunately i cannot find a manual anywhere on the mobo or chip so i am a little stumped, any further assistance would be appreciated
    Sergeant:
    Champion:
  • 293 Answers
Bad luck, check also the memory modules that you have maybe its not compatible with the processor, check also your power supply it should be 350w to 500w
Posted on Apr 08, 2008
SOURCE:
I have a Soya SY-7VCA mobo that hasn't been used for about 6 years. Upon bootup, I received a CMOS checksum error message, but was still able to load a copy of Windows 98SE that I had on floppy. After...
Probably your BIOS battery, replace that and setup you BIOS again and it should be fine. BIOS batteries look like little round watch batteries.
Any more questions just let me know.
Thanks
John
Feb 14, 2011 | Soyo SY-7VCA Motherboard
What are the functions of its parts?
1) Motherboard Diagram, (Proper computer speak for motherboard is Mainboard. I just use Mobo.
MOtherBOard)
http://en.wikipedia.org/wiki/File:Motherboard_diagram.svg
2) Soyo SY-KT400 Dragon Ultra - motherboard diagram,
http://techreport.com/articles.x/4139
CPU = Central Processing Unit. Another term is Microprocessor, or simply Processor for short.
The 'Brain' of the computer.
The Processor sits in a processor socket.
The processor socket for the Soyo SY-KT400 is a Socket A. Also known as Socket 462.
http://en.wikipedia.org/wiki/Socket_462
The motherboard chipset is the Northbridge chip, and Southbridge chip.
The motherboard chipset for the Soyo SY-KT400 is the VIA KT400 - Northbridge chip, and the VIA VT8235 - Southbridge chip.
http://en.wikipedia.org/wiki/List_of_VIA_chipsets#Slot_A_and_Socket_A
The Northbridge chip handles the Faster capabilities of the computer.
The Northbridge chip determines what Processors can be supported, what Ram Memory can be supported, and High-Speed graphics.
High-Speed graphics being AGP and PCI Express, not a graphics card installed in a PCI slot, nor Integrated Graphics.
The Processor communicates with the Northbridge chip through the Front Side Bus. (FSB)
Think of the FSB as an 'Information Highway'.
The Northbridge chip communicates TO the Southbridge chip through the Internal Bus.
The Southbridge chip handles the Slower capabilities of the computer.
The Southbridge chip handles IDE, SATA, USB, Ethernet, Integrated Graphics, and the PCI bus.
(As in a graphics card installed in a PCI expansion slot, for one example)
Also handles information from the Super I/O chipset.
The Soyo SY-KT400 - Super I/O chipset is a VIA VT1211
There are 5 PCI slots. All connected to the PCI bus, which is connected to the Super I/O chipset.
Click on this link,
http://techreport.com/articles.x/4139/2
Scroll down a little bit to the photo of the Soyo SY-KT400 motherboard.
A) At the top middle is the Processor socket. White in color, rectangular in shape, square hole in the middle, and socket holes on it.
To the immediate left of the Processor socket are 8 Electrolytic Capacitors in a row.
These capacitors are Radial Aluminum Electrolytic Capacitors. (Used all over the motherboard)
These particular 8 are part of the motherboard voltage regulator circuit.
Specifically, voltage regulation for the Processor.
B) To the right of the Processor socket are three long Black Ram Memory slots. (Proper computer speak for Slot, is Bank. 3 Ram Memory Banks)
C) The Blue and the White connectors to the right of the Ram Memory slots are IDE connectors.
One for the Harddrive, the other one for the optical drive/s.
D) Underneath the Processor is the Northbridge chip. There is a clear fan sitting on it.
E) The large square Black chip with VIA on it, below the Ram Memory slots, and to the right of the purple PCI slots, is the Southbridge chip.
F) The 5 purple long slots are PCI expansion slots.
G) To the right of the bottom purple PCI slot is the CMOS battery.
H) Above the purple PCI slots is a brown AGP slot.
Uses AGP 8X graphics cards
Nov 29, 2010 | Soyo KT400 Chipset MotherboardAMD Socket A...
ECS long beep
Your graphics card having some problem ...
Jun 07, 2009 | Soyo AMD KT400 Dragon Ultra Black (K7VX4B)...
No signal on monitor
You might try switching the VGA cable if you haven't. If that doesn't work then I'd agree with you in saying the motherboard is likely fried.
May 26, 2009 | AMD ASUS A7V8X-X MOTHERBOARD ATHLON XP...
I need to know which Pentium 4 cpu my mobo could take. It has a chipset: Intel 82845Gl Revision B1/ Intel 82801DB ICH4. Would it take an FSB 8oo MgHz and run it at full speeed or would it clock down to...
check your pin packging. if it is 478pin packaging then you can upgrade only to that.
but the current processors use lga775 packaging. check the processor pin packaging before upgrading.
Apr 20, 2009 | E-Machines eMachines Desktop PC
Replaced soyo mobo with pc chips m848, now windows won't load
I just put a PC Chips mobo in my computer.  You need to reinstall Windows.  Windows is still trying to loa dthe drivers for your old motherboard and is running into brick walls.  So it will not load.  If there is data on that hard drive that you absolutely must have and can not replace, bring it to a friends house and make a backup.  Then reinstall windows, then trasfer back over the files.  I am aware of the fact that you can "restore" windows without losing the files.  However this option still has currupted filed to the point they are non-readable for me and many other users.  Other than that, buy another small hard drive, install windows to it.  After that is done, all you have to do is hook up your other hard drive as a secondary hard drive and run the both of them in your computer.
