Question about Craftsman 10" Table Saw
Wood feels like its "pinching" between blad and fence
I have a Craftsman 10" table saw (not a portable, sort of a hybrid between contractor and cabinet maker's saw) about 5 years old.
Every time I cut piece of hardwood like maple, oak or ?? the wood starts to bind and burn on the blade and becomes difficult to push through as if it is getting pinched between the blade and fence.
I've replaced the blade 3 times (the last two were Freud), re-aligned the fence countless times, bought a new Incra TS-LS table-saw fence (because the Sears fence was a bit rickity), had Sears come out twice while it was under warranty and re-align everything then tell me the saw is fine, but I still have the problem. Any idea what could be going on? Any assistance is really appreciated.
Regards;
Jacob
  • 59 Answers
Possibly the problem is the wood itself. If it is burning both sides of the kerf then it is probably that your kiln dried wood is picking up moisture on the outside from the environment which causes it to bow inwards as it passes the saw. I have even had this problem with plywood. Just keeping timber in an unheated workshop for a while can cause the problem but after a few months it should equalize and the problem disappear at about 15% moisture content. (kiln dried timber should be nearer 10%)
Cut part way along a plank and then mesure the kerf at the end of the plank and at the front of the cut. if it is significantly narrower at the plank end then that is your problem.
These hard woods you mention are always a problem to cut on domestic saws at usually a maximum of 2000 watts . I use a 4500 watt motor in my saw and it will still complain at dry oak, ash and maple etc. especially if they are moving a bit as I cut them. Before I retired I had a panel saw half as powerful again as that and still those hard woods could cause trouble.
Posted on Jun 03, 2010
Craftsman model 137.415030 10 in portable table saw won't turn on. It is getting power the switch sounds like it is working ok but it won't turn on. The reset button ,does not appear to do anything.
My table saw motor just stopped.. What do I do? - The WoodenBoat ...
forum.woodenboat.com/showthread.php?...table-saw...I...
WoodenBoat
Apr 6, 2013 - 23 posts - ‎20 authors
Does the motor have an internal thermal cutoff switch? ... Auto reset on a table saw, now that would be scary. ... A Craftsman, I think. ... The saw is a Grizzly 1022Z contractor-style saw about 10 years old. .... After the motor cools down the switchneeds to be pressed to restart the motor, it won't start suddenly ...
My table saw stopped, the reset button won't reset. What ...
www.shopyourway.com > Manage My Life > Questions
It is a Craftsman Table Saw Model 137.248880. ... I pressed the reset button and the saw restarted. I continued ... My table saw stopped, the reset button won't reset. ... One was just the switch the other the rocker switch, identical except in cost.
Craftsman 10 table saw motor stalled - Yesterday's Tractors
www.yesterdaystractors.com > Discussion Forums > Tool Talk
Dec 25, 2015 | Craftsman 21802 10-inch 13-amp Portable...
When i turn on saw it bogs down and dose not take off spining but is not froz
If you are trying to rip wood with the fence it will most likely be that your fence is not true to your blade check the blade to see if it is the same distance on both ends of the blade to the fence. If that is the case you will need to adjust your blade. Check your owners manuel to start that process.
Jan 27, 2014 | Craftsman 10" Table Saw
I need a fence for my model # 113221770 craftsman table saw
look at the uni9 fence by delta or the better yet from general. Delta is part poor. retrofit shouldn't be too much of prob.
Dec 28, 2013 | Craftsman Sears 10" Table Saw Extension...
My saw keeps cutting out when cutting heavy wood, does that mean my saw is wore out, or what can i do
When it cuts out while cutting heavy wood, there are several things you can do.
First, check to be sure you are not feeding the wood in too fast.
Next, be sure the saw blade is clean of pitch.
And, be sure the blade and fence are aligned.
Are the teeth of the saw showing completely over the wood? Just the tooth should stick up over your board.
Also, if this is a continuous problem despite cleaning and all the above, installing heavier belts sometimes helps.
"woodworker by night"
Handy Andie
Mar 20, 2011 | Craftsman 10" Table Saw
How do I make the blade parallel to the fence on a model #113.242460 table saw. The blade pinches at the end of the cut
look in your owners manual under adjustments, if you dont have one go to "managemyhome.com" and with your model number you can download a manual for the tool
Aug 26, 2010 | Craftsman 10" Table Saw
Problem with 10" craftsman table saw
Your adjustment should be done on the rip fence which will align it to the blade for strait non binding cuts.
May 11, 2010 | Craftsman 10" Table Saw
The front and back of the blade are not square to
use a square to sure up your blade so you are at a true 90 degree
Jan 16, 2010 | Delta Machinery 10" Left Tilt Contractor'S...
Blade isn't cutting well. It smokes and the wood rides up as it is cutting. The saw is 14 yrs old but blade has only been used a few times. I think it needs alignment. Can I do that myself?
You should be able to adjust the fence but every model is different so I probably cannot tell you exactly how. My Biesemeyer fence has 2 set screws on front guide of the fence for parallel adjustment to the blade (this fence is a single piece fence). I had a Sears contractor saw that had 2 bolts on the top of the fence that needed to be loosened, the fence moved parallel, and the bolts tightened again (the Sears fence was a bolt together fence). Whatever fence you have I would think the adjustment would be on the front part of the fence. I would remove the fence (the fence only, not the guides) from your table saw and take a close look at it for any adjustment screws (the Biesemeyer set screws are somewhat hidden) . If the fence bolts together you will probably need to loosen the bolts to do the alignment. There is a quick check you can make to verify the problem is the fence not being parallel to the blade because your problem could also be caused by a bent saw blade arbor (the saw blade would wobble as it turns)
ø Lock your fence down and measure from the front of the blade to the fence and from the back of the blade to the fence. These measurements should be within 1/32” (ideally is should be zero).
ø If the fence passes the test above, you can see if your saw blade shaft is bent by sliding the fence very near the blade, locking the fence down, and rotation the blade by hand (unplug the saw first). If the blade rubs on the fence as it rotates then you could have a bent arbor, a bad arbor bearing, or a bent blade.
Oct 03, 2009 | Craftsman 10" Table Saw
Biesemeyer fence not parallel to blade.
Yes you can adjust the angle of the fence. There are two adjusters at the front of the fence where it meets the fence rail. Adjusting these will pivot the fence either slightly left or slightly right.
There is a basc video on youtube my daughter made to show you how to align yourfence to the saw blade.
Feb 28, 2009 | Delta Machinery 3 HP Left Tilt Unisaw with...
Craftsman 10" Table Saw Logo
154 people viewed this question
Top Craftsman Saws Experts
Craig Butler
Craig Butler
Mike
Are you a Craftsman Saw Expert? Answer questions, earn points and help others
