Question about Samsung DMR57LFS Stainless Steel Builtin Dishwasher
Onstart up noisy grinding
On start up noisy grinding samsund dmr57 dishwasher
    Problem Solver:
  • 13 Answers
Most likely broken glass or some other solid debris in the drain pump.Check owners manual to find out how to clean sump ,watch out for shards of glass.
Posted on Jun 01, 2010
Noisy pump when we run the dishwasher
Recently had a similar experience. Sounded like grinding noise for a period of time. Then motor stopped. Motor bearings were shot. Had motor replaced under P.S.E.&G. Service contract. This utility company offers appliance contracts for the home. P.S. serviceman indicated they will only do that once for the contract. This is an expensive part. If you don't have access to a contract be ready for 130.00 or more for a new Motor and more to have it installed if you are not handy. Service man removed front kick plate and dropped motor without removing dishwasher.
Apr 19, 2014 | Kenmore Dishwashers
Dishwasher started whinning
Hello - Two things to consider...when was the last time the filter was cleaned? Most dishwashers have a glass trap located in the center of the filter designed to collect pieces of broken glass, straws, bones and pits. Simply grasp handle, lift out, empty and place it back. Is the unit making more like a grinding noise? If so, contact a professional because you may possibly have a defective drain motor.
Oct 20, 2012 | Frigidaire 24 in. FDB1050REC Stainless...
Error F1 on sansung dishwasher
F1 fault code is an indication that you have a water leak. Before calling in a professional, try to troubleshoot the problem on your own. Many times it can be something as simple as a leaky hose, a broken seal or a blocked drain hose causing the F1 error.
Additional details and codes in Samsung/DMR57-00026A_EN.pdf
Hope helps.
Jun 18, 2011 | Samsung DMR57LF Builtin Dishwasher
Kenmore 16532 dishwasher,three years old. It has slowly gotten very noisy. I have stripped down everything I can access from the tub, including the chopper. I can't find any problem. It is quiet while the...
It could be 2 things:
a) water obstruction in the spray jet ports causing uneven rotation of the spray arm.
This uneven rotation will eventually wear out the motor bearings.
Fix: clear out any clogged spray jet ports.
b) the motor bearing are already shot, and they're growling and howling in pain as the motor grinds them to death.
Fix: replace motor - new bearings will come with the new motor.
Alternate Fix: replace dishwasher. Often new motors are so expensive, replacing the whole unit is the bast option, especially with Sears/Kenmore (where parts are expensive)
Try: www.SearsPartsDirect.com.
I tried the sears parts web site for you, but you model number came back to a Bissel carpet cleaner.
Oct 15, 2010 | Kenmore 24 in. 16532 - Multiple Color...
I'm looking for an operating manual for Samsung dishwasher model # DMR57.
The operating manual is available at this site.
Please rate my solution if you found it useful otherwise post a solution so that I can help you.
Aug 16, 2010 | Dishwashers
Noisy dishwasher
It is the wah motor. contact Frigidaire for a replacement motor that has been redesigned to eliminate that noise
Feb 26, 2010 | Frigidaire Dishwashers
Makes growling noises throughout the cycle.
HI. here are the most common issues that will cause a noise during the wash.
* Check the spray arm for damage and obstructions
* Check the inlet filter screens
* Test the water inlet valve(see below for test procedure)
* Check the motor and mounts- The motor may e loose or one of the mounts may have separated form the housing. this will cause mis-alignment.
* Check the fan motor and blade
* Check the drain for obstructions
NOTE
If all checks out above, the culprit will be a cracked pump impeller. this will occur if the drive stud becomes unstable, allowing the impeller to partially separate form the motor spin drive stud. this will cause the impeller to rub or grind during the wash cycle. If this is the case, there are impeller repair kits available for purchase that will correct this issue.
Sep 25, 2009 | GE Dishwashers
Kenmore 17263 has a noisy motor and is leaking at the motor
I am not familiar with your particular model - so take my advice lightly.
Usually the motor and sump (not the bottom pan) come as one assembly that come as a unit. Replacing both is usually easiest and economical considering that a motor problem could be caused by something wrong with the sump, or the other away around.
Thiis is something you can fix yourself if you are mechanically inclined.
Sep 12, 2009 | Kenmore 24 in. 17263 Dishwasher
1999 k2500 4x4 5 speed started grinding only when
If it is noisy only in third, then third is where the problem is, cluster gear and/or mainshaft gear. Rule of thumb, if it is noisy in only one forward gear, then that gear is where the problem is.
Sep 11, 2009 | 1999 Chevrolet C/K 2500
Dishwasher motor makes like a grinding noise on start up
Hi. This grinding or hum can be associated with internal electric motor failure. the grinding and humming sounds are warning signs that will ultimately, lead to total failure.The actual term we in the industry use is A.C. hum. This will occur when the internal electric motor windings begin to break apart from the center housing inside the motor casing. this will disrupt the current flow, causing over heating. the grinding is because of the alignment that has been disturbed as well. The solution is to prepare for the replacement of the electrical motor or, you can repair it.
please rate and have a great day.
Mar 21, 2009 | Dishwashers
Samsung DMR57LFS Stainless Steel Builtin Dishwasher Logo
555 people viewed this question
Top Samsung Dishwashers Experts
vince
gbob59
Are you a Samsung Dishwasher Expert? Answer questions, earn points and help others
