Question about GE Profile WPRE6150KWT Colossal Capacity Washer
VIOLENT OUT OF ROUND TYPE NOISE AS SPIN RPM'S GET HIGHER
This macine is about a year old, and doesn't have a regular agitator. It has a floating drum
  • vmelodyman80 Jun 01, 2010
    tHE BASKET SOUNDS "OUT OF ROUND" ON THE FAST SPIN CYCLE. THIS WAS PURCHASED 02/07/10
    IT IS A GE WPRE6150K2WT AT114828G
    IT RATTLES AND SHAKES AND MAKES A POUNDING NOISE
  • 10,319 Answers
Just reading upon your problem and the sales charts shows these as a very quiet washer to use.It has a floating drum and if the laundry is balled upninone side it will make a lot of noise
The websites below show many reviews on this washer and pros & cons as well
http://www.google.com/#hl=en&source=hp&q=GE+Profile+WPRE6150KWT+White+Colossal+drum+noise&aq=f&aqi=&aql=&oq=&gs_rfai=C_tZV32kETMm3FZj2Msnl6b0HAAAAqgQFT9CZrSM&fp=1328cd8acda262ff
Posted on Jun 01, 2010
  • GE Master
  • 12,061 Answers
Http://appliancejunk.com/ge/washer/31-9103.pdf
http://www.washerhelp.co.uk/diy-repair-help.html
http://www.repairclinic.com/Washing-Machine-Repair-Help
I think you may have an agitator problem. Please find above the top link is tour service and troubleshooting manual, below are two DIY washer self help troubleshooting websites, that will be of great assistance to you. Simply perform the troubleshooting procedures and you will soon isolate your issue and hopefully repair. If you need to you should call a professional to attend to the matter, if you do, always ask for a "Quote" before proceeding with any repairs.
My washer, A612S, does everything correctly but SPIN in the spin cycles. Both belts underneath are fine. The motor pulley spin fine when in the spin cycle, but the belt doesn't. When I turn it off...
the brake it the drum directly above the transmission pulley it is not intergrated into the trans.
in my almost 30 years of repairs in that old and very reliable machine i would find where a article of clothing and floated over the inner tub and has wedged itsefl between the inner and outer tub, their is enough clerance between the tub and tub cover where you could get finger into it and run it around the tub and feel if a piece of clothing is caught. if that isnt the problem then the tub bearing is ceased up and would require repalcing it and the tub seal
Jul 18, 2011 | Maytag Washing Machines
The "floating drum makes out of round knocking noise in spin cycl
On the bottom of the washer tub is a "balance block?" that the bolt has loosened on. Have GE come repair it. We just had it happen to us as well. If you don't get it repaired it will cause more damage to the washer and then it won't be covered under the warrenty.
Jun 01, 2010 | GE Profile WPRE6150KWT Colossal Capacity...
Agitator does NOT spin along w/ drum during spin cycle
If this is the old style that uses a belt, it is not worth fixing. But the problem sounds like the wig-wam is not functioning properly. Most of the time it was a wire broken since it moves back and forth constantly.
Jan 28, 2010 | Kenmore Washing Machines
Doesn't agitate and spin cycle work when reset
you have a worn motor coupler
you can order a new one at sears
and its a ver y easy repair
Oct 06, 2009 | Kenmore 3.2 cu. ft. Plus Top Load Washer
Washer is loud, and won't spin or agitate
check the motor bushes,and also check for bearings in drum you can check this by lifting the inner drum up and down if you feel a knocking noise then this will be the bearings have worn.
Jul 13, 2009 | Frigidaire ATF6000ES Front Load Washer
Malber WD1000 won't hi-speed spin
check if the drum assembly is loose, but it seems like one of the mounting arms or shocks broke.
Jul 10, 2009 | Washing Machines
My Kenmore 80 series washer just started making a loud Aihaiha electrical or motor type noise. This happened during a heavy load cycle. Noise was very loud. When I click to regular, delicate or hand wash....
The following are the reasons for the drum not spinning :-
* Test the lid switch
* Test the timer control
* Test the centrifugal switch
* Test the water level switch
* Inspect the motor coupler
* Inspect the drive belt (belt drive only)
* Inspect under the washer for soot (clutch)
* Test the motor
* Inspect the pulley
* Test the transmission
In the case of loud noises in the machine, the drum bearings might have been damaged and might need a replacement. Also do check the leveling of the machine. Good luck.
Feb 28, 2009 | Washing Machines
Noise when stopping after spin cycle or open lid (after moving)
check hub nut, it is likely loose, its under the agitator. top pops off agitator and bolt hold agitator down.
Jan 04, 2009 | Whirlpool Inglis IP4400 Washer
GE Profile WPRE6150KWT Colossal Capacity Washer Logo
57 people viewed this question
Top GE Washing Machines Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a GE Washing Machine Expert? Answer questions, earn points and help others