Mar 04, 2009 | PC Chips M848ALU Motherboard
BIOS access on Soyo Dregon Ultra KT400
when u start up the mobo than press the "del" key
over and over until u come in the bios
Dec 31, 2008 | Soyo KT400 Dragon Ultra Motherboard
Power wont turn on with M957G mobo
try and check the manual you will see the picture there thanks
May 16, 2008 | Pc Ware PC CHIPS: PC-Chip M957G...
SL-KT400-A4C - SOLTEK MOBO
yes check the switch settings on the motherboard , select the right settings for your processor.
Apr 08, 2008 | Computers & Internet
it supports only this type of processor
Support AMD Sempron CPU (2200+, 2300+, 2400+, 2500+, 2600+, 2800+).
Apr 07, 2008 | Computers & Internet
Open Questions:
PANDA TEch suPPoRt pHone @~18OO\\8O31O69}+ nUmBer rddfgt Usa PANDA USA phone number is ranked #2 out of 2 because 7,728 PANDA USA customers tried our tools and information and gave us feedback after they called. The reason customers call # I:8OO:,:8O31069 is to reach t he PANDA USA Tech Support department for problems like Where to buy, Complaint, Tech support, Repairs, Returns. As far as we can tell, PANDA USA has call center locations in New Mexico and you can call during their open hours Mon-Fri 9am-8pm EST. PANDA USA has 2 phone numbers and 4 different ways to get customer help. We've compiled information about I8OO8O31O69 and ways to call or contact PANDA USA with help from customers like yourself. Please help us continue to grow and improve this information and these tools by sharing with people you know who might find it useful. Calling PANDA USA Calling PANDA USA at this number should be pretty straightforward. Also important is what you do once you call, or what your other phone number options are. First of all, we strongly recommend using our free call-you-back tool. Essentially, we navigate their phone menu for you, wait on hold, and then call you when a representative from PANDA USA Tech Support can talk. Generally, it saves you at least 27% of your wait time. So it's faster and you don't need to listen to bad hold music. Once on the phone with PANDA USA's Tech Support department, you may need to provide them with information that identifies you as a customer, like your full name or name on the account, email address, phone number, or an account number. It's usually worthwhile to gather this information before you call. Click here if you want to compare PANDA USA's phone numbers against each other. Contacting PANDA USA in General While I8OO8O31O69 is PANDA USA's #2 most popular phone number, it's not the only way to get a hold of their customer care team. You already know from reading above that I8OO8O31O69 is their best customer phone number overall, and we have put together a comparison of their 4 total ways to contact support for you to look at as well. One thing to keep in mind as you try to reach PANDA USA help by calling them, is that other customers give their customer support at this number a 84% score for their communication skills and a 94% score for the overall help they received. That could be indicative of their abilities to help you resolve your problem overall, regardless of whether or not you call this number. Click here to see a comparison of all the phone numbers, social media and other avenues to contact PANDA USA.
Oct 21, 2019 | Panda Computers & Internet
D link router CUSTOMER service pHoNe:~{-l84433O2330}-}nUmBeR USA USAiary D link router CUSTOMER service Number +l84433O2330}}USALogin Repair service center to resolve all D link router tEcH SupPoRt pHoNe nUmBeR products. D link router ROUTER is an American multinational company which was founded by Michael D link router ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, D link router ROUTER support number, and selling of computer-related services and products. D link router ROUTER Tech Support Phone Number Recently, D link router ROUTER has been named the number D link router ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, D link router ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a D link router ROUTER Service Tag or a D link router ROUTER Get D link router ROUTER Technical Support Phone Number and Customer Services. D link router ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Oct 21, 2019 | The Computers & Internet
D link router tEcH SupPoRt pHoNe nUmBeR:~{-l84433O2330}^-} USAsary D link router tech Support Number +1{84433O2330}}USALogin Repair service center to resolve all D link router customer service phone Number products. D link router ROUTER is an American multinational company which was founded by Michael D link router ROUTER using its company headquarters in Round Rock, United States of America. It deals with the repair, growth, D link router ROUTER support number, and selling of computer-related services and products. D link router ROUTER Tech Support Phone Number Recently, D link router ROUTER has been named the number D link router ROUTER technical support advice you not to perform any troubleshooting method if you are not confident of your skills. In such cases, D link router ROUTER customer care number can be dialed to contact the certified technicians Contact Technical Support Use one of the below methods to identify your product and see the available contact options, including Service Requests, Chat, and Phone . Enter a D link router ROUTER Service Tag or a D link router ROUTER Get D link router ROUTER Technical Support Phone Number and Customer Services. D link router ROUTER is a US-based multinational tech organization having its headquarters located in Round Rock, Texas. This tech organization supports, repairs, sells, and develops technology products. Basically, the company offers computer related products and services.
Computers & Internet Logo
35 people viewed this question
Ekse
Marvin
Marvin
