Question about Refrigerators
I have water dripping inside my refrigerator - Refrigerators
  • Refrigerators Master
  • 43,501 Answers
The drain for the water to get away when defrosting is frozen shut...
Checkout this tip to help you..
Water Running in Refrigerator from FreezerI have water dripping inside my refrigerator - 2_bing.gif
http://www.fixya.com/support/r3780310-water_running_in_refrigerator_from
heatman101
Posted on Jun 01, 2010
Whirpool Gold refrigerator model GR2SHTXKQ01 (water leaks from dispenser. This model has freezer on top, dispenser is inside refrigerator.
Water valves leak like a leaking faucet sometimes. They just will not close all the way allowing water to bypass the valve and either drip at dispenser or drip and make a mess in freezer. Your model takes a=> 2219592 Water Valve - Dual Outlet
Change the dual water control valve and I believe this will solve this problem, Thanks Sea Breeze
Jul 11, 2012 | Whirlpool Refrigerators
Water is dripping inside the refrigerator ... Model f23elite
hello about the water dripping from inside your fridge.inside your fridge there should be a drainage hole were the water should drain out ,it should lead to a pipe that leads down the back of your fridge.try unblocking the hole and pipe this should help the water run away more freely
Apr 23, 2011 | Whirlpool Refrigerators
Water dripping down the back of the inside of our ET22DK/DM
your drain in the freezer is blocked. try defrosting the freezer. if that does work call your local repair company.
Jun 19, 2010 | Whirlpool Refrigerators
Model KSRS25FGWH01-water is dripping inside the freezer ice bin.
If it overfills and drips, look for an adjustment behind the plastic endcover with a +/- on it. - is less water.
If it continuously drips, replace the water inlet valve on the back where the house water supply comes in.
Nov 16, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water dripping inside top of refrigerator.
if freezer is on top what is happening is your drain hole behind freezer panel is clogged
Nov 11, 2009 | Refrigerators
Water driping inside from ice maker
The water inlet valve on the back of unit opens when the ice maker needs water. If the valve doesn't seal good because of sediment or wear it will continue to drip and when the water reaches the ice maker supply tube it will freeze. You can take the water line off the valve and watch to see if it drips.
Sep 27, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Water is dripping inside the refrigerator from one of the holes in the top in the area back from the light
The drain is plugged and in defrost the water has to go somewhere. Try to blow out the drain with air. Or you might have to remove the evaporator cover to get hot water down the drain. First try to clear the line.
May 13, 2009 | Whirlpool 18.2 cu. ft. Top Freezer...
Water dripping in refrigerator compartment
This is an indication that the defrost drain is clogged or blocked. Below is a link that will help you resolve the problem. Thanks, Sea Breeze
http://appliancejunk.com/forums/index.php?topic=22.0
http://servicepartstec.blogspot.com/
Apr 27, 2009 | Refrigerators
LG Refrigerator
  • the drain line in the freezer may be clogged forcing water to drip into the freezer. clean out the freezer and pour some hot water in the back of the freezer to unclog the drain.
  • another cause of this would be if the door is not sealing properly then the inside of the refrigerator will build up condensation.
Jul 05, 2008 | Refrigerators
Refrigerators Logo
203 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
