Question about DeLonghi D14527DZ Dual Zone Deep Fryer
My Delonghi D14527DZ keeps reading error when plugged in, we over filled it one time but have since let it sit empty but still won't power up.
    Genius:
  • 1,417 Answers
what this means is that ,The error code indicates that the water or oil or any form of liquid have been located by the temperature sensor reading is out of range (below 23 degrees F or above 217 degrees F)
what you will have to do to fix up your fryer is to do what is call general cleaning on it miter so as to allow the lens to communicate with it with this the problem is solve .
Good luck and thanks for using fixya.
Posted on Jun 01, 2010
Empty circuit fill circuit insert water spout press ok
when inserted the water spout if the water is delivered,that means you have an issue with the flow meter and you have to tack it to maintain,
how ever if the message (fill circuit ) turned off after the posses of filling the circuit and when you are trying to brow coffee the message shows, that means the grinder is too fine adjust it and try ones more
Apr 12, 2015 | DeLonghi PrimaDonna S Deluxe Super...
I had 178 miles to go before its empty , I drove it to work which is only 20 miles from my home and when I got to work there was only 33 miles left before its empty . I stop on the way and filled it full...
That sounds like the sending unit in the gas tank. To replace it, the gas tank will have to be removed, and the fuel pump will have to come out. I would recommend replacing the fuel pump while you're in there so you don't have to drop the tank a couple months/years later.
Aug 24, 2013 | Vehicle Parts & Accessories
Delonghi deep fryer D14527DZ
Hi there.
You can download Owner's Manual for your fryer at the Cutomer care tab on http://www.delonghiusa.com
Regards.
Nov 26, 2011 | DeLonghi D14527DZ Dual Zone Deep Fryer
D14527DZ Delonghi deep fryer
Hi there.
You can download Owner's Manual for your fryer on the Customer Care tab of http://www.delonghiusa.com.
Regards.
Printer screen reads "ink system has failed. unable to print. refer to printer documentation. error: 0xc18a0301. turn power off and then on again." i have tried turning it off and on repeatedly and every...
jusr solved this off an article. the *,#,123 thing only gets you a r0046 support answer no sytem configuration menu, so.........hit cancel the hold down canel, ok black and color buttons at teh same time, error message continues, keep holding all 4 and the power off with on botton, let sit for a few seconds, my have to restart a few times but maintenaince is done and volla-fit it. up your hp-let keep em honest. andy fecteau
Aug 26, 2010 | Office Equipment & Supplies
Delonghi fryer
I broke the plastic mount that holds the controls against the outside of the frame. That plastic mount was depressing a switch that is no longer being depressed. I get an Error message too. I'm going to try to contact the manufacturer to see if I can get a replacement part. (I doubt I can because the model is discontinued).
Aug 02, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Error message
I have the same problem. It is caused by the thermister thermal probe going bad (open circuit). Delonghi wont sell you the probe which probably costa about $2, they want to sell you a new control panel for $93. You can replace it with another thermister and it works but it will probably be out of calibration.
Jul 19, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
Full Tank very fast
witch model do you have, for some models thats normal on others its not, some run the water over hot coils and it evaporates others the water goes into a holding tank and sits their til the tank fills up then you must empty. expect more water when high humidity or in the summer
Jun 27, 2008 | DeLonghi Pinguino PACL90 Portable Air...
My DeLonghi D14527DZ will not "power up"
FIRST OF ALL YOU COULD CHECK THE FUSE IN THE PLUG IF THIS IS OK THEN CHECK THE THERMOSTAT SWITCH TURN IT BACK AND FORTH AND MAKE SURE YOU CAN HEAR A CLICK IF NOT REPLACE THE SWITCH
Feb 19, 2008 | DeLonghi D14527DZ Dual Zone Deep Fryer
DeLonghi D14527DZ Dual Zone Deep Fryer Logo
246 people viewed this question
Top DeLonghi Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Oloyede Monsuru
Gerry Harvey
Gerry Harvey
Are you a DeLonghi Kitchen Appliances - Other Expert? Answer questions, earn points and help others
