Question about KitchenAid 24 in. KUDI02IR Built-in Dishwasher
Diswasher control panel not working.
The control panel on our kitchenaid dishwasher is stuck on rinse only. It will not switch to another cycle and will not start in rinse only.
  • 901 Answers
Micro controller to be checked. Refer user guide and contact the service provider.
Posted on Jun 01, 2010
Kitchenaid diswasher replaced control panel and dishwasher is not working again
Check the door switch, it could be a loose wire or broken door latch switch.
Feb 29, 2012 | KitchenAid KUDS01DJ - Multiple Color...
KUDS01FK diswasher will not start cycle. Completes diagnostic cycle properly (disconnected stuck pressure switch). If you enter a setting and press start, nothing happens. After a few seconds the lights...
Hello
first push and hold the cancel for 15 seconds and the if that dont reset the control push these buttons
normal wash ,, hi temp scub
if either of these resets the control the you will have to replace the control panel / thanks
Aug 06, 2011 | KitchenAid 24 in. KUDI01FLSS Stainless...
Control panel will not light up, the dishwasher was running and now it has stopped mid cycle and will not do anything. I just replaced the control panel (black plastic with buttons, not control...
I have a kitchenaid dishwasher model # KUDC10FXBL1 I went to start it and none of the buttons were working. I have checked the breaker and the wiring and everything seems to be in order.
Jan 13, 2011 | KitchenAid 34 in. KUDP01FLSS Stainless...
Dishwasher stuck in cycle
Hi
I have a similar problem, did you find the cause of the problem?
Geoff
Jan 13, 2010 | Dishwashers
I have a Kitchenaid dishwasher model#KUDS01J, Icann't get it to start the rinse only cycle is stuck with a light blinkin and we cann't press any other functions on the panel.
I suggest having a qualified service tech diagnose your situation. The most likely issue would be a shorted touchpad. However, a failed control board could give you the same scenario. Both parts are expensive, so you would want to know which is failed prior to changing a part.
Nov 04, 2009 | KitchenAid 24 in. KUDS01FLBL Built-in...
Bosch SHX46A02Uc/21
it is likely a control module issue. I will take mine apart this weekend to verify what others have said: solder joint on circuitboard burns out from possible overheating, and DW doesnt go into rinse cycle. Try rinse and hold cycle to see if it stops on its own. mine does, but the other cycles which require the rinse to go to 156 degrees do not; the continue to run until I cancel and drain.
Feb 01, 2009 | Dishwashers
Diswasher stopped working
there is a fuse in the washer that needs to be replaced reply to me and will walk you through it
Dec 31, 2007 | KitchenAid 24 in. KUDI01FLSS Stainless...
The "Rinse Only Button" will not function even after going through the "Cancel" cycle.
br, sounds like you have a stuck keypad. This would be the only reason it is switching to a different cycle. Catriver..post back.
Oct 01, 2006 | KitchenAid 24 in. KUDS25 Built-in...
My Kenmore diswasher gets stuck between the quick rinse and drying cycle
I am having the same issue as described above. I think it is either the timer, thermostat (temp assure), or thermostat (temp boost) that needs replacing. The dial gets stucks in both the wash temp boost cycle and rinse temp boost cycle. However, I don't have a picture of the temp assure or boost part. Does anyone know how to fix this? Thanks. -Bill
Aug 31, 2006 | Kenmore 16602 / 16604 / 16609 Built-in...
KitchenAid 24 in. KUDI02IR Built-in Dishwasher Logo
435 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
