Question about Whirlpool Calypso GVW9959K Top Load Washer
Washing machine starts then stops but does not turn off just keeps repeating this problem..problem started today no codes are coming up
    Brigadier General:
  • 8,619 Answers
Hi
Thanks for using FixYa. From what you have described it seems that the issue is with a bad lid switch and to resolve this it should be replaced. Lid switch is located inside the washing machine main housing near the door frame. In the below picture part#11 is the lid switch:
Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Jun 01, 2010
Washer keeps turning off and on in programe ?
Is there any fault codes on the display. If yes,re post the make of the machine and the code number. God-Bless!
Jun 02, 2016 | Washing Machines
Why won't my washing machine stop cycling?
Sounds as if somehow machine got placed in continuous wash mode you have an F5E4 code tells me you know how to enter diagnostics go to diagnostic turn the knob till wash, rinse, and done are lit press the start button washer should not start and lights should go out unplug washer and wait 10 seconds plug back up should not start if not then you are done if so repeat process
Jan 14, 2015 | Admiral 3.4 cu. ft. Top Load Washer in...
Hoover Optima WMH 147 DF water keeps on filling up
have a Hoover OPtima washing machine WMH 147 DF. It is filling up with water and not stopping, also the panel lights and wash cycle time display are not coming on. It's only 1 old
Dec 13, 2012 | Washing Machines
Machine started filling with water - then stopped and flashed F
I have the f51 code filled up with water and stopped. They are coming today to fix it. Called whirlpool and they are fixing this at their expense. I have the extended warrenty they said they are fixing codes f1 and f51
Oct 18, 2009 | Whirlpool Cabrio WTW6600SBT Top Load...
I have a bosch washing machine. The tumble lights are blinking and I cannot get the machine starting a new program
Restart the machine and repeat the following procedure to reset the machine to original factory settings.
Enter the test program by:
1. Set the cycle knob to any "X" (reset) position
2. Press and hold the Pre-wash and the Start buttons at the same time. While still holding these buttons, turn the unit on by pressing the On/Off button
3. Keep holding the Pre-wash and the Start buttons until the digital display comes on (about 5 seconds)
The digital display will show 00 for no faults or will show a fault code.
To end the test program turn the washer off at any time.
Post the results.
The result would be a fault code which indicates the error. Will await your further comments.
Apr 10, 2009 | Washing Machines
Whirlpool duet washer flashing f- 20.
not enough water coming in washer press pause/cancel twice to clear the codes the check water flow from valves look for dirt clogging the screens at the inlets at the valves kinked hoses make sure valves are full on or water pressure less than 10 psi
Feb 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Hotpoint wma10 washing machine wont stop filling up
You may have a problem with the pressure dome hose (has a cut or kink in it) or it may be a problem with the main control board. Sometimes that small hose inside the machine can get a cut or come loose. That sends pressure to the board and its valve to let the machine know that it has the right amount of water in it. If it has a hole or is blocked, that signal wont ever come on, and you have overfilling.
Sep 06, 2007 | Washing Machines
Whirlpool Calypso GVW9959K Top Load Washer Logo
56 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
