Question about Pioneer VSX1019AH Receiver
VSX-1019AH-k, 5.1ch configured with Zone2 speaker terminals. Radio Tuner playback ok in Zone2, but all other inputs won't play back in Zone2. Am I reading p.31 of manual correct (that only analog audio inputs will be output to Zone2 speakers...so only component connections...not TV (HDMI), nor CDs (HDMI Blu-Ray), nor iPod, nor digital optical connections, etc.)? Is this true? If so, is there a work around on this?
  • 560 Answers
Hi. You are reading the manual correct. Zone2 on most AV Receiver will output analog sound only.
You may visit this forums for possible work around:
http://www.avforums.com/forums/av-amplifiers-receivers/1120095-so-what-receiver-could-output-zone-2-digital-input.html
http://forums.audioholics.com/forums/archive/index.php/t-23027.html
It is not for the specific model that you have but most AV Receiver works the same.
Posted on Jun 01, 2010
Plays only mono when listening to music
I lot could depend on how the music source has been connected to the receiver. If you are using a stereo CD player then you may need to check if it is configured to send audio in stereo mode and not mono. The input source selection for the audio is given in page 26 of the manual.
You can go to the setting menu in Receiver and configure the speakers settings according to which ones you have installed.
Also refer page 25 in the manual to over ride speaker configuration if it is not showing correct.
VSX 826 Pictures support downloads Pioneer Australia
Aug 22, 2014 | Pioneer Vsx 826 K Av Receiver Black
How do i connect a sub wooferto my reciever
I own 2 of these Pioneer VSX-D903S units.
The only way to hook a powered subwoofer up to a VSX-D903S is if your subwoofer is equipped with amplified/speaker level terminals on the back, in addition to the line-level input. If you only have a line-level input, do not attempt to hook it up to this receiver.
If you're lucky, and have speaker-level inputs on your powered subwoofer, you would use the amplified terminals (connect to B-channel on the receiver). DO NOT connect anything to the line-level connection.
Alternatively, you could build two unpowered subwoofers, then set the receiver's Impedance switch to LOW, then connect one enclosure to each of the "B-channel" outputs. Connect your regular left and right speakers to their corresponding "A-channel" outputs. [Impedance range: 4 Ohm minimum, 16 Ohm Maximum]
Jul 20, 2012 | Pioneer VSX-D903S Receiver
How to install bose 901 eq to my pioneer vsx-1019ah-k
This works for all models of AV receivers when you want 901's as Front L&R speakers..
Get yourself a nice separate amp, draw the Front L&R pre-out signals from wherever you can find them. On many, there is a pre-amp out for every channel in case you want to run external amps for any channels. That is how my old Pioneer VSX-36TX is equipped. For others, you may have to borrow the signals from a typical Tape- or Adapter-Out RCA pair. Just remember, AV receivers disable digital inputs as soon as you switch in a Tape Monitor, so choose one you won't have to switch IN. The signal Out is always there regardless of the monitor state.
Patch the Active EQ directly off that point (Amp In from the receiver, Amp Out to the new amp). Run all the speaker level settings on the AV Receiver and rock on.
Nov 04, 2009 | Pioneer VSX-1019AHK A/V receiver
I just bought a vsx-1019ah receiver. I connected
Check if your KuroLink is on or off. There are a lot of problems that users have been having with the KuroLink on. Since you have a Pioneer display, KuroLink might help in switching both the receiver and the display on and off together, but my advice to you would be play around with the settings (in your case, especially KuroLink). Also remember, the KuroLink is on by default i.e. if you've never changed this setting, it probably is on.
Hope this solution works, else check out the Official Thread on Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Oct 13, 2009 | Pioneer VSX-1019AHK A/V receiver
I have a motorolla DSR505 sattelite receiver that I want to connect to my Pioneer VSX-1019AH-K audio/video receiver. The sattelite receiver has a DVI output jack so I have a DVI to HDMI cable to connect it...
The DVI output usually transmits only video (I'm almost 90% sure about this). It would be better if you did not use the DVI to HDMI cable. Receivers and displays can be very picky when it comes to using HDMI. Your Motorola DSR505 has other output options on its rear. I would suggest using the Component out for video (the 3 outputs colored green, blue and red) and either an optical or coaxial for the audio. The Pioneer VSX 1019 AH-K has the required inputs. Of course, you would require new component and coaxial/optical cables to do the job.
Hope this helps. If you're still in a tangle, you can consult the Official Thread on the Pioneer VSX 1019 AH-K on avsforum. There are a lot of helpful people out there.
Sep 18, 2009 | Pioneer VSX-1019AHK A/V receiver
Looking to connect 4 speakers to the surround back
Series the speakers, they may not get as much power as you would like, but your receiver will last longer.
Aug 16, 2009 | Pioneer VSX-518-K Receiver
Pioneer vsx 3000 plays fine, but the radio function hums
If memory serves correct, the VSX-3000 is from the late 80's. They are good receivers from that era. From your description, it appears the tuner module could have issues, since only the AM/FM has a hum. If all other inputs sound well, it points the the tuner module. These modules are not easy to repair (PCB with SMD highly tuned parts), and are easiest and cheapest to replace. Many VSX models of that vintage use the same part. Not sure how easy it would be to find one. They are a small PCB enclosed mostly in a silver shielding, with one or two connectors from the inside and screwed to the back of the receiver, where the antena connection is.
Good luck
Jul 29, 2009 | Audio Players & Recorders
I have a Denon 2308CI. I use the 7.1 suround. I have my sony STR DE995 to use as a second amp for zone two hook up. My goal is to watch a movie in the living room and listen to the radio or any other audio...
the mani surround room should be connected to the front speakers A, Center, sub pre-out and surround.
for the other two rooms connect them to surround/back, go into settings and in power amp assignment assign the surround back speakers to the multi room.
once this is complete with your remote in the zone2 control mode you can play your sources in zone2 and control the volume also, if you have inwall volume controls set the zone2 volume to -10 and use the room controls.
To listen to the same source in both zones you will have to select that source in both zones
Nov 16, 2008 | Denon Audio Players & Recorders
SAA7130 TV Tuner...
DOuble click your speaker icon near the clock. click file then advanced, in the advanced menu select teh RECORDING radio box and click OK to return to your volume adjustments.
toggle the check boxes under each input and make sure they are turned up while you are trying to watch tv. when  you find the one that has the sound from your tuner go back to the advanced menu and make sure that input is checked under playback.
May 02, 2008 | Philips SAA7130 TV Tuner/FM Radio/Video...
Zone 2 issues
Zone 2 only plays anolog inputs.
Aug 27, 2007 | Yamaha RX-Z9 Receiver
Pioneer VSX1019AH Receiver Logo
66 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
T-Comtech Repairs
T-Comtech Repairs
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
