Question about GE Freezers
The ice maker is not making ice. - GE Freezers
  • 2,841 Answers
If there is no water entering the ice maker then it may be the inlet is freezing or simply not working. This is normally caused by the flow solenoid not fully shutting off or not opening at all. If it does not completely shut off, this will allow some water to flow into the freezer after it should shut off and it freezes blocking the line. The water enters the refrigerator on the rear through a 1/4" line flowing into an electric solenoid. If the water's route is blocked or the solenoid does not work, no water, no ice. Of course if the bail wire is lifted it cannot make ice. If you see the arm swing into action and 10 seconds later, you hear a buzz but no water flows the ice maker is asking for water but it is not getting there. This probably means the solenoid is ok and you have a kinked water supply line or the filter inside the solenoid is clogged. Also check the fill tube to make sure it is not frozen. A hair dryer will thaw it out quickly. If ice is laying around the fill tube it will freeze over. Check the line entering the solenoid. Turn the water supply off, disconnect it from the solenoid and put it in a bucket turn the water on and see if you have water. Lastly the solenoid itself can be defective. Either it is not opening or it is not completely shutting off. Either way it will stop the flow of water. Replacing the solenoid is fairly straight forward if you buy a direct OEM replacement and not a universal valve that fits many units. The make and model of your unit is necessary to get a replacement.
Posted on Jun 01, 2010
Won't pump water to tray.
How a Portable Ice Maker Works - NewAir
www.newair.com/articles/how-a-portable-ice-maker-works/
Look inside to find out how a portable ice maker works, and get some tips about ...Just fill a tray with water, stick it in the freezer, wait 30 minutes or so and, bam, ice! ...Power supply - if the unit won't turn on, make sure if it is plugged into an ... Leakingwater - If the pump is operating but no water is reaching the freeze tray, ...
Customer Reviews: Igloo Portable Countertop Ice Maker ...
https://www.walmart.com/reviews/product/15162429
WalmartIgloo Portable Countertop Ice Maker ... My wife is lazy and never refills the ice traysto put back in the freezer. ... Great ice maker for camping trips and parties. ... even though the thing is completely empty so it won't make anymore ice, and 1/3 of .... My satisfaction was quickly marred by the sheer volume of the water pump in ...
Igloo Portable Countertop Ice Maker - Walmart.com
www.walmart.com/.../Igloo-Portable-Countertop-Ice-Maker/151...
Walmart
Rating: 4 - ‎350 votes - ‎In stock
Buy Igloo Portable Countertop Ice Maker at Walmart.com. ... It features a 3.1L capacity water reservoir that can make up to 26lbs of ice in 24 hours. You need not drain the melted ice ..... A. yes, the ice tray that hold the finished made ice is right about the water reservoir. .... A. Jogie: No, it won't make crushed ice, only cubes.
EdgeStar Portable Ice Maker - Troubleshooting Help ...
blog.edgestar.com/.../edgestar-portable-ice-maker-troubleshooting-help/
Jan 31, 2016 | Igloo Cooler Igloo Portable Countertop Ice...
Everstar HDIM 35 ice maker
Click below ;
There's no ice
Hope this may help
Jul 30, 2008 | Freezers
F-330bah-c stopped making ice & unit is 1 month old
it should be under warranty . is the water shut off to fridge . ice maker could be bad . make sure water to the ice maker is on just check your water line . a very easy common mistake and very easy fix if the water is not turned on to the ice maker it wont make ice . hope this helps let me know how it gos
Nov 02, 2013 | Hoshizaki Freezers
Our ice machine is making too much ice. When we open the door, ice spills out - so for some reason, whatever triggers the machine to know that it has enough ice made, seems to be malfunctioning. Any...
When frost builds up on the little flapper at the top of the door above the ice maker it can get stuck. It tells the ice maker to keep making ice. Try cleaning the mechanism of frost and make sure it operates freely.
Oct 17, 2013 | Electrolux Stainless Steel Under-counter...
Does not make ice
Either the ice maker is not calling for water or the ice maker water valve is not working, there are many different types of water valves so its very dificult to tell you what to do without a model number or picture of the valve, but generaly speaking if you VERY CAREFULLY put 120V to a water valve it should open and alow water to flow, you can try this for the valve that has a water line going to the ice maker and see if it lets water go to the ice maker, sometimes there are two valves that must open, one main valve and then another for either the water dispensor or the ice maker. a better first test might be to test the water valve for resistance across the coil and compair it to another coil and see if its close-ish. also you can test some ice makers and see if they are putting 120V to the water valve by bypassing the bimetal and causing the ice maker to go into a cycle, but again a model number is required to know what kind of ice maker you have., even a picture would help
Feb 08, 2013 | Kenmore Sears Tempered Glass Shelf Refrig...
Ice maker not making ice
Hello there:
There's no ice If your ice maker has stopped producing ice completely, check these, in this order: It may be turned off. Look for the wire along the right side of the ice maker that looks a bit like a coat hanger. If the wire is in the raised position, the ice maker is turned off. If so, try one of these: bullet.jpg If your ice maker has a small red plastic lever, lower it to lower the wire. bullet.jpg If there's no plastic lever, simply lower the wire. bullet.jpg In either case, the ice maker should begin producing ice again. Also make sure that the temperature is 8 degrees Fahrenheit or lower. If the freezer is too warm, the ice maker won't cycle properly. The ice maker fill tube may be blocked with ice. If so, melt the blockage using a hair dryer-but be careful to not melt any plastic parts! Also replace the water shut-off valve or water-inlet valve, or both, if necessary. The ice maker head assembly may have broken parts. Look to see if the gears are broken. Check to see if the small plastic arms that rest against the ice rake are broken. If the ice maker head assembly is modular and you've found broken parts, you can just replace it.
Aug 07, 2010 | Maytag Freezers
The ice maker suddenly stopped making ice. The "arm" is down. Should it be up?
arm down ...Pour about 1/2 cup of water into ice maker . If it dumps , replace the water valve . If doesn't dump , replace the ice maker . Also make sure the coils are clean of dust , lint , etc...
Aug 16, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Jenn-air ice maker, stand alone unit, will not shut off, keeps producting ice.
There should be a sensor inside the ice maker bin that tells the ice maker when its full. It may be a wire or an arm on top of the ice. If you accidentally knocked that off the ice maker won't know when the bin is full and just keeps making ice
Jul 07, 2009 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Not making ice
need to check your water supply...if good then see if ice maker has water in the maker itself. if not then replace ice maker
Jun 22, 2009 | Freezers
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Freezers Logo
Top GE Freezers Experts
Charles T Nevin
Charles T Nevin
christian nielsen
Victor Nwachukwu
Victor Nwachukwu
Are you a GE Freezer Expert? Answer questions, earn points and help others
