Question about AO Smith 1.5 hp 3450rpm 48Y Frame 230/460 volts 3 Phase Square Flange Pool Pump Repl
Motor hums but does't start is this the starting capistor
The motor hums but does not start is this the starting caoistor
    President:
  • AO Smith Master
  • 1,378 Answers
Thank you for posting your question here on Fixya.com.
It may be or it may be the starting switch, but could also be more severe such as the winding itself. You will need to check all of them. You will also want to examine the shaft where it passes thru the pump and motor and look for signs of rust from a pump seal leak.
If you are not familiar with testing these parts your best bet would be a local electric motor repair shop to see if the motor can be repaired or if it would need to be replaced. They should also be able to ensure there is no pump damage.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Jun 01, 2010
Dryer makes humming noise drum won't spin just goes back to pause
take out the plug and change the capistor ..make a note of the wires and take picture where they go
Aug 05, 2014 | Electrolux EIED55HIW Electric Front Load...
Husky air compressor motor hums won't start
In a safe manor, when the motor is humming, give one of the pulleys a push to help get the motor started. If the motor runs OK with the help push, the start capacitor is bad. If not the next thing to check is the tank check valve.
Nov 23, 2012 | Air Tools & Compressors
Amana front load washer hums only
A centrifugal switch to allow the motor to start up on the start winding and once started it opens to take it out of the start winding. The motor has to have voltage applied to the start winding and the run winding at the same time in order for the motor to start. The capacitor is part of the start circuit. When the motor goes to start, the voltage must be applied to the start winding in order for the motor to start or it will just hum. The moment the motor reaches a certain RPM the centrifugal switch opens up to remove the start voltage to the motor and it will remain running on the run winding. The motor will not start up on run voltage alone. It needs both, the start voltage and run voltage.
I think the problem is that the motor is not getting the start voltage supplied to the motor or the start winding has opened up in the motor.
Oct 22, 2011 | Amana NFW7300WW Washer
Dryer motor hums but does not turn when start button is pushed
If you hear the motor humming and not starting at all it most likely has a severe friction problem with the drum or motor. It could possibly have some type of garment jamming the blower wheel preventing the motor from starting too.
Open the dryer door and manually rotate the dryer drum counter clockwise (CCW). It should take very little effort to rotate the drum. If it's hard to rotate that could explain why the motor hums instead of starting up. If it turns freely, shut the door and see if will start. If it still hums and not start it may have bad motor or a low voltage supply to the motor.
Jan 24, 2011 | Maytag MDG6000 Dryer
Model # 72852 Burning smell Drum does not turn but a humming noise When door is closed it hums without the start button being pushed.
Jan 18, 2011 | Kenmore Dryers
When I press the start button, it hums but won't turn on, I hear clicking behind the cycle setting dial?
Jan 17, 2011 | Maytag Dryers
Hum when you hit start button rr lexus@yahoo.com
If you are pressing the start button and getting only humming, that is a motor. What is happening, the motor is trying to start, but the motor has been damaged in some way, so it can't start. All you get is the motor humming. If you post a model number, I can tell you the part number of the motor and an average price :) Having a motor changed by a local service man should generally cost around $200.
May 29, 2010 | Dryers
When statrting the dryer it doesn't start but hums
Sounds like a bad motor to me. If you hold down the start button and hums while its pressed its the motor. Depending on how old it is should determine your decision of whether or not to have it fixed. Hope this helps...
Nov 28, 2009 | Coffee Makers & Espresso Machines
Duo-Therm AC does not work
fan motor is possiblely bad but start with the capistors in the run box on the roof remove cover you will see where all the wires go onto a metal or plastic box depending on age of unit remove acess cover peek inside and see if you see a exploded capistor ie: i see smoke comming out of my ac capsitor are easy to change but they can kill you they store a lot of energy and are dangerous if you are not careful with them
Jul 18, 2009 | Dometic Rooftop RV Air Conditioner
Kenmore Series 80 Gas Dryer only Hums when start button pressed, but won't start
Hi, Does the dryer only hum when you push the start button?
Might be a bad motor.
Does the motor hum but, the drum doesn't turn?
Please let me know and get me a model # so I can assist you further.
Vic
Jun 01, 2009 | Dryers
AO Smith 1.5 hp 3450rpm 48Y Frame 230/460 volts 3 Phase Square Flange Pool Pump Repl Logo
280 people viewed this question
Top AO Smith Pool & Spa Experts
Jay Finke
Jay Finke
Larry Maranto
john h
Are you an AO Smith Pool and Spa Expert? Answer questions, earn points and help others
