Question about Haier Mechanical Air Conditioner HWF05XC7
Haier AC Won't start
This portable AC unit was working fine. We thought we blew a fuse, but it was just the Surge protector tripped. We turned it off to run the microwave & toaster oven so as to not trip the surge protector again. When I hit the On switch, it started for a half a second then stopped. It would not start again. We let it rest all afternoon, and it still would not start. Everything else is working at this outlet and there are no blown fuses. Is there a reset switch? Thanks Dana
  • Dana Jun 08, 2010
    There is no remote with this model.
I had the same problem with a different model. I tested the cord, it worked, but still would not turn on. Well, after two days my friend and I decided we would try to replace the battery in the remote---it worked! Try your remote battery.
Posted on Jun 05, 2010
My hdmi ports aren't working when tried blank screen comes on I can plug the cable connection in and have cable
If you don't have it plugged into a surge protector box it may have fried your connections. If you do have a surge protector, try reseting or push power button on surge protector unit.
Aug 15, 2017 | Televison & Video
Monster 1250g does not turn on
Surge protectors either have a switch that trips or a fuse that blows when high current passes through. This is a safety mechanism that protects your appliances from an "electrical surge".
The fuse is most likely blown. you can easily check if the fuse still works with a multimeter. If it isnt, change it and the strip should start working again. ( if u have a reset button on the spike, try hittin that. Im not sure if this model has a fuse or the breaker switch that trips.)
Jul 18, 2014 | Monster 121650-00 7 Outlets 1250 Joules HP...
The condenser unit will not kick on...it is a concord unit,10=12 years old,13 seer,3 ton. The air handler works fine. I thought it was the capacitor. The old one was bad,I verified that with multimeter....
It could be a low refrigerant cut-out (switch), grounded or shorted motor windings, open internal winding overload protector (check at the common winding), a broken conductor, or no power at condensing unit from blown fuses or open/tripped breaker.
Aug 22, 2013 | Intertherm Heating & Cooling
SPLIT AC CONDENSER TRIPS AFTER 1 OR 2 MINS, ONLY DURING THE DAY TIME
The condensor is not cooling fast enough. Try cleaning the condensor coil. Also check that the fan goes on. At night the outside temperature is cooler and does not need much work to cool down the condensor.
Jul 15, 2012 | Haier Heating & Cooling
My window unit got hit by lightning and blew the plug right out of the wall, although it had a surge protector on it- it does not work now- any ideas on what I could try to fix it like a new fuse or...
As you saw a surge protector doesn't stand a chance against lightning!!!
The unit is toast... turn it into homeowners and buy a new one...
heatman101
Jul 12, 2011 | GE Heating & Cooling
We had a power surge in our living room while the TV was on. It was also plugged into a surge protector, however, everything else turned back on but the TV. There is no power going into it at all, as if...
Sounds like it might have blew a fuse on the AC input to the power supply, have to remove the back and look for a fuse near where the AC wires go from the plug on the tv. If the fuse is good
the power supply board will have to be checked or replaced..Next time consider buying a surge
protector that starts clamping at a lower voltage. Panamax brands usually start going to work
at 150v rms, where most others start at 330v rms..
Oct 21, 2010 | Panasonic Viera TH-42PZ80U Plasma TV
Our power went out and ever since then, the television won't work. It was on a surge protector, but the tv repair man that I consulted said those are over-rated. Please help!!
Many devices marketed as surge suppressors are actually 'temporary power taps'.
The rear of the surge protector unit should show the UL-rating of the device. If it's listed as a UL-TVSS, that's a surge suppressor. If it says 'Temporary power tap' then the only surge suppression may be a resettable circuit breaker, through which lightning could pass unchecked.
Most likely the TV power supply has failed, and the cost/complexity of the replacement all depends on the local repair shop. Modern LCD-TV power supplies are typically a $200 part, plus a similar cost for labor. If it simply blew an internal fuse, an honest shop would fix it for under $100, I would guess.
With respect to surge suppressors, the leader in this field is APC (amercian power conversion) and several other good brands are TrippLite and Panamax. These devices are not dirt cheap, but you get what you pay for.
Oct 21, 2009 | Televison & Video
''Blew'' my power strip and can't reset it.
open it up and on the inside is a fuse replace it check outlet in wall to make shure it is working
Jan 05, 2009 | Televison & Video
RCA g36788LV TV
check fuse n power supply section
Oct 27, 2007 | RCA G36788LV 36" TV
Haier Mechanical Air Conditioner HWF05XC7 Logo
419 people viewed this question
Top Haier Heating & Cooling Experts
Tom Chichester
Matt
Matt
Level 1 Expert
Vincent Schnittert
Vincent Schnittert
Level 1 Expert
Are you a Haier Heating and Cooling Expert? Answer questions, earn points and help others
