Question about Uniden Cordless Phone
No caller ID display on my 5.8 GHz Model DXAI5588-2
When calls are coming I used to be able see who called. After we moved and the phone was installed in our new place, no caller display and, after receiving a call and hanging up, the phone rings but only once. Shaw, my phone provider, checked it out with one of their own caller display units and there was no problem, it worked well and no ring after he hung up.
Heike
  • 3,866 Answers
The thing I would question is the unit itself. If you could take it to a different location that you know that has caller id and try it this would be a big help. Now not all phone systems are compatible with shaw if you had shaw before at the old location it just might be in that are there system was sending the ID down the line to communicate with the phone. But it seems to me its the unit itself not picking it up. The thing to do is have it sent out for a replacement or by a new base unit.
I know shaw is a cable service provider witch I got to question. Where they your service provider at your old place? Ether or here the phone is not picking it up but there sending it so it would be the unit and there is not much you can do but change it out or have it repaired.
Thanks and please do click the accept button for my efforts.
Posted on Jun 01, 2010
  • inkada Jun 01, 2010
    Hi, like I mentioned, Shaw is my service provider, was also my provider in the old place. What I didn't mention before was that I purchased a new 9 volt power supply during the move and used that for the first time at the new place. The old power supply had an intermittent problem and the problem was in the mini plug. I can hardly imagine that this could be a problem. I now rather think that something happened in transport and indeed replacing the unit might be the only answer, or put up and *******.
    Thanks for your effort.
    Heike
How do i make my phone number visible to my callers when calling from a Vtech phone
Caller ID
If you subscribe to caller ID service, information about each caller appears after the first or second ring. If you answer a call before the caller information appears on the screen, it will not be saved in the caller ID log. The caller ID log stores up to 50 entries. Each entry has up to 24 digits for the phone number and 15 characters for the name. If the telephone number has more that 15 digits, only the last 15 digits appear. If the name has more than 15 characters, only the first 15 characters are shown and saved in the caller ID log. Review a caller ID log entry Press CID when the phone is not in use. Scroll to browse through the caller ID log. When the desired entry appears: Press repeatedly to show different dialing options. Press 1 repeatedly if you need to add or remove 1 in front of the phone number. Press or to dial the displayed number. Dial a caller ID log entry When the desired entry appears, press or to dial. 1. 2. 1. 2. 3. 4. 1. 2. 3. • 1. 2. • • 3. • Save a caller ID log entry to the phonebook When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Phonebook then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a caller ID log entry When the desired caller ID log entry displays, press DELETE. Delete all caller ID log entries Press MENU when the phone is not in use. Scroll to Caller ID log and then press SELECT. Scroll to Delete all and then press SELECT twice.
Call block
If you subscribe to caller ID service, you can set the telephone to block unknown calls and certain undesired calls. The call block list stores up to 20 entries. Block unknown calls Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Calls w/o num, and then press SELECT. Scroll to choose Not block or Block, and then press SELECT. Add a call block list entry 1. Press MENU when the phone is not in use. 2. Scroll to Call block, and then press SELECT. 3. Scroll to Block list, and then press SELECT. 4. Scroll to Add new entry, and then press SELECT. 5. Enter the number. • Use the dialing keys to enter the number (up to 30 digits). 6. Press SELECT to move to the name. 7. Use the dialing keys to enter the name (up to 15 characters). Additional key presses show other characters of that particular key. 8. Press SELECT to save. 1. • • 1. 2. 3. 4. Review call block list Press MENU when the phone is not in use. Scroll to Call block, and then press SELECT. Scroll to Block list, and then press SELECT. Press SELECT to choose Review. Edit a call block list entry When the desired entry displays, press SELECT. Use the dialing keys to edit the number, and then press SELECT. Use the dialing keys to edit the name, and then press SELECT to save. Save a caller ID log entry to call block list 1. When the desired caller ID log entry displays, press SELECT. 2. Scroll to To Call block then press SELECT. 3. Use the dialing keys to modify the number, and then press SELECT. 4. Use the dialing keys to modify the name, and then press SELECT to save. Delete a call block list entry When the desired call block list entry displays, press DELETE.
Mar 15, 2016 | Vtech V CS6419-2 DECT 6.0 Cordless Phone,...
Uniden cordless phone caller id quit working
Using the Caller ID and Redial Lists
Caller ID (CID) is a service available from your telephone provider that shows the phone number (and sometimes the caller's name) of incoming calls. Contact your telephone provider for more information.
Caller ID list
Redial list
When a call comes in, the phone displays the number and name (if available) of the caller.
The phone saves the information for the last 30 received calls to the
CID list.
When it's in standby, the handset shows how many calls came in since the last time you checked the CID list.
Each handset remembers the last 5 numbers you dialed on it. The redial list is separate for each handset.
Dec 02, 2012 | Uniden Cordless Phone
When there is an incoming Call, the display shows,
You must have caller ID provided by your local phone company for Call ID to work. This is an additional charge on your phone bill.
Feb 21, 2012 | Office Depot Ativa D5765 58 GHz 1Line...
I am having a problem with my Panasonic KX-TG6442t. It won't store phone numbers and is not show numbers on the display when the calls come in. It just says incoming call. When I go into look at the...
Welcome to Fixya
Try to erase your phone's voice messages. Press ERASE 2 times while the phone is not in use. Caller ID is being activated by your phone provider. To use Caller ID features, you must subscribe to a Caller ID service. Contact your service provider/telephone company for details.
Thank you for using Fixya!
Jul 12, 2011 | Panasonic KX-TG6442T 1.9 GHz Twin 1-Line...
Caller ID/CLIP) not working in Panasonic cordless
Well if the phone has been bought abroad and being used in India you will face this problem. this is because of the format of transmitting the caller id info being different. In USA it is STF and in India it is DTMF. You need a convertor in the phone line which is DTMF to STF. IF you find onw in Delhi pl let me also know.
Aug 19, 2009 | Panasonic KX-TH111S 2.4 GHz Cordless Phone
2 Problems: #1Volume fades out. #2No caller ID on Call Waiting
1. move closer to base
2. you must have call waiting ID for that to work at all and most of these phones don't use it during active calls.
go to page 21 of the manual ("http://service.us.panasonic.com/OPERMANPDF/KXTG1032.pdf" if you don't have it) good luck!
Feb 05, 2009 | Panasonic KX-TG1033S Cordless Phone
No caller id on my phone
no caller id on my phone
Nov 11, 2008 | Uniden Cordless Phone
LG KU990 Caller ID
  • If you answer the call, the number (or number and name) stays on the display until either you or the caller hangs up.
  • If you do not answer the call, most display units keep a record of the calls received, including the phone number (or number and name), date, and time.
  • If the letter P, priv, private, or a similar term appears, the caller may have blocked the display of his or her number.
  • If the letter O, ????, out of area, or a similar message appears, the caller either is in an area that does not support Caller ID or has placed the call using operator assistance.
  • Caller ID comes with Anonymous Call Rejection, which, when active, allows you to reject calls from callers who block their number. Your phone does not ring, and the caller hears a message saying blocked calls will not go through.
    • To turn on Anonymous Call Rejection, press
      *77 on a touch-tone phone (or dial 1177 on a rotary phone)
    • To turn off this service, press
      *87 on a touch-tone phone (or dial 1187 on a rotary phone)
or go through
http://www.decommunications.com/support/topics/repairs/phone/no-id-name.php
Oct 13, 2008 | LG KU990 Viewty
Uniden Cordless Phone Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
