Question about Troy Bilt Tb70ss Gas Trimmer
Starts but wont stay running - Troy Bilt Tb70ss Gas Trimmer
  • 27 Answers
The carburetor will likely require replacement, the series of carbs used by MTD on these handhelds are relatively inexpensive and are prone to failure, some might suggest trying fresh fuel and a carb overhaul, but past changing the gas and maybe cleaning the carb your time and money will be better spent replacing the carb, primarily because these carbs are not easily adjustable and an overhaul kit plus labor usually costs more than a whole new carb in the first place. Plus there are only two fasteners holding the carb on, a novice can replace it easily, so no labor charges for a DIY. Also check your fuel lines for brittleness or a broken off pickup line, this will cause a fuel starvation problem, as well as leaks later on.
Posted on Jun 01, 2010
There is an internal filter in the carburetor that may be clogged. Remove all the fuel from the tank and remove the back cover (clean the air filter while your at it, clean with soap and water, let dry and then lightly oil with 10W30 motor oil). On the left side, facing the carb, there is a screw holding on a plate for mixing the fuel. Remove it and clean the flter gently with a paper towl. Reassemble the carb, including the air filter, and put on the back cover. If that doesn't work, replace the carb.
Posted on Jul 01, 2010
Truck starts but won't idle. If I stay on the gas pedal it will keep running untell it warms up if I turn lights or heater on it dies right away also please help
Need help: Truck starts but wont stay running?? - FullSizeChevy.com
www.fullsizechevy.com > ... > Technical / Maintenance
Jun 19, 2005 - 17 posts - ‎9 authors The truck will start but then die right out. I can do this all day long with the same effect. I can however keep it running by feathering the throttle. if ...
Truck starts but won't stay running...?? - Dodge Dakota Forum
Nov 30, 2015 | Cars & Trucks
2003 chevy silverado 4.3 starts but wont stay running
Correct fuel pressure? EGR stuck open? IAC dirty/stuck? Throttle blade hanging open preventing IAC from working? Yune up issues?
Jul 07, 2014 | 2003 Chevrolet Silverado 1500
Running starts stay wont
i found my own results to does who are having the same problem i was double check vacum hose behind the map sensor and egr valve a simple 1.50 hose did the trick
Jan 02, 2014 | Cars & Trucks
Cant get car to stay running has fuel delivery starts with chem start but wont stay running
replace the fuel pump relay
the priming switch operates fine if starts although after the priming switch does its job the fuel pump relay takes over
Sep 06, 2010 | 1992 Buick Regal
Here is a link for you to retrieve your DTC codes on your Lumina.
http://www.troublecodes.net/GM/
Mar 17, 2010 | 1995 Chevrolet Lumina
My 91 chevy truck wont stay running it starts up then just dies
my 2001 silverado wont stay on. it starts up and runns for a while then starts to putt then it dies
Sep 13, 2009 | 1995-1997 Chevy 1500 Truck Ignition...
Generator Starts But wont stay running after a few mins.
check the oil level most products like this have a safety valve.
Jul 15, 2009 | Generac 5622 GP Series GP5000 6,250 Watt...
Wont stay running
check your tps it may have gone bad. had that happen to a friend changed out the tps and when he cranked it it stayed on hope this help u out let me know
Jun 28, 2008 | 2001 Kia Sephia
Troy Bilt Tb70ss Gas Trimmer Logo
1,214 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
